Home | Forums
advanced search
Go Back   Mountain Bike Forums > Mountain Bike Manufacturer Forums > Knolly
User Name
Password
Register FAQ Members List Calendar Mark Forums Read
Reply
Forum Jump:
Thread Tools Display Modes
Old 11-13-2007   #1
dulyebr
htfu member
dulyebr's Avatar
Idea! Knolly Fork and Rear Shock Settings Thread
shock: 2008 Fox Rp23
rider weight: 185lbs
frame size: Med
psi main:150
psi boost: n/a
coil lbs: n/a
settings/comments: generally prefer level 1 propedal for most trail riding.
dulyebr is offline   Reply With Quote
Old 02-26-2008   #2
All Mountain
  • shock: 2008 Fox RP23
  • rider weight: 220 lbs
  • frame size: M
  • psi main: 180
  • psi boost: n/a
  • coil lbs: n/a
  • settings/comments: propedal off, 3 on the road
  • shock: 2008 Marzocchi Roco TST Air
  • frame size: M
  • psi main: 120
  • psi boost: 180
  • coil lbs: n/a
  • settings/comments: TST off for most trail riding, 1-2 clicks on some smooth climbs and road
All Mountain is offline   Reply With Quote
Old 02-26-2008   #3
sikocycles
sikocycles's Avatar
rider weight: 250lbs.
frame size: XL
psi main:250
psi boost: n/a
coil lbs: n/a
P.S. Got to lose weight.
__________________
PBJ in my Lunchbox
http://wagonwheeldh.blogspot.com/
sikocycles is offline   Reply With Quote
Old 02-27-2008   #4
LAKESNAKE
shock: 2007 Fox DHX 5.0
rider weight: 145lbs
frame size: Med
psi main:145
psi boost: 100
LAKESNAKE is offline   Reply With Quote
Old 03-01-2008   #5
BryanS.
  • shock: 2008 DHX Air
  • rider weight: 205 lbs
  • frame size: L
  • psi main: 200
  • psi boost: 150
settings/comments: propedal off most of the time, 1 on non-technical climbs and the road
BryanS. is offline   Reply With Quote
Old 08-31-2008   #6
bikesinmud
bikesinmud's Avatar
shock-CCDB 400lb steel spring
Rider-185-190lbs
Frame size-L
30% sag
LSC-15 clicks out
HSC-3 turns out
LSR-13 clicks out
HSR-3 turns out
bikesinmud is offline   Reply With Quote
Old 09-07-2008   #7
TIGMAN
T , V , & K Rider
TIGMAN's Avatar
Shock : 08 Fox RP23
Rider : 6' 3" and 220 lbs ( without gear )
Frame : XL Endorphin
psi main : 200 average ( range from 190 to about 210 )
Don' t feel the need to use the propedal much !
Would like to send it to PUSH Ind. for a personal tune and rebuild this winter...........however , very pleased with the setup for tech xc use ! Even though I use it as a light playbike too..........I can't resist ( Ooh man , I dig this bike ) ! TIG.
TIGMAN is offline   Reply With Quote
Old 09-07-2008   #8
dulyebr
htfu member
dulyebr's Avatar
I have to edit mine profile slightly.
Coming from a Titus MotoLite, the Endorphin felt too plush so I started off using propedal. After I got used to the bike, I went for a long time leaving the propedal off. Then I started riding with a pretty fast group where any advantaged on the climbs was welcome. Now I climb anything smooth in level I mode. A little propedal really helps control bob and keeps me a little higher in the travel, which steepens the geometry slightly.
Old 09-08-2008   #9
GaryM
shock: 2008 Fox DHXC
rider weight: ~200lbs geared up
frame size: Med
psi main:n/a
psi boost: 150psi
coil lbs: 450
Started with a 400lb spring but found it a tad soft causing the bike to ride low in it's travel and feel a bit sluggish. Switched to 450 and it feels great. I don't use any propedal even on long fireroad climbs and get very little movement. The shock will either be going to push this winter to remove all the platform or it will be replaced by a ccdb...most of our climbs are very technical and I would rather gain the smoothness and more active feel by eliminating the platform entirely.
GaryM is offline   Reply With Quote
Old 09-14-2008   #10
john85D
rider weight: 145lbs w/ gear
frame size: Small
psi main:95psi
psi boost: n/a
coil lbs: n/a
Propedal 1 for most trail riding, and off for downhill runs!
One thing that's strange is the low air pressure I am running. Actually I'm only getting 14mm of sag with this air pressure. But so far it looks good, no bob in propedal 1 and minimal bob in the off position.
john85D is offline   Reply With Quote
Old 09-15-2008   #11
hjb117
Hey john85,do you have good small bump compliance?if yes what's your rebound setting?
hjb117 is offline   Reply With Quote
Old 09-16-2008   #12
john85D
Small bump compliance is actually good, rebound is 3 clicks in from full open.
Old 09-30-2008   #13
Shonky
Shock: 2008 Marzocchi Roco TST Air
Rider weight: 165 lbs
Frame size: S
PSI main: 95
PSI boost: 170
Coil lbs: n/a
Settings/comments: TST off unless climbing. I've also had the compression damping opened up a little as I find the Roco TST shocks a little spiky.
Shonky is offline   Reply With Quote
Old 07-17-2009   #14
All Mountain
an update....
Frame: Endorphin
Rider: 220 lbs
Shock: Cane Creek Double Barrel
psi main: n/a
psi boost: n/a
coil lbs: 450
preload: 2 turns
compression: high speed - 0.75 turn, low speed - 8 clinks
rebound: high speed - 0.75 turn, low speed - 10 clicks
settings/comments: All clicks/turns from full out. Best shock I've used so far. Really like the oil flow at speeds and the ability to adjust low and high speed tuning. Only two rides so still tuning!
Fork: 2009 Fox 36 Talas RC2
psi main: 72
coil lbs: n/a
compression: hsc - 2 clicks, lsc - 2 clinks
rebound: 5 clicks (i forgot so all update this later)
settings/comments: All clicks from full out. Use 160 travel for most riding.
Old 11-19-2009   #15
Lev
You Guys Riding?
Lev's Avatar
Bump on this thread...
rider weight: 185lbs (without gear)
frame size: Med
psi main:165
psi boost: n/a
coil lbs: n/a
Curious what others are doing...
Lyrik setups welcome as well!
Lev is offline   Reply With Quote
Old 11-20-2009   #16
jitenshakun
shh. don't tell the wife
shock: 2009 Fox DHX 5.0
rider weight: 205 lbs (without gear)
frame: Delirium T
frame size: Large
psi main:n/a
psi boost: 160
coil lbs: 500
Fork: Lyrik Coil u-turn
spring: stiff
high speed compression dampening: 5 clicks
low speed compression dampening: 2 clicks
rebound dampening: 10 clicks
__________________
All you need is love... but Scotch'll do in a pinch.
jitenshakun is offline   Reply With Quote
Old 11-20-2009   #17
Dominator13
NorCal to Idaho!!!
Dominator13's Avatar
It's funny...
that this thread popped up this morning. I was just telling Dude! that I had turned the best shock into the worst shock by screwing up the settings for "jumping". I had tried to set my CCDB up with a lot less HSC and a lot more LSC and it turned it into a shock that doesn't even compare to any top of the line shock out there. I, quickly, changed them back to the proper settings.
Med. DT
180 lbs. w/ gear
CCDB - Ti 350lb Spring
35% Sag
LSC 14 clicks
HSC 4 - 1/4 Turns
LSR 14 clicks
HSR 2 - 1/4 Turns
__________________
[SIZE="2"]"You don't stop playing because you get old, you get old because you stop playing!" - Unigeezer [/SIZE]
Dominator13 is offline   Reply With Quote
Old 11-23-2009   #18
LAKESNAKE
Update after 2 years on the Endorphin.
Marz ROCO TST coil
Rider 139#
spring: 300# Ti
boost pressure 200 PSI
Shock modification:
removed 2 largest compression and rebound shims from main piston stack.
Removed TST valve plate (washer, not a shim) and replaced with 2 large shims previously removed from main piston assembly. This mod loses the 90% of TST function at full lockout, but man is it smooooth. I was expecting the mod to only remove high speed spiking, but it has a dramatic effect at low speeds as well (climbing square edged chunk).
The stock TST works well as advertised, but I have no use for TST in Austin anyway. A good compromise for my application.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump:
Photo Caption Contest
Enter here
Latest Articles and Reviews:
Quick Poll
What's your drivetrain on your main bike?
Classic 3x9
2x9
1x9
1x1 aka singlespeed
Hot Forum Topics:
(Week of 9/7)
Top User Reviews:
Copyright ©1996-2010 All Rights Reserved.ConsumerREVIEW.com, a business unit of Invenda
