Thanks for the responses. The bike is pretty much the same bike as the one in the picture, with different pedals, tires, fork, handlebars, saddle, stem, grips, and rims. Nothing fancy or expensive - just really basic parts, some of which I purchased new, others of which I took off other bikes.
I have a 32t and a 22t up front - it looks like I have only 1 in the picture. I was going to start with the 22t and then switch to the 32t later after I get a little stronger, but is that even necessary? From what I understand, singlespeeds are more efficient, so its easier to pedal....right? I also have a 24t and a 36t I can use up front.
I'm assuming the tensioner is necessary? At first I was thinking I could do without one, but it seems like the conversion won't go so well if I don't.
On a related note, is a singlespeed chain required, or will any chain work? I've had some bad experiences with chains breaking on that bike, because of me screwing up the installation after the chain break - yes, I'm a pretty bad mechanic, even on basic things like breaking and putting back together a chain. :madman:
I was hoping ideally to get a chain with a masterlink, but I've read that they don't always ride smoothly. Suggestions on which chain to buy? The one I have is probably toast.
Anything else I need to know?
