Results 1 to 10 of 10
    #@$*& creaky EBB!
    I've got a Soul Cycles Hooligan, with a set screw EBB. Love it.
    But, it's been getting pretty damn creaky. Don't love that.
    I couldn't find the source of the creak, but it must be the EBB right?
    Took the entire drive train apart. Greased up the chainring bolts, cleaned everything up. Dumped out the mud and crud from the bb shell. Greased up the EBB with white lithium grease, put it all back together, headed out for a wet, muddy ride.
    Soon enough, creak!, creak!.
    #@$*& ! #@$*&ing EBB!
    Took out the EBB, cleaned it up, wrapped it in plumber's tape, put it back together.
    creak! creak!
    Took out the EBB, cleaned it up, greased it up with Phil's grease, put it back together.
    creak! creak!
    #@$*&ing losing my mind on a ride last night. what the hell is wrong with this thing?
    And all the while, I'm thinking, I keep doing the same thing and expecting a different result... isn't that a sign of insanity?
    Sure enough, towards the end of the ride I broke out the multi tool and tried to find anything else that could be causing the creaking.
    Cranks loose? No.
    Chainring bolts loose?
    TING!
    Cracked chainring bolt. Sheared when I put a wrench on it.
    Blessed quiet from there on out.
    Reputation: alex_k's Avatar
    not sure if it helps you... but check your saddle as well... I spent hours looking at crankset and bb and then found out a problem with my saddle.
    yeah, that too. I have a Thomson seat post and it seems to gets creaky pretty quickly, but I'd addressed that as well.
    I think that the whole issue was that one chainring bolt. I'll throw some new ones in there for a Saturday ride, hopefully I'll finally have a quiet bike.
    The funny thing is that last night, it was the left crank that was causing the creaking. Left crank forward and dead level, down to the bottom of the stroke would cause a creak every time.
    Reputation: Nater's Avatar
    I believe the Carver 54mm "creak-proof" EBB insert will fit the Soul.
    that's good to know.
    my point though, and I guess it should have been made more clearly, was that the creaking was not an EBB problem. I was blaming an innocent party.
    I just turn up the volume.
    Sweep the leg!
    Reputation: Caffeine Powered's Avatar
    Mar 2005
    If you ever find yourself riding with someone on a full suspension rig you'll wish you had a creaky EBB
    Authorities speculate that speed may have been a factor. They are also holding gravity and inertia for questioning.
    Quote Originally Posted by Caffeine Powered
    I had a creaky full suspension rig that I sold to a friend. He got it to stop creaking, which I was never able to do. Makes me question my skills as a mechanic.
    I just replaced the chainring bolts, off for a ride - I hope it's a quiet one.
    Roc
    Roc is offline
    Reputation: Roc's Avatar
    I had the same problem with my Zion, then I bought one of these http://www.bikeman.com/content/view/1868/119/
    Huge difference, you occasionally have to tighten it, but it's immediate improvement.
    Roc
    Quote Originally Posted by grundy
    That's what I get for merely skimming the OP!
