NOW OPEN 2009 Virtual Tradeshow Booths:
BH,
Chumba Racing,
Diamondback,
Edge,
Ellsworth,
Ergon,
Felt,
Formula,
Fox Racing Shox,
Fuji,
Giro/Easton/Blackburn,
Gu Energy,
Ibis,
Jamis,
KHS,
Kona,
Knolly,
Look ,
Lupine Lighting,
Motobecane,
Norco,
Panaracer,
Park Tool,
Pedro's,
Pivot Cycles ,
Race Face ,
Ritchey Design,
Santa Cruz,
SRAM ,
Syncros,
True Precision,
Turner,
WTB ,
X-Fusion
12-22-2006
#1
the lighter the better;)
TOKEN Carbon Fork: 447g
i also got some sweet TOKEN carbon forks today. just last week i presented the Ritchey Carbon fork in detail:
http://forums.mtbr.com/showthread.php?t=252695
now it's the almost identical Token. "almost" because the Token i have here is Disc-only and the Ritchey was Disc/V-brake. other than that the forks are 100% identical. but the Token is lighter
weight of the disc-only version with uncut 300mm steerer: 447g
shortened to 175mm: 407,7g
lenght: 41cm
max. tire width: 60mm
original Expander: 25g
i already did a 1,5 hour ride today but a comparison to the other "Pace-like" carbon fork i used before is difficult: just over the last 2 days the trails got completely frozen over here in Switzerland! 2 days ago everything was still soft and pretty muddy, but now it's all bonehard and frozen. so a direct comparison is really difficult. only in the few leftover parts where trails weren't completely frozen yet i could compare it and it felt almost similar to the other fork. also having a bit of comfort. but now a meaty front tire would help big time since all irregularities get transerred unfiltered directly into the hands...the 1,8" Nobby Nics don't help much  but i really like the shorter lenght and little weight. this was felt immediately. the steering became alive! what a difference to the 440mm long fork it replaced. the bike now feels nimble and reacts very instantly to every input. it almost feels as light as my Scale which i also ride with a shortish 63mm SID. i really like "nervous", lively steering bikes. i also liked the lower handlebar position and will have to correct the saddle position as well since seat angle was changed as well.
anyway - i finally bought a lighter fork as well so once again i should have followed my rule: always invest in the best possible right away rather than spend twice the money when you have to upgrade later...
my winterbike now sits at 7,68 kilo / 15,4 lbs - not bad considering the many used taiwan parts
__________________
ATTENTION - i may be showing you an item i sell, my comments may be biased because of this
12-22-2006
#2
Nice
Nice forks, look a bit like my winwoods, but much cleaner without the crappy v-brake mounts.
__________________
One crowded hour of glorious life is worth an age without a name.
12-22-2006
#3
How much do you weigh?
__________________
Bare Knuckle Brigade
Killing Dreams One At A Time
12-22-2006
#4
i'm 155 lbs.
__________________
12-23-2006
#5
Do you know if they might be making a longer one?
It would be pretty on the front of my 29er single. I need at least 460mm
12-23-2006
#6
Yeah, it would be awesome if Token / Ritchey would do a 29er version. 29ers are where you can actually use rigid forks for racing.
12-23-2006
#7
Time to go farther
Token/Trigon
Are they the same? Who sells the Token in the US and how much?
12-24-2006
#8
Recovering couch patato
That's scary light...and I thought 600g was light for a cyclo-cross fork...
12-24-2006
#9
scary indeed...
not too many years ago 400g was considered light for a road-fork. i remember my Scott carbon fork of 2003 which weighed 350g...
but riding the Token i have to say it feels pretty solid. maybe also because of the shorter legs there seems to be less flex in it than the "pace look-a-like" fork it replaced.
__________________
12-24-2006
#10
Time to go farther
nino
I asked you a question here and sent a PM. Did it go through?
01-14-2007
#11
I just installed one of nino's Token forks. The cut weight is 411 grams (18.5" frame); 419 with Chris King ti base plate. The Wound-up fork previously on the bike weighs 624 grams (with a stainless steel ck base plate).
I like it  .
David
01-14-2007
#12
what a nice bike!!!
I like it  .
David
David,
your bike looks awesome. congratulations!!!
__________________
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
