Home | Forums
advanced search
NOW OPEN 2009 Virtual Tradeshow Booths: BH, Chumba Racing, Diamondback, Edge, Ellsworth, Ergon, Felt, Formula, Fox Racing Shox, Fuji, Giro/Easton/Blackburn, Gu Energy, Ibis, Jamis, KHS, Kona, Knolly, Look , Lupine Lighting, Motobecane, Norco, Panaracer, Park Tool, Pedro's, Pivot Cycles , Race Face , Ritchey Design, Santa Cruz, SRAM , Syncros, True Precision, Turner, WTB , X-Fusion
Go Back   Mtbr.com Forums > Mountain Bike Manufacturer Forums > Intense
User Name
Password
Register FAQ Members List Calendar Mark Forums Read
Reply
Forum Jump:
Thread Tools Display Modes
Old 11-05-2008   #1
mr intense
mr intense's Avatar
Tracer vp with HammerSchmidt
I have to say that the HammerSchmidt caught us a little off guard and had already finalized the Tracer and started production when I was fully introduced to it at Eurobike.
So here we are and I had to make up a proto with machined in ISCG 05 mount to try it out. The fact that we have gotten lots of requests for compatability also has us looking at it. There were also performance concerns not only with the HS but how well it would work with different suspension systems as it relies on a 22 or 24 tooth ring only.I personally wasn't concered with this as the new Generation VPP on the Tracer has much better small middle ring performance and relies less on anti-squat to isolate the low frequency input ( pedal bob). First rding impressions " Me Likey" will give better report after more time and some others take it for a good trashing.
mr intense is offline   Reply With Quote
Old 11-05-2008   #2
rkj__
rkj__'s Avatar
the thing is so small. it looks like you could bash the FRAME when going over an obstacle.
rkj__ is offline   Reply With Quote
Old 11-05-2008   #3
tkblazer
tkblazer's Avatar
how much of a weight difference is it between the HS and running a standard crank/derailluer setup? i would also wonder about rock strikes on the lower link as well..
tkblazer is offline   Reply With Quote
Old 11-05-2008   #4
rkj__
rkj__'s Avatar
http://reviews.mtbr.com/blog/truvati...-pro-review/5/
Old 11-05-2008   #5
kntr
kntr's Avatar
Why didnt you route the cable up the top of the downtube with the other cables?
__________________
951
Originally Posted by boogenman
I'm waiting for chubby, balding and stupid to come into style so I fit in better.
kntr is offline   Reply With Quote
Old 11-05-2008   #6
gravityfreaky
Is it just me or does the right hand (Hammeschmidt) side crank now sit our way further from the frame than a normal crank?
gravityfreaky is offline   Reply With Quote
Old 11-05-2008   #7
Blaster1200
Old school BMXer
Blaster1200's Avatar
Mr Intense, thank you for answering a very popular question.
It's also interesting to note that you're using a flush lower pivot pin (no circlip). Was this needed for the HS, or was it a general "want" to stop the chain from contacting the pin?
At what point will the Tracer have ISCG tabs?
Although it's probably been answered a million times in other threads (and I'm too lazy to look), and I'm sure current Tracer owners may want to know, but can you use the bottom bracket mount ISCG adapters with the HS?
Blaster1200 is offline   Reply With Quote
Old 11-05-2008   #8
mr intense
mr intense's Avatar
We are considering adding it to Tracer & it will be on the new Uzzi of coarse.
The Behind the bb mounts will not work with HS as there is too much force through the mounting back plate of the HS.We would use the machined in ISCG tabs as the HS requires the tabs be perfectly true to the face of the BB and there is too much warpage with welded on tabs.
We made a running change to the flush bolt on all tracers.
Old 11-05-2008   #9
Black RONIN
Black RONIN's Avatar
After reading this thread, I had to voice my very thoughts.
Sorry if it's a common place for you all Intense owners and riders, but for me, it's just amazingly wonderful to have such a close relationship with the company that makes you bike. That's becoming very rare.
So, Mr. Intense, thank you so much for showing me how good is to have the company's main guy closer to the costumers, and how much I appreciate for you to be such an open person to suggentions and for all the respect you have to all the inputs coming from your costumers and riders. This is honorable and that makes all the difference, be sure of that.
In fact, that makes such a difference. that it's the reason alone I'll be buying my first Intense, and heck, it will be the Tracer. I was amazed by the new Tracer, but wasn't 100% sure of which bike go for, the BLT2 or the Tracer, but now I'm pretty damn sure.
Black RONIN is offline   Reply With Quote
Old 11-05-2008   #10
KRob
Shiitake Mushrooms!
KRob's Avatar
Good move Mr. Intense. I think that making the hammerschmidt available as an option on the Tracer by adding iscg 05 tabs will be a great addition.
You mentioned how having the 22 or 24t ring be the primary gear may have been a concern with the v.1 VPP but not on the v.2. I aggree. I could not detect any chain induced pedal feedback on the Tracer I rode.... and even preferred to keep it in the small ring for climbing (that certainly is not the case with my 6.6). I think this is important for the success of the HS on the Tracer as you do feel a bit of drag when in the multiplier cog (34/36).
I applaud your being sensitive and responsive to customer's input and evolving component technology.
KRob is online now   Reply With Quote
Old 11-06-2008   #11
TheNewOriginal
Goes to 11
TheNewOriginal's Avatar
Thanks, looks great !
but still the question remains regarding how well it would work with the classic VPP designs. I would specifically like to hear the expert's opinion on having the 24T Hammerschnitzel on the Slopestyle.
Thanks !
__________________
Roads? Where we're going we don't need roads..
TheNewOriginal is offline   Reply With Quote
Old 11-06-2008   #12
Blaster1200
Old school BMXer
Thanks !
As a SlopeStyle owner, I can tell you that you never want to apply power from a 22 or 24. The suspension feedback is not good. Sitting and climbing in granny is not a problem, but applying torque really makes the suspension move.
However, I did the same test as above on a Tracer, and I was very impressed of the lack of feedback.
HS on SS = not good
HS on Tracer = good
Old 11-06-2008   #13
tkblazer
tkblazer's Avatar
Originally Posted by .downhillfaster.
Sorry to take this OT, but what Intense tires are those? They look nice. That's a brand I have never tried because I have heard they don't react well to Stans. Is that true?
they look like the system 4, not a bad tire but does not shed mud at all... i found out last weekend on a downhill trail
Old 11-06-2008   #14
CoyoteRun
CoyoteRun's Avatar
Intense Tire System 4.
CoyoteRun is offline   Reply With Quote
Old 11-06-2008   #15
CoyoteRun
CoyoteRun's Avatar
So in short, will the ISCG05 be added to Tracer as Production for sure, or it is still in Proto phase? If it is going to be in the production, when will it be available to the public?
Thanks,
Old 11-06-2008   #16
TracerVP
Too old to jump
TracerVP's Avatar
Caution;  Merge;  Workers Ahead! Frame on order, must stop immediately
OMG, I will stop an order for my frame right now if this is truly a production possiblity. I have a frame that is due Dec. 1st with a CCDB that I'm planning to put an SLX double mech on the front. It broke my heart that the Tracer didn't have ISCG and therefore no Hammerschmidt when I was ordering the frame.
Mr. Intense, when can this possibly be available because I need to change plans immediately if so!
I know that you have a lot of proto to do but I will wait to be part of the drive train revolution!
'sorry, screwed up the reply location in the thread'
TracerVP is offline   Reply With Quote
Old 11-06-2008   #17
jonny427
Botox User
o0o0! Competitivecyclist just got my frame in on Monday... when did this running change take place? If mine shipped out before, can I just order the flush bolt now and install it myself when the bike arrives next week?
jonny427 is offline   Reply With Quote
Old 11-06-2008   #18
boogenman
boogenman's Avatar
Great to see this kind of thing shown to us consumers. It sure makes me want to go out and brag to my riding buddies that Intense is on the ball with listening to thier consumers wants and needs.
I'm glad I got my M6 last june and I sire will be replacing the rest of my rides with new Intense frames
boogenman is online now   Reply With Quote
Old 11-06-2008   #19
TracerVP
Too old to jump
TracerVP's Avatar
Just got off the phone with my LBS talking with Intense. Looks like at least 6 months to a year for testing and proto before we'll see Tracers with ISCG tabs if at all.
Sorry for the panic attack a few posts ago. I'm glad I like the looks of that SLX double setup!
Old 02-25-2009   #20
Evil Sylvain
How's that project coming along?
Evil Sylvain is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump:
Photo Caption Contest
Enter here
Latest Articles and Reviews:
Quick Poll
(sponsored by Moots)
If buying a new bike this year, will it be a:
26” XC/AM trail bike
29” XC/AM trail bike
freeride bike
downhill bike
road bike
Copyright ©1996-2008 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda
