I installed Juicy 3.5's today, all is good except that the Levers move too much before actually braking.
When I squeeze on the levers, I need to squeeze them a full 1 inch until they actually start braking, then from there it only takes about 4mm to go from light braking to 100% braking.
The caliper moves very slowly during that 1 inch, then moves fast during the last 4mm.
Is this normal?
Or will they self adjust over time?
My hydraulic rim brakes (Magura's) had an adjustment to adjust the play. Do the Juicy Brakes have a similar adjustment? I see various Allen bolts but not sure what they all do.
I know of the 2mm allen screw below the base of the Lever, but that just adjusts the angle of the lever from the handlebars, it doesn't adjust the "Play".
Is this normal?
