I recently purchased a Specialized Hardrock MTB (26") as I'm getting into cycling. I do ride on trails frequently but also do a lot of road traveling as well (riding to the trails, the store, etc.).
I've seen lots of different bar end/drop bar/other extensions for the handlebars/grips that make things for comfortable and useful depending on the situation. My grips currently are closed-end, so I'd also like a suggestion of what grips to purchase as well.
While a few guys still sport the bar ends, they really went out with the hoola-hoop, and for a few solid reasons...
- They add weight
- They hook vines, trees, etc.
- They put your hands in a pretty awkward position for riding, handling, etc. Okay for climbing, I guess.. but terrible for anything other than just cruising along.
My suggestion would be to go without for a while. For anything (!) technical, I keep my hands at the end of the bar. But, on long flats, or long moderate climbs (like FS roads, etc.), I'll put my hands close in - near the stem, or even put my forearms on the bar and pretend I'm on a TT bike ;-)
I like that grip on for road riding and some fireroad. I don't like it that much on single track because what make that grip so awesome on the road riding is the flat part of the grip, it's so damn comfortable and the integrated bar end even better. That said, on the singletrack descend or tech climb I need to reposition the grip for better control, fix position grip does not do well.
Tree hooking is not so much a concern because I ride with wider bars anyways but once even without the bar end I hooked myself at the end of my bar and went down, it's not something you want to remember.
My fore arms are usually so sweaty on a climb that they just slide off. I have small nubs on my grips that are kind of like tiny bar ends there's just enough to to rest the heal of my hand on.
Could get some large ones like these https://www.google.com/shopping/pro...7&ei=puLzU_rcOsWZyAT3mIIo&ved=0CP4BEKkrMAk4FA that offer even more hand positions and hook back far enough that catching stuff on trail isn't much of an issue. If anything they protect your hands. Then you could wrap them with squishy, grippy bar tape like road bikes get.
I say if you like em and use em don't care about what people have to say about em.
For grips lock-on odi rogue are my favs.
While bar ends are out of fashion they are still useful in my opinion. As stated above they are best for increased leverage while climbing, they also provide an alternative hand position during long climbs which I really like. I use the stubby straight end or one with a slight bend. You can easily find a very light set that will add mere ounces to your bike. Plus they are really cheap so you can try it and toss them if they don't work for you.
I just switched to ergon gs3 carbon and they are nice and also lightweight. One thing that was a little strange at first was the smooth surface of the bar end compared to rubberized, i got used to it though and now almost prefer it. They make the same one 50 g heavier with rubber grip.
I have tried to not use bar ends and always put them back on after 3-4 rides. They give me another hand position to relieve pressure, opens my chest up, and i can leverage the bar more on the tough mashing portion of a hill. That said, i only use a two finger barend. Short and stubby is my preference and entirely essential for my comfort. I currently have the Ergon GP2 and GS2 on different bikes and like them both. My commuter has some ESI Chunky grips with Titec Micro ends that i took a pipe cutter to and shortened to around 1 1/2-2 finger length.
I like bar ends, I've used them for years. I couldn't care less if they are fashionable or not.
If you are riding off road they are a waste of space, you'll never use them. Riding on road they are good for two reasons. Great for climbing and to give your hands and back a different position on long runs.
I've got long bar ends,
like this:
And I've got both the handlebars and the bar ends covered in foam like this:
It's very cheap on eBay and very comfortable. Totally happy with it.
Oh, another thing. I have my bar ends mounted the wrong way round/upside down! That way the end curves away from you. It is more comfortable when you rest your hands on top of them and easier to hold when you are pulling on them.
I have bar ends on my 2013 Marin Rift Zone XC8. It looks funny, but I like the different hand positions and I use them on almost every off road climb. I also use them to hook my fore arms through to get low on the flats and riding against the wind. Nobody I ride with uses them, they are much younger than I am.......
When I was using bar end I like either stubby kind or ergonomic kind like the CaneCreek. That said, the most comfortable ones has got to be the big a$$ one like the Rosie.
They explain a torque limit to keep from cracking them, but then they still rotate on the bar. ...and sometimes still crack anyway. They shoulda just made them from aluminum.
If you want new grips, the Ergon with the small end are probably nice. I use the round Ergon's but really wish they made a round grip with bar end, or at least made the end compatible. Since I use my mtb for many uses (kids trailer, errands, leisure, mtb) it would be nice to have that extra hand position for times when I am on the road.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
