I have the current generation XT disc brakes. I bought them as a pre bled set up.
The front brake feels fine.
The rear brake has an inconsistent feel to it. When I first use the brake it is fine. But with repeated lever pulls on sustained downhill the lever pull is short and engages early in the lever pull.
I have a set of M785 with Goodridge braided lines and ice tech rotors and finned pads that do the same thing. The front brake seems to stiffen up just a tiny bit on long downhills - it's barely noticeable. The rear brake seems to do it a little bit more. I recently re-bled the rear brake and got the exact same lever travel and feel as before.
I'm wondering if it's just fluid expansion from the heat. The rear line is about 2x as long and therefore has 2x the fluid and would expand more.
I don't think it's anything to worry about. As long as your pads don't drag the brakes return to their normal feel quickly after the downhill is over.
Mine do this when the pads are about half gone. Two sets, same quirk, quite a few pads at this point. Try a new set of pads, or a bleed, or both. Annoying feature with the XT's.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
