As long as the grips end up where you want it don't matter, althou stem length as measured from center of steerer tube to center of handlebars, regardless of rise, will effect steering speed. So if you're going with more rise you need more length to get the same distance from steerer to bars.
Bar width will also effect steering speed, and the more difference there is between bar width and shoulder width, the more it effects reach.
Might wanna try some spacers under your current stem first, if there's room.
Riser bars will allow you some adjustment by rotating them. The greater the rise, the greater the amount of adjustment. Sweep, and the more you have may limit that.
With a stem all you can do is flip it.
Riser bars will allow you some adjustment by rotating them. The greater the rise, the greater the amount of adjustment. Sweep, and the more you have may limit that....
Sweep can be more important to your wrist comfort than you think and is hard to get with a flat bar. You also get tilt up maybe 4-5 degrees besides the 6-12 degrees of sweep back and the 15-25mm or more of rise.
This is all true. One advantage I've found with risers is that I can flip the bike upside-down and the ends of both grips touch the ground instead of the bike rocking on the stem. That said, I currently have flat bars (On-One Fleegle w/ 15° sweep) on both of my MTBs.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
