As you might have seen from some of my posts I have been making the bar mounts on my lights in the hope that they will use the bars for a bit of heat removal.
so I thought I would take it a bit further with a housing for the cree mc e led when it becomes available
here is the idea for my light .
this will also keep it out of the way when turning the bike over to fix a flat.
So with this design where do I put the driver to keep it as small as possible
I am not sure which optic to use either the 20mm or 26.6 mm
if I used the 20 mm then I could put 2 mc e`s side by side in the aluminium I have
but I figured the larger 26.6mm optic may be the best for the leds and would make a smaller light.
any ideas please
any ideas please
