Results 1 to 8 of 8
    Happy trails
    Reputation: FATTRAXX's Avatar
    1/2 chain on standard (3/32?) cog and ring?
    I have a NIB 1/2"x1/8' chain laying around.I have a SS cog on the rear and a non-ramped DH style ring up front.Both are for the narrower chain.Can the wider chain be used without any bad things happening?
    Aaron
    I haven't gone on too many rides but, I ran a 1/8 chain on 3/32 gears without realizing it. I honestly just slapped everything together and went. I guess I was too eager to get the SS rolling I didn't notice the side-to-side play the chain had with the gears.
    However, I had no issues running 1/8 chain on 3/32 gears. I did however have a good bit of noise, but no problems.
    It does not matter. You are just fine.
    Mtbr Forum Sponsor - Homebrewed Components
    i've run it that way for years, but if you replace your cogs and rings, i would go with 1/8" because the extra surface area will increase the lifespan by alot. If you already have the 1/8" chain, why the hell not, right?
    It works just fine. Especially with thicker SS cogs and rings with no ramps or pins.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    I bought a nice SS/6 speed 3/32 chain for less than $10, how much are you saving? I'd keep the 1/8 chain around for when a friend needs a Typhoon or StingRay chain....
    enjoys skidding
    Feb 2005
    I've done it before. No real issues but it did seem to wear out the rear cog quicker than normal.
    Bicyclochondriac.
    Quote Originally Posted by FATTRAXX
    I did that once, but the chain would make noise sliding side to side. Mostly just irritating, not a major issue. Plus I was running a bash guard and had to shim it out to keep it clear of the chain. YMMV.
