Results 1 to 25 of 25
    Mar 2013
    1/8 chain with a 3/32 cog
    will there be any issues running a 1/8 chain with a 3/32 cog. also what chain would you recommend?
    1*14*29*2.1 & 1*1*29*2.4
    I've been wondering about this too...I have a 1/8 ring and chain I want to use but will probably get an WI eno freewheel which is 3/32 I think...I haven't seen anywhere that they make a 1/8 which I think is strange. The combo didn't work so well on my Rohloff...still worked but was a little noisy
    WillWorkForTrail
    Jun 2012
    I don't think there are any specific issues that would prevent this from working provided the tension was kept just right, etc. I've actually done this before in a pinch. I busted one chain, and had a spare for a different bike, so I used that to go for a ride before the replacement chain came in at my LBS. It does make a little extra noise, and it will walk back and forth on the cogs some. My concerns with doing it long term would be uneven wear causing the early demise of either the chain or the cogs. Like I said, nothing specific preventing this from working, but I'm not sure I'd do it long term.
    Reputation: p4nh4ndle's Avatar
    Oct 2012
    nope. none. don't try to do it the other way around though. it doesn't work.
    Edit: i like the sram pc7x when i can find it
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    I've run 1/8 chains with 3/32 sprockets without any issues. Lots of others say the same. If there is an issue with the drivetrain, it's likely to be something else than sprocket width.
    undercover brother
    Reputation: tangaroo's Avatar
    Nope, been running a 1/8 chain on my 3/32 gears for about a year now.
    Reputation: thickfog's Avatar
    Oct 2010
    Re: 1/8 chain with a 3/32 cog
    Working ok for me over year and a half now.
    CRAMBA Chairman
    Why not just use the correct chain?
    Mar 2013
    Quote Originally Posted by SS Hack View Post
    i have a profile chainring that i was planning on using
    Mar 2013
    Quote Originally Posted by Cotharyus View Post
    yah i've read other comments about extra noise. is the noise that noticeable? does it sound like a grinding noise?
    Oct 2010
    I hear like a slight skip noise here and there. Nothing crazy.
    CRAMBA Chairman
    Quote Originally Posted by Deez66 View Post
    Is that a 1/8? ideally everything should match.
    Mar 2013
    yes it is 1/8
    yes it is 1/8
    Sounds like you need a 1/8 rear cog now.
    Oct 2012
    Drivetrain noise is more dependent on straight chainline, chain quality and lubrication. With those things in order a 1/8 chainring and chain with a 3/32 sprocket is as quiet as anything.
    Mar 2013
    Quote Originally Posted by Saul Lumikko View Post
    what chain would you recommend? btw its for a 29er.
    Mar 2013
    thanks for all the info guys.... lots of good stuff
    WillWorkForTrail
    Jun 2012
    No, it's not a grinding noise. What I heard was more of a chattering noise. Now, keep in mind, that could be because it was a new chain on an old set of cogs. It's possible that the year's worth of wear on the cogs was simply causing some oddity in the way the chain was running over them.
    Mine too...like you could hear each roller in the chain slapping each tooth in the cog.
    Something made for 29ers, the 26er chains won't work.
    undercover brother
    I'm hoping someday they will upgrade the technology of the 26er chain... its not fair that the 29er chains are just so much better...
    Reputation: J.B. Weld's Avatar
    I read this awhile back on the Surly info page and agree wholeheartedly so rather than plagiarize I'll just copy and paste.
    4. 1/2x1/8" chains vs. 1/2x3/32" chains. 1/2x1/8" chains suck. Run whatever you want, but bigger isn't better here. Yeah, they're wider, but according to manufacturer-supplied data, they're not stronger and they are definitely not of better quality. Multi-speed drivetrains is where the bucks are at, and chains that work on such drivetrains are where the manufacturers of chains showcase their innovations and developments in quality. The rollers are better, the plates are better, the pins are stronger, and the construction method (riveting procedure) is better on all multi-speed 3/32" chains. I guess if you grind your chainring and chain down the handrail every night at the local pub, a bigger 1/2x1/8 " chain will last longer, but most of us don't and it won't.
    Reputation: GTscoob's Avatar
    Thats a good point but the amount of contact area between the pins and the plate is immense on a 1/8th chain. Also the fact that track sprinters put down more strength than road racers pushing 10/11 speed drivetrains makes me think otherwise in actual use.
    I've never seen a broken KMC Kool 710 chain. Heavy but indestructable.
    Quote Originally Posted by J.B. Weld View Post
    But all the cool hipster kids use 1/8 and they're got to be right! All them pretty colors too.
    I am sure there is truth to that. I run 3/32 on my rohloff because there is not too much choice. The older style 8 spd chains are plenty wide and have to be lighter than a SS chain. Strength wise, it is debateable. Rohloff was famous for their chain making...taught Campag how to make them virtually. They have ceased the production of their chain but will start production of a SS/IGH chain. Their reasoning is that the move to 10 and 11 spd chains has compromised the strength and longevity of standard style chains, and they don't want to compete in that market. They feel they can make a better quality chain in the S format. Also, it's not just about the chain. I hope to get better life out of the rings and sprockets with extra width.
  1. Replies: 4
    Last Post: 03-14-2013, 05:23 AM
  2. Replies: 10
    Last Post: 08-13-2012, 06:34 PM
  3. Chain skipping- new rear derailer, cable chain and cassette already in place
    By Master Obiwan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2012, 08:06 AM
  4. Old components on new frame .2" shorter chain stay - chain length reduction?
    By DPDISXR4Ti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2011, 03:32 PM
  5. I hate Shimano. Chain routing? Breaking the chain? Derailleur adjustment?
    By happyriding in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-03-2011, 01:39 PM
