NOW OPEN 2009 Virtual Tradeshow Booths:
BH,
Chumba Racing,
Diamondback,
Edge,
Ellsworth,
Ergon,
Felt,
Formula,
Fox Racing Shox,
Fuji,
Giro/Easton/Blackburn,
Gu Energy,
Ibis,
Jamis,
KHS,
Kona,
Knolly,
Look ,
Lupine Lighting,
Motobecane,
Norco,
Panaracer,
Park Tool,
Pedro's,
Pivot Cycles ,
Race Face ,
Ritchey Design,
Santa Cruz,
SRAM ,
Syncros,
True Precision,
Turner,
WTB ,
X-Fusion
04-26-2005
#1
Santa Cruz NOMAD - REVIEW (just added)
My Nomad..
Top Tube: 22
Seat Tube: 70
Head Angle: 68 (depends on tire and fork choice) (mine is 67.5)
Bottom Bracket: 13.7 (depends on tire and fork choice)
Weight: 30.4 lbs.
Days ridden: 7
Crashes: 7
Problems: 0, no problems yet. Since I'm 6'0 I think a large would be in order... The top tube is a bit short for my taste. A through axle option would be nice for those of us that are using the bike for aggressive DH/All Mountain riding.
The Nomad
Santa Cruz has built a bike that meets the needs of someone who would like to use the same ride for everything. Most of us have a plethora bikes for every style of riding; unfortunately we can't always take multiple bikes with us on trips. The Nomad allows us to have a bike that can handle everything, it is a cross between an XC race bike and a full on DH machine. Although the bike is not built specifically for either style of riding it can handle both extremes. The Nomad can be classified as an Aggressive Trail Bike and its geometry lends itself to almost any style of riding.
Sloping Top Tube:
Santa Cruz has scored with those of us that find it important to slam their seats on technical descents. Having a sloping top tube not only brings the center of gravity down a but it also gives you far more clearance to throw the bike from side to side without hitting your legs. While riding fast technical singletrack it is very important for a rider to move the bike from side to side without the top tube getting in the way. People use the term "flickable" when describing this phenomenon, I can say for sure that this frame has that attribute. It is very "flickable" and almost feels like you are riding an overgrown slalom bike with XC prowess. Hitting corners at speed seems easier when you have a sloping top tube; it just feels like you can get your body and center of gravity lower in the corners.
Cornering:
The shorter wheelbase allows for much quicker direction change, thus tight corners can be negotiated at higher speeds. Quick hops out of corners are much easier as well. The 67.5 degree head angle is steep enough to get your weight forward so that its easy negotiate high angle flat corners. Once again the 70 degree seat tube allows the rider to put the saddle all the way down to the frame for a more comfortable position.
Climbing:
On the climbs the Nomad feels like a true XC rig. It is very stable while pedaling in the saddle and its also very easy to transfer your weight over the front of the bike when the climb gets steep. The seat tube allows the rider to utilize a full-length post for long climbs. The 70 degree seat tube makes for a comfortable ride while pedaling in the saddle. Other bikes in this category have very slack seat tubes which make it hard to pedal uphill. My bike feels very stable on the climbs, it sits down into the first 1/3 of travel and does not move much while on smooth ascents. If you happened to run into roots or logs on the way up the trail, the bike will soak them with no problem.
Descending:
The Nomad's suspension set up is similar to other Santa Cruz designs such as the Blur and Blur 4x. Depending on how you set up your shock, will determine how the bike performs. I have a DHX Air on mine that has 200lbs in the main chamber and 80lbs in the boost valve. I weigh 185 lbs. My bike is set up for more of a high speed DH/Trail application. I ride trails that are very fast (in excess of 30 mph during most of the ride) with large hits. By hits I mean holes, rocks, railroad ties, logs, roots and jumps.
Set up will vary based on personal preference, intended use and riding style. For Instance Mark Weir likes to run 40% sag in his shock. Mark Weighs 165. He runs 160lbs in the main chamber and 100 in the boost valve. People may choose to run a softer application like this for aggressive trail riding. It allows the rider to utilize more travel during the ride. Keep in mind if you set it up like this you will bottom out occasionally on larger hits.
Jumping:
This bike is killer for jumping. Once again, it's low BB and sloping top tube make it easy to throw around in the air. Whether you are hitting dirt jumps or trail style hits the Nomad will perform.
Written by Forrest
Additional info provided by Mark Weir.
__________________
forrest@mtbr.com
04-26-2005
#2
I wanna talk to Samson!
Soooo....how does the suspension work?
Sick ride holmes.
__________________
JackNugz
Originally Posted by zedro
no, but they are shinier....it's like the fututre, where everything is really really shiny.....but still really just the same ol'crap
04-26-2005
#3
suspension...
I'll let you know as soon as I can... My ankle is all jacked up but I should have some info by next week...
Thanks,Forrest
__________________
forrest@mtbr.com
04-26-2005
#4
dam thats sexxxxxxxxxxxxxxxxyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
04-26-2005
#5
Cynical Bystander
That looks about 150x better than the chrome one! That is one sexy bike. :drool: You gonna use her for mostly trail riding or all around fr/xc/dh/whatever type stuff?
__________________
Tony
is making a comeback.
Colorado School of Mines - ChemE
Running my way back into cycling
04-26-2005
#6
Soul Cycles
awsome
04-26-2005
#7
im cool. i swear
i wonder how those hydroformed tubes compare to normal tubing, strength wise
04-26-2005
#8
brooklyn bike rider
damn i gotta agree that's a fackin FINE bike.
i want one...
__________________
Originally Posted by fred3
Some folks hug trees. Some hug steel bikes.
04-26-2005
#9
M070R-M0U7H FR3NCHI3
when are you getting "SantaCruz" tattooed across your belly?
04-26-2005
#10
adding sodium to water
that looks way more slick and organic than the prior press kit/Sea Otter images we've seen (white powdercoated and polished alu). let us know how well it rides.
04-26-2005
#11
when are they going to be on santa cruz's website
04-26-2005
#12
Bike Hoor
Can you put a coil on that rig? I have yet to hear a definitive answer on that one.
Sweet ride, BTW.
04-26-2005
#13
Trail Riding, DH/FR... anything!! it shuld be cool...
Thanks for the compliments... I will let you know what's up after I ride it...
Forrest
__________________
forrest@mtbr.com
04-26-2005
#14
Strength...
I'm not sure but I've heard they are very strong...
__________________
forrest@mtbr.com
04-26-2005
#15
Yes, you can get a Coil... Weir is running his with a....
DHX coil... It has an 8.5 eye to eye... I bet it would be really nice with one.
thanks
__________________
forrest@mtbr.com
04-26-2005
#16
Me gusta
shes perdy
__________________
chode1: dude I cant nail that road gap
jong2: yah dude.
chode2: dudes, if we had a team...
jong1: yeah just like on that Disney movie!
chode1: chix would dig it and wed get layd
chode2: everyone except you that is
jong2: yeah lets be the Paris Hilton Death Squad
chode2: PHOQUE YEAH!
chorus: TIME TO DO THE ROAD GAP!
Origionally posted bygonzostrike
04-26-2005
#17
Bike Hoor
With a coil, IMO (and mine only) that would be the PERFECT bike. Then again, Intense has a 6.6 on the way. Seems as though SC is first to market with any new VPP genre of bike. Maybe that is part of the licensing deal... who knows.
You must be the first Nomad owner in the whole damn world.
04-26-2005
#18
AMAZING BIKE!!!! how did you get one?
04-26-2005
#19
SCAR'D 4 LIFE
efing 31 pounds...wow. that is light what are all the components
__________________
!!!!!!!!!!!!!!!!!!!GO 24 Dupont Chevy!!!!!!!!!!!!!!!!!!!
04-26-2005
#20
Uhhhhh...
Umm...thats Forrest. Hes sponsored by Santa Cruz.
__________________
Fayetteville, AR and N.W.A RePrEsEnT
04-26-2005
#21
Mentawais... I'm not sure why they....
let me have one at such an early stage... I think it may be because I usually break all my stuff. Anyway, I'm super stoked to have it!
Thanks,Forrest
__________________
forrest@mtbr.com
04-26-2005
#22
Shiver me... Here is the component list...
Medium Ano Grey Nomad, Fox 36, Fox DHX Air, King Headset, WTB Dual Duty Wheelset, Thomson Stem, Easton Monkey Bar 31.8, XO drivetrain, Truvativ GXP crank with a triple, XT front der, Thomson Post, WTB Shadow V Stealth Saddle, WTB Mutanor 2.4 rear, Weirwolf 2.5 front, Hayes Mag disc brakes...
I think that is it...
Thanks, Forrest
__________________
forrest@mtbr.com
04-26-2005
#23
SCAR'D 4 LIFE
Thanks, Forrest
thanks...running tubeless will get it to 30 pounds ... WOW ...if that can hold up to abuse
__________________
04-26-2005
#24
Trail rider and racer
One can safely conclude after seeing pictures of it in White, that this ol' color looks mighty fine indeed. Nice bike!
Whats the saddle may I ask? It looks a little beefier than a SLR but a little less stout in contrast to the other WTBs I've seen.
__________________
Trev!
04-26-2005
#25
Cynical Bystander
Originally Posted by SHIVER ME TIMBERS
thanks...running tubeless will get it to 30 pounds ...WOW ...if that can hold up to abuse
I bet it can, seems like it'll be tough competing with this and the new Enduros.
__________________
Tony
04-26-2005
#26
Bionic Mtn Biker
Damn, like something straight outta MOMA...Truly a work of art. Looks like I'll be waiting til '06 to get my grubby lil' mitts on one.
__________________
Better than he was before. Better. . . Stronger. . . Faster. (but not smarter)
04-26-2005
#27
RIDE TO LIVE&LIVE TO RIDE
that's a really sick bike. looks much better than i thought it would. have fun on that thing.
nice.
04-26-2005
#28
Fartographer
Administrator
Nice Pictures, but...
I think we're going to have to get you to a fisheye lens anonymous meeting.
That first photo is super cool.
People are asking about hydoform tubing. It's supposed to be both lighter and stronger. And maybe more importantly - ithe hydroform parts supposedly cost less to manufactuer. That should mean cheaper and better bikes for all of us. That's what they say, anyway.
04-26-2005
#29
Cynical Bystander
The hydroform looks pretty damn cool at times as well... and in certain colors.
__________________
Tony
04-26-2005
#30
Whats the top tube length. Head angle, and bottom bracket height?
Curious ya know!
Thanks, M.C. Yeh, that is nicer than what I was expecting.
04-26-2005
#31
Angles Etc... I will take measurements tomorrow...
and give you the skinny...
Thanks, Forrest
__________________
forrest@mtbr.com
04-26-2005
#32
Shiitake Mushrooms!
That's what I was thinking.....but I don't know nuthin' about photos, so I was glad to hear PJ say it first.
Cool bike.
__________________
Mmm... Adrenaline, sweat, and sardines. These tracks are fresh sir.
04-26-2005
#33
The king is on fire
Santa Cruz's are hot **** thats for sure.
04-27-2005
#34
College
Thanks, Forrest
you Should take some more pictures
 . that color looks much much much much better than the white and polished ones.
04-27-2005
#35
wow..that is a nice ride..!!! i really need an all mountain bike...i got a 2000 cannondale jekyll 600 and its quite shitty especially with the head shock!! but i just bought myself an IH Sunday factory..so i guess it will be the end of this year that i will be getting an all moutain bike..
and the Nomad is defn on top of my list...
but sick ride!!! how did u get it so quickly? i tried to order a v10 and got the sunday instead as it was taking ages to arrive!!!
like pictures as well
KC
__________________
Also know as TurnerDHRider
04-27-2005
#36
what the hell thompson stem is that? i thought i was gonna need their 6 bolt bmx stem. is it out to the public yet?
04-27-2005
#37
More photos... I will take more photos this afternoon...
I'll try to get some detailed ones.
__________________
forrest@mtbr.com
04-27-2005
#38
Ultimate Poseur
Wow!
Holy! That is sex on 2 wheels. Must resist the urge to sell off stuff to own one. Simply gorgeous.
04-27-2005
#39
34 miles per sandwich
Very nice Forrest. I liked the white, but yours looks even better. I'll be looking forward to a ride report.
picture request: closeup, non-drive side, BB area. Gracias.
BTW: how did you jack up your ankle?
__________________
Nick.
04-27-2005
#40
heckler and jekyll
pc gray
thats the best color i've seen on the nomad so far! that bike freaking rocks bro! let us know how she rides...
looks like my heckler's got a year left to live... enter the nomad
04-27-2005
#41
/dev/null
Wow, that looks great. The polished version looks downright hideous but that's very.. understated. Sweet!
04-27-2005
#42
Can you measure the following for me;
BB Height
Wheelbase
Chainstay length
Effective TT length
__________________
I know in my heart that Ellsworth bikes are more durable by as much as double. AND they are all lighter...Tony Ellsworth
04-27-2005
#43
Rear Brake
Every Nomad I have seen set up has seemed to have a 6in rear rotor. I don't want to get into a debate about not needing more than 6 since I'm sure you don't really. I just happen to have a 7in M4 and am wondering if I am going to have to buy a new rear brake if I get a Nomad.
Will a 7 or 8in rear brake rotor fit on that frame?
#44
Yay
That is an AWESOME bike dude! im so jealous!!! Let us know how it rides!
__________________
Life is not a journey to the grave with the intention of arriving safely in a well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, -WOW- What a ride...!!!!
04-27-2005
#45
Fashionably functional...
Always thought the bike was FUUUUUUUUUGLY...till I saw this one. SWEEEEEEEEEEEEEEEEEEET!!! Definately a better color choice than what they released to press so far. Anyone have a clue what a frame is gonna cost yet? I love my Heckler and I spec'd it out lovely. If any change was to happen, it'll prob be just be frame and any little thing I break till then.
04-27-2005
#46
Stem...
That is the new Thomson 31.8 X4 stem...
__________________
forrest@mtbr.com
04-27-2005
#47
Nick, I jumped that creek gap....
in Santa Cruz and came off sideways... I tried to put my foot down to keep me upright but it didn't work... No biggie though, it could be worse!
thanks,Forrest
__________________
forrest@mtbr.com
04-27-2005
#48
It will fit an 8in rear for sure dude... I just wanted to save...
the weight...
thanks,
__________________
forrest@mtbr.com
04-27-2005
#49
Xtremely Moderate
Nice bikey.
What about tire width?
__________________
"Korash your enemiez, zee zem driven bevore you, and ear ze lamentation of za vemen"
04-27-2005
#50
Killer Bike...
That is a sick looking bike bro!!! I can't wait to get my hands on one next year! I currently ride a VP Free and I'm very satisfied with the Santa Cruz craftsmanship and the VPP suspension.
Have fun on that!!!
More pics please!!!
__________________
Manny
04-27-2005
#52
The photos of the chrome bike at Sea Otter made me want to yack, but now its growing on me. (Like a tumor, maybe). The grey is WAY nicer than the chrome (or the white for that matter).
Sweet bike!
04-27-2005
#53
It has a super wide rear end... It will fit up to a 2.8 I'm...
sure...
Originally Posted by eo
Nice bikey.
__________________
forrest@mtbr.com
04-27-2005
#54
MTBR.com Addict
sure...
Hey Forrest, who is that person in the pics? He looks familiar to me. I've seen him in the shop in the back of Walnut Creek Performance Bike.
__________________
Education Coordinator for Bicycle Trails Council of the East Bay
www.btceb.org
Help us support open and multi-use trails.
04-27-2005
#55
Fast new kid on the block - Ryan Condrashoff
04-27-2005
#56
Luc is right... That is non other than Ryan Re....
Condrashoff... Hanging out!
__________________
forrest@mtbr.com
04-27-2005
#57
Tear it all out!
SuperModerator
Anyway, let me know what you think!!!
Lust...
By the time these are out, it may be time to replace the Blur and the Bullit.
Thanks for posting the pics, looking forward to seeing more.
How has your VP Free been working for you?
BTW, how come you aren't joining the rest of the MTBR crew on the FFTF road trip?
04-27-2005
#58
Craig... Dude.. The Free works killer, I friggin love it!
I can't go this weekend man, although I would love it!
Thanks,Forrest
__________________
forrest@mtbr.com
04-27-2005
#59
that is one sweet bike. i wonder how the DHX air will work. have fun on it
04-27-2005
#60
Hey, we need some specs. I want to know Head angle, top tube lenght, bottom bracket height, seat tube angle. If you can or know. I love the welds. Does the design of the top tube seem visually strange when you are riding it or do you not notice?
Thanks, M.C.
04-27-2005
#61
One more Question, How easy is it to flick the bike from one side to the other. With the shock being so high I would think it wouldnt be that great, but your the one with the bike.
Thanks, M.C.
04-28-2005
#62
MC... I don't have all the specs but the HT is 67.5 with..
a 2.4 Mutano Raptor in the rear and a 2.3 weirwolf in the front. TT is 22.5, but I will measure again. Not sure of BB and ST, I will measure today. I didn't notice the TT when pedaling around my court.
Thanks, M.C.
__________________
forrest@mtbr.com
04-28-2005
#63
Damn Forrest you are such a rockstar. That bike looks awsome! You always have the best toys.
04-28-2005
#64
Sick
SICK! That thing looks SO good, and no doubt it will ride awesome!
04-28-2005
#65
swwwwwwwwwwwwwwweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeet! haha, this bike sure is getting a lot of attention! it is prurdy though.
04-28-2005
#66
Forrest bike drove me crazy
hey guys , right now i'm puzzle ...my little drama; last year i was looking out for new trail bike, i was tired of heavy IH SGS expert harsh suspension feeling , my choice was FOES INFERNO (with titanium coil , floating brake), after 5 month in waiting it will arrive next week here in Brazil ...but after i had read some MTBR foruns i realized that VPP design is the best to kind of rides i do( very technical rocky downhill) then comes Forrest bike , 5 pound lighter than inferno , stunning sexy machine ...i gonna to let INFERNO frame in the store to sell, save all money as i can ( no sashimis,no party , no new surfboard ever good weed) to a buy a NOMAD and wait another 5 month of course  , it's my dream come true bike!!!!!
04-28-2005
#67
Sweet bike Forest!!!!
we regular folk, aren't suppose to see those in production till fall right? anyone heard? I've been meaning to ask our rep just haven't thought about it while I was on the phone with him.
04-28-2005
#68
Youngbuck
Thats a sweet bike. Would it be good for 4X? Maybe take off that triple and put on two ring with bashguard? I think the hyrdoformed tubing looks sweet,especially in that colour
__________________
Honorary Member of the: 500 club
04-28-2005
#69
MORE PHOTOS of the NOMAD!!!!!
We took about 10 more photos for you folks... Let me know what you think...
Thanks,forrest
__________________
forrest@mtbr.com
04-28-2005
#70
More photos...
Here you go...
__________________
forrest@mtbr.com
Reason: retard
04-28-2005
#71
More....
More....
__________________
forrest@mtbr.com
04-28-2005
#72
photos are sick man!
04-28-2005
#73
/dev/null
Your fisheye lens makes my eyes hurt but the frame looks awesome! Some bizarrely large welds on that rear end near the linkage, though.
04-28-2005
#74
Forrest thanks for that last pic on the non-drive dropout. that Nomad is full of nice design details. the folks at SCB should be proud.
04-28-2005
#75
Angles Etc....
Head angle 67.5, Wheelbase 43.5, Top Tube 22.5, BB height 13.5.... Everything seems pretty darn cool! Can't wait to ride it!
__________________
forrest@mtbr.com
04-28-2005
#76
JM soon?
Hey Forrest,
When will you be testing that at JM?? I'd like to check it out sometime...
Let's ride.
Rolfe
ps congrats on the sea otter dh, you were flying....
04-28-2005
#77
Those welds may be due to the fact that this is a....
Prototype frame...
Here is a photo of Mark Weir's, he has taken it on a few spins already!!!
Thanks,Forrest
__________________
forrest@mtbr.com
Reason: retard
04-28-2005
#78
how did u get 1 so quick? does the top tube become a bugger with the man marbles ? looks like a great spot to park them for a milisecond of pain
04-28-2005
#79
Rolfe, I should be good to ride next week dude... My..
Ankle is healing fast!
Thanks for the note on Sea Otter, I had a really good time down there but a bad run  ... No worries though, next year!
Thanks,Forrest
Originally Posted by Katana
Hey Forrest,
Let's ride.
Rolfe
__________________
forrest@mtbr.com
04-28-2005
#80
Top tube...
I don't think so man, it doesn't feel any higher than a regular top tube. think it just looks like that because of the shape. I'm not sure why I got one so soon, I have some good buddies at SC.
__________________
forrest@mtbr.com
04-28-2005
#81
Ultimate Poseur
Size
I don't recall you stating what size frame this is? Based on the TT# I'd say it's a "medium" correct? Might be a little slack for the riding I do...but I still want one. SC=Hammer hit nail on head.
04-28-2005
#82
It is a medium....
You could make the headangle change with a twist of a knob on the 36... The TALAS travel adjuster on the 36 works really well..
Thanks,Forrest
__________________
forrest@mtbr.com
04-28-2005
#83
Hey Forrest,
When will you be testing that at JM?? ....
Never evidently. I was considering it initially as my next frame, but the BB height is too low (and the wait too long obviously). I've been riding a 6" travel frame with a 13.3" BB, this is already a damn-low BB for that much travel and I have to be carefull to not bang my pedals on rocks, but 13.5 for 6.5" of travel is just too low. I was expecting more like 13.75-14" or so, given the travel. I don't want an excessively high BB, but 13.5 is too low IMO for that much travel. That top tube is a little short for me as well. I can see where the bike is short, it's in the front end. The 43.5" wheelbase is a little short for my tastes (I prefer around 43.75-44, and with the short top tube, I'd bet that it has ~16.75" chainstays. The shorter front end is probably what keeps it from being more like a 44" wheelbase.
Not dissing the bike, but I'm very particular when it comes to geometry, so take it with a grain of salt. It looks like an impressive bike and I'll try to bum one off someone in the future for a little ride. Nice to see SC filling the "gap".
__________________
04-29-2005
#84
Thanks, Forrest
Pedals, please?
Looking for some decent flats...
04-29-2005
#85
Nobody noticed I guess........
- Weir's bike has an 8 inch rotor on the back.
I remember that question being asked quite a bit.....
Sooooper slick rig Forrest, enjoy!
04-29-2005
#86
allmost banished
Before any moron asks, "why is there a suspension seatpost on a full suspension bike?", it's a gravity dropper seatpost. You can raise or drop the saddle 3 inches, on the fly. They kick ass!
__________________
04-29-2005
#87
Xtremely Moderate
My wife wants one.........I can't imagine why?
__________________
04-29-2005
#88
allmost banished
Because she won't have a saddle attached to the end?
__________________
04-29-2005
#89
Xtremely Moderate
Dammit! I knew there was a motive..........
__________________
04-29-2005
#90
Correction BB Height is 13.7.....
Originally Posted by C88
Pedals, please?
__________________
forrest@mtbr.com
04-29-2005
#91
Truvativ Flats dude... They are killer!
thanks,
Pedals, please?
__________________
forrest@mtbr.com
04-29-2005
#92
very sick, but can you not get black zip ties? otherwise orgasmic.
04-29-2005
#93
Got Doubles? Pun Intended
That bike is fugly.
I'll keep my Intense 5.5.
Did Santa Cruz just hire some newbie kid designer who just graduated from the Design Center???
It reminds me of those concept drawings that never make it to production.
Some one was high on crack when they gave the "green light" to produce that bike.
__________________
Originally Posted by Pamela Anderson
"Freeriderizzle is soo haut right now"
04-29-2005
#94
Only had white...
sucks.
__________________
forrest@mtbr.com
04-30-2005
#95
Porn.
I get a chubby every time I look at those photos.
04-30-2005
#96
Note that only the 50mm version looks like that. All others have a more or less rounded body between the clamps.
04-30-2005
#97
Originally Posted by freeriderizzle
That bike is fugly.
It's just a bike buddy, calm down. The frame follows the same looks as the v10, and I think it looks good with the rest of their line up. If you don't like it, don't buy it.
04-30-2005
#98
I Know It's Only Rock'n Roll ...[/
because i like it!!! i will buy one
04-30-2005
#99
That's the spirt!
04-30-2005
#100
ewww...
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
Photo Caption Contest
(sponsored by Maxxis)
Enter here
