Results 1 to 6 of 6
    120mm hub, 135mm frame
    Can a respaced 120mm track hub be used in a 135mm mtb frame? More of a theory question.
    If you get a long enough axel and enough spacers.
    Quote Originally Posted by cannotaim
    True, but what about the chainline with the difference widths of the hub bodies?
    The need for singlespeed
    Reputation: zaskaranddriver's Avatar
    My SS roadbike has a 120mm hub and 41mm chainline. Even the granny ring on MTB cranksets is at least 42.5mm, so the chainline will be off. I guess you could work the spacers so the wheel is offset in the drops, or maybe use chainring spacers. But with the latter you might run into clearance issues with the bottom bracket.
    Quote Originally Posted by zaskaranddriver
    You would need to re-dish the wheel a bit if you go this route.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Quote Originally Posted by Val Garou
    Yup. It would be a lot easier just to get another wheel.
