Right now I am using the stock Debonair and I'm really liking it so far. I do switch between the open and medium compression settings on the Monarch depending how much climbing or descending I am expecting. And I notice that with the compression open the shock feels very plush but maybe moves through the mid-stroke a little quick. No harsh bottoming though.
I have an opportunity to upgrade to a DHX2 and wanted to see if anyone has some feedback or comparison regarding air vs coil on the Patrol.
If you feel like it is moving through mid-stroke too quickly, you can make it more linear by removing the red volume bands from the inside of the outer sleeve (simple to do). You will run a tiny bit more pressure, ride a little higher in the stroke, and of course have a little less small bump sensitivity (since you're not having as much mid-stroke reaction).
IT's a little bit different feel. The adjustability of the Debonair is remarkable, and I'd suggest fiddling around with it some before spending a bunch of money on a new shock.
Having said that, there are some people running coil shocks on the Patrol.
I am really happy with the Carbon Patrol so far. I really wasn't even shopping for another 160ish bike but my buddy found a deal and so we jumped on it.
First impression was that I liked the fit way better than the Nomad. The Patrol is also a lot more of a fun bike, meaning it is easier to pop off trail features and just goof. Funny enough the Patrol also feels better at speed due to the longer reach.
Running an RC4 on mine. Works awesome. A LOT better than the stock RockShox on high frequency stuff. The stock shock does work well overall though, but is never going to be as compliant as a coil no matter what they do with the negative chamber.
400# ti spring for a 185-190# rider yields exactly 35% sag FYI.
I thought about an X2, but they're expensive and honestly not all that proven yet for long term production durability. The damper character is also a LOT more adjustable in compression with the boost valve than the X2 valve which is just a needle/stack with a spring backer. Just missing the one rebound adjustment, which I've found most people can't get set right anyway.
The RC4's are durable enough and easy to find inexpensively. I'm pretty over paying to guinea pig for these suspension companies.
Thanks for the feedback. Pretty set on the DHX2 and got a message from Transition saying that's the coil they would recommend also. I had the X2 on my Nomad for about 6-7 months before I got the Patrol and I really liked it. Never had any issues and really appreciated the ability to fine tune things.
I used the Fox spring calculator and came up with 350lb spring and we're the same weight, curious that you're at 400. I'm planning on trying a couple different spring weights on cheap coils and then I'll pick up a SLS.
I couldn't get along with the Monarch. Moved to an Avy'd fox van; the traction is primo up or down. Just like with any horst link, you have to adjust your pedaling technique when out of the saddle, but it climbs very well in all terrain and conditions. There is one particular situation where I wished I had a "switch" , that being grinding up a medium-steep grade with deep undulating pockets. With a coil and no switch, it eats up a little extra energy, but still very acceptable ride. For the riding that I like to do, the added weight is negated by the gobs of traction and predictability the coil provides.
I have had the 2016 Carbon Patrol for a while now. I ditched the RS Debonair and replaced it with the FOX DHX2 Air. The DHX2 Air I felt has a wider range of tuning for that bike over the Debonair.
The Patrol is a true "do it all bike" that really needs a shock that can handle everything up to high speed hits that I felt the Debonair just could not handle. The DHX2 Air can. I will say though that the tune based off FOX's web site is not for the Patrol and will take a little time to get dialed in right if you know what you are doing.
As for the DHX2 Coil, I had one as well that I will put on the Patrol for big park riding. I am 175lbs and run a 425lb spring. The Coil I found to be a little bit more challenging to tune for the Patrol, but feel after a few more times at the park I will have it dialed like I have my DHX2 Air.
I would say if you are looking to have just one shock that will help the Patrol progress to its true potential, I would go with the DHX2 Air.
Looks good man, I have shelve the desire to put a DHX2 coil on the Patrol. Ended up spending the coil shock money on a shock for another bike.
It is interesting to hear that you had troubles with Debonair on high speed hits. I've had pretty good luck with the shock in those situations. Even in high speed repetitive hits the shock feels good. It's kinda a double edge sword because I like how plush the shock feels, but its seems to blow through the travel too quick. No harsh bottom outs, not crazy bobbing but it just seems like it could use a little more support in the middle to bottom of the travel. The middle compression setting feels too firm for rowdy descents and the open setting is a little too soft most of the time. And now that I have two Debonairs that fit the Patrol (warranty return from another frame) I am considering the Avy treatment for one of them. For the money it'll be hard to beat a custom tune.
I can eventually get an used dhx2 from a friend with a 400# SLS spring and 2pos switch. With gear I have ~170lbs, not really sure bout the spring rate; the mojo spring generator doesn't consider the SAG.
The patrol is my do-it-all bike, but since I'm not really in the long uphill business but more lift/bike park and short home tracks and I guess I won't suffer from the coil disadvantages that much.
Another alternative would be to send in the monarch plus for a tuning (mid valve etc); at the moment I have 4 bands in it and ~ 33%; that's oke for touring but in park and rough terrain the rear feels pretty dead and harsh. Taking out band results in more bottom outs.
Are people running 35% sag also with coil or is it more important to get a spring more suitable to your riding area?
I have no previous experience with coil but found the 350 spring that I have now a bit soft as I needed 4 rounds of preload. A 400 is on its way. Will it make a big difference when it comes to bottom out resistance with a dbcoil? I also have a 500 spring but that gave me around 20% sag which felt strange compared to the Monarch on the Patrol.
I have now gotten more time on my ccdb coil. Running with a 400 spring I do bottom out and feel it a few times when I miscalculate landings on smallish jumps. Other than that I've done some tests on drops and although it moves the bumper down I cannot feel it bottom out. I guess that my spring is a little soft (running 35% sag with two rounds), but it works perfectly if I'm riding smoothly enough. If I'm out of the comfort zone I think 450 might be better but I'm not sure running less sag would be helpful. The Patrol gives so much confidence when running at the recommended sag. Anyone running less sag which care to give their experience with how the bike handles then?
running a 350lb nukeproof SLS spring with my CCDB IL coil on a suppressor. Tried both 30% and 35% and couldn't tell any difference on small to medium hits (never did anything big).
2016 model with the original link - have been running an RC4 and now a DHX2 w/climb switch.
On the RC4 the bike got balanced and came alive with a 425# spring and a more aggressive compression setting. I'm around 185-190#. 450# was too stiff and 400# would wallow and kick up from g-outs unexpectedly.
I'm still playing with rates on the DHX2. The damping seems to kick in more immediately, so I'm on a 400# spring, for now. The X2/425# would deflect and dance around quite a bit more on choppy stuff than the RC4/425# would, which doesn't make sense because there's a lot more gas spring force in the RC4.
I've ridden a couple of the new 2017 links and they feel a bit nicer off the top, but I haven't seen very many commercially available metric coil shocks to complement it yet.
Brief update to my coil shock experimentation on the Patrol (8.5" shock link, not the metric). I tried a DHX2 coil with a climb switch, with a 400 and a 425 spring. Ultimately I ended up selling it. The frame is just still a bit too linear for a shock like that. Seemed to be susceptible to the same problems that the CCDB's always had - locking up on square edges, or blowing through travel, and really not much in between. This is over a couple months of testing. Probably have better luck with the metric link or a frame with a lot more progressive leverage curve.
The RC4 by comparison does very well on this frame, as does the stock Monarch Debonair.
Which do you prefer out of the Scout and the Patrol ?
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.6K members
Since 1990
