Results 1 to 86 of 86
    Reputation: flipnidaho's Avatar
    X-Post: Review of mtnbiker4life's shock bushing tool
    "El Whatever"
    Reputation: Warp's Avatar
    Please post it here directly. Maybe AM will do a sticky out of it... it's pure gold!
    Check my Site
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    yeah...awesome work, Flip!
    The unabridged version....
    If you slightly lift up the saddle of 575 and hear a knocking or looseness kinda noise, make sure all the suspension bolts are tight, your rear wheel's bearings are not loose and your saddle is tight on the seatpost. If the sound and sensation is still there, it's more than likely your shock's bushings.
    Here is what it would sound like (turn up the volume):
    I'm not including the steps to remove the shock from the bike and the dogbone as that was already covered on a different thread.
    Step 1- Gather all the tools you will need. In this case, a bushing tool. This tool is made by mtbr member "mtnbiker4life" and he sells it in the classifieds along with bushings for different manufacturers. It is very well made and I highly recommended it to the DIY crowd! Also shown are the assorted tools needed to remove the shock from the Yeti and it's dogbone linkage.
    Here is a picture of the old bushing prior to removal.
    Step 2- Insert the Ejector Pin through the bushing and slide the bushing guide on the other side with the counter bore facing the shock so as to capture the bushing once it's pressed out by the pin.
    I used a vise to press the bushing out out of the shock eyelet and into the counter bore.
    The bushing presses out pretty easily using the vise.
    Note that the bushing has been pressed out of the shock's eyelet and into the counterbore on the other side.
    Step 3- Installing a new bushing
    Clean the eyelet.
    Lightly grease the pin
    Put the new bushing on the pin
    Lightly grease the bushing
    Place the support foot (the end cap) into the counter bore of the bushing guide (the counter bore will not be directly against the shock during the bushing installation).
    Make sure that the slit in the bushing is facing away from the shock body (or facing the back of the bike).
    Put the tool into the vise and slowly press the new bushing in.
    Halfway in
    Done
    Step 4- Put the shock back on the bike and torque all bolts to spec.
    Test. No more bushing slop
    Total time was 10 minutes to remove the shock and dog bone, 5 minutes to remove and install a new bushing and another 10 minutes to reinstall the dog bone and put the shock back on the bike....
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    This is a great illustration on this tools use. The 12mm bushing tool is now available as seen side-by-side with the 1/2 inch bushing tool.
    Dec 2004
    +1! Another VERY happy user of this tool.
    May contain nuts
    Reputation: Haggis's Avatar
    Got the new black 12mm tool for Manitou shocks. A thing of beauty and a joy forever. Stop messing with sockets and get one.
    Dec 2005
    Quote Originally Posted by Haggis
    Well I did order the 1/2" version, should be here any day, I will comment back once mine comes in as I need to change out the DU's on my Roco.
    Just picked up an Manitou Evolver ISX-6, so I guess I will need the 12mm DU tool for that now or at least down the road when the DU's wear.
    Cheers
    J
    I finally used the bushing tool that I bought from mtnbiker4life some time back.
    A few minutes and I was done. Thank you for making a quality tool that works this well.
    Powered by ice cream.
    Reputation: Enel's Avatar
    Yep, works great. Just the tool for the job.
    Reputation: ScottW's Avatar
    Agreed, great tool. I picked one up a while back but haven't needed to use it yet.
    Reputation: big_mountain_biker's Avatar
    I bought one last week and used it yesterday. It is an awesome tool, very well made and extremely easy to use. Only took about 10-15 minutes to swap out the bushings. The play that was once there is now gone.
    moaaar shimz
    Reputation: tacubaya's Avatar
    Yeah I used it too and it took like 3-4 minutes. Great tool.
    why are you using grease on the bushing?
    That isn't a good idea according to the folks at Romic and my LBS....
    Amphibious Technologies
    Reputation: SCUBAPRO's Avatar
    Quote Originally Posted by Qman
    Agreed. I did that once and dirt got in the bushing and actually decreased life of bushing. Never again. I run them dry and they last much longer.
    "The best you've ridden is the best you know" - Paul Thede, Race Tech
    Quote Originally Posted by SCUBAPRO
    The manufacture of the bushings states these can be run dry or lubricated since the ones I sell have a small percentage of lead which increases lubricity. As stated our application is exposed to the elements so adding anything that will make dirt/sand stick to it would not be good.
    During my testing I ran them lubricated and dry. It did not make a difference. I've even removed them and reinstalled them to do more testing. In my years of testing these on bikes and in pumps here are a few things that can cause premature failure:
    1. Incorrect installation by using the wrong tool
    2. Incorrect placement of the slit
    3. Incorrect installation of pivot/shock hardware
    The only caution to be taken is not to apply to much since the bushing could shift inside the bore but since it's capture by the spacers it will not come out.
    A quote from Garlock Application Guide - Lubrication - Can be used totally dry, fully lubricated, or with intermittent lubrication and can be used in the presence of many industrial liquids.
    "El Whatever"
    Quote Originally Posted by mtnbiker4life
    Actually, the same type of bushing is used on our forks and we use lots of oil in them.
    Check my Site
    No difference; so why not run them dry then?
    I do it so I can take the reducers out easily (don't have a bolt extractor ) to change shocks, work on them, etc
    they get kind of stuck when dry...
    I am currently running them dry due to trail conditions.....dust and sand. Like many parameters in mtn bke set up......test, and document then run what works for your style of riding on the many different trails you ride. Their is no one set answer.....it's all about working within the manufactuers given/stated parameters.
    Reputation: Christ D's Avatar
    I'm waiting for this fine tool to be delivered(Belgium),but what to do with reducers that are very stuck? I just can't get the smallest (Fox shock) out . How do you guy's do this?
    Thx.
    Arrived yesterday and used right away:works very good,everything went smooth.Took about ten minutes to get the bushing's out and new ones in.
    Dec 2008
    Bonking ... not feelin' well X-Post: Review of mtnbiker4life's shock bushing tool
    hi,
    Thx.
    May contain nuts
    Quote Originally Posted by CliffordHayes
    hi,
    Thx.
    If the reducers are firmly seated, then the DU bush doesn't need replacing. When the bush is worn they fall out...
    Oct 2007
    damn its only 25 bucks? i dont even need one and am tempted to buy it at that price
    Dec 2008
    OK I'm going to ditch the socket approach to replacing bushings and get the tool. But I have a question; I have a Fox and typically replace everything: all the spacers/reducers and bushings. It makes things more expensive and takes longer. Plus I tend to avoid the process b/c I don't have all the parts. Should I just be replacing the lower bushing more frequently? Right now I have the "pick up your seat thump."
    Reputation: ebotto's Avatar
    Quote Originally Posted by Slabysz
    In my experience, once you have the "pick up your seat thump", the reducers are worn as well. I would like to know the same thing because I usually don't replace the bushing until it's too late.
    Quote Originally Posted by ebotto
    Yes sir, if you wait to long before changing them those spacers/reducers will wear. If the bearing material has worn off the DU Bushing to a point of creating some wobble then spacers/reducers will be allowed to move inside that bushings. THe worst damage will be seen if you have 8mm mounting bolts because the ID of the bolt hole is larger then if you had a 6mm bolt thus reducing the amount of material in the spacer/reducer....essentially making it weaker. How long will it take to bugger everything up....who knows. I'm typically on top of my sh*t so it has never gone that far. But one of my riding buddies rides her bike until it falls apart....usually on the trail which is a buzz kill.
    Bushing tool
    mtnbiker4life is my hero.
    The last time I needed a DU bushing replaced, I took it to my LBS. They took the shock from me, whipped out their handy flat-head screw driver and hammer and started hacking away. Then they charged me $15. Sure the play was gone, but I swore never to do that again. I usually work on my own bikes, but if I don't have an appropriate tool, I get a little gun shy.
    This bushing tool is amazing. It is so simple and effective, I wish I invented it. I intended to remove the shock and put it in a vise, but the lower mount would not budge. I ended up using a c clamp on the upper bushing while the lower mount was still connected to the bike. The old one came out, and the new one went in with no fuss at all. I put everything back together and the play was gone.
    Thanks mtnbiker4life, I now have one less reason to visit my LBS for maintenance that I can do myself. I think it would be in every do it yourself rider's and every LBS's best interest to own one of your tools.
    Some of us are Hammers, others, just Tools.
    my body breaks the falls
    Reputation: twindaddy's Avatar
    I have to echo the praise here. Received mine yesterday (only three days from order date) and in under ten minutes the job was done. I also want to say that the tool is a demonstration of simple elegance. It looks as good as it works. I love it when members of the community fill a niche like this.
    $500 million for more irresponsible EBRPD land management? No thanks.
    www.noonmeasureww.org
    Chilling out
    Reputation: bear's Avatar
    +1, good stuff.
    for those that don't have a bench vise, a large c-clamp held in place with a tool box on a table, carefully applied, works just as well.
    Reputation: Walt Dizzy's Avatar
    Aug 2003
    Another happy user
    I got my tool today and had the bike back together again in no time. Well worth the price in reduced aggravation.
    Walt
    More Torque
    Reputation: Diesel~'s Avatar
    Got and used my a couple of months ago. Excellent stuff!
    Ridin' dirty!
    Reputation: cdalemaniac's Avatar
    2 up for this tool!
    One of the nicest tools I've purchased in a long time...
    "Common sense isn't always that common!"
    Custom Prophet and Custom Delta V
    Reputation: kompressor's Avatar
    Good job!
    Very well made tool. I deal with special tools in the aircraft industry. This is on par.
    Mtnbiker4life excellent to work with, Buy it
    kompressor
    Boyeeee
    Reputation: BCBlur's Avatar
    +1
    I used mine recently when building up a buddy's used Nomad. Good tool.
    11 is one louder than 10
    Reputation: Green Giant's Avatar
    worth the cash for sure. Just used it, with a hammer - no problems. Great Tool.
    "The thing is, Bob, it's not that I'm lazy, it's that I just don't care."
    Jan 2005
    just used it tonight...tool works great...although mine became all stained up after like 3 minutes, haha
    "He can make even a global summit meeting seem like a kegger." M. Dowd, NY Times, 19 July 2006
    56-year-old teenager
    I just got this tool and wanted to add my compliments to mtnbiker4life. It worked like a champ. I think it's very fairly priced.
    Work is the curse of the biking classes.
    Action Chuck says: Don't waste your time with sockets and trying to make something work. Took mine to work and replaced my bushing on my coffee break...it's that easy. This tool will have a new bushing in your shock in 10 minutes or less with no damage to anything. I ordered mine on a Saturday, got it in my mailbox on Tuesday. $28 bucks to my door, including the bushings. Worth every penny and then some, thanks!
    It worked perfectly on my Fox shock too. Great tool. Below is the eBay link:
    http://shop.ebay.com/mtnbiker4life/m...&_trksid=p3686
    works great
    kompressor
    Another Thumbs up
    Have had this tool for a year and it works great. Had a few bushing push out easy but a few in so tight that the vice left teeth marks in the back of the tool. Was really glad I was using this tool on that occasion.
    I've also used it to push reducers off shock, sealed bearings all reducers. A lot of other uses for this tool when you get 'stuck'.
    Another Satisfied Customer
    Ordered on Tuesday. Received it on Thursday. Took ten minutes to replace bushing. No more play! Yay!
    Reputation: pedaler845's Avatar
    ...During my testing I ran them lubricated and dry. It did not make a difference. I've even removed them and reinstalled them to do more testing. In my years of testing these on bikes and in pumps here are a few things that can cause premature failure:
    Where should the slit go?
    (Seriously-thx)
    Edit:
    After researching I found the slit shouldnt get placed in the shock path.
    Singletrack Slayer
    Reputation: DavidNeiles's Avatar
    Just got it today and it is so nice, Thank you for the coolest tool ever mtnbiker4life ,
    ~~~~~~Singletrack Slayer~~~~~~~
    Reputation: swinefeaster's Avatar
    hey so what's this "pick up your seat thump" ? when i pull up my seat i notice that there is in fact some play on the bottom of my shock --- looks like the part of the shock where the eyelet is can move around a bit on the pivot (not sure if i'm using the correct terms here). do i just need to change the bushings there too or am i kinda screwed at this point and need to do the spaces/reducers ?
    i looked this stuff up to see how to replace the *other* bushing, the one on the top of my fox vanilla shock, which is making clicking noises.
    thanks!
    swine
    Singletrack Slayer
    Sounds like your bushings are toast, you might need new reducers as well. If it just started and you noticed it you might just need the bushings replaced. I was lucky to catch it right away and the org. reducers are fine.
    "I'm not including the steps to remove the shock from the bike and the dogbone as that was already covered on a different thread. "
    could you kindly post a link? i'm at this step and lookin for the info...
    thanks
    ok so i managed to figure it out with the help of another forum... btw this tool is awesome! thanks mtnbiker4life! another happy customer
    so the pick-up-the-seat thump is now gone, but when i first push the seat down there's a click. does that mean my reducers are toast?
    otherwise it is waaaaay smoother than it was prior to the surgery.
    oh and i just realized i didn't pay attention to where the slit was! does this just mean i should change the bushings again sooner? and i'm not quite sure i understand "Make sure that the slit in the bushing is facing away from the shock body (or facing the back of the bike)." - which one? back of the bike or away from the shock body? cause there's 2 bushings one on each end...
    cheers
    swine
    "El Whatever"
    Just to give props to mtnbiker4life!!
    I got his headset press adapter cups and although it requires some fiddling to make them work on the Nashbar press I got, they worked perfectly.
    The fiddling was just to swap the press' parts to get the adapters mounted and it's fault of the Nashbar press design, as the adapters are intended for a Park Tool (or compatible) press. At any rate, even my 5yo kid could figure it out in three seconds and the adapters work perfectly.
    The fit to my CK headset was superb and the adapters made short work (literally) of pressing the cups into the tight headtube that came a bit undersized as intended from factory.
    The adapter are cheap, with a high quality finish and tolerances to them. The kind of tool you enjoy and pride to own.
    It doesn't have the flashing finish of other tools, but it's absolutely functional and of a high quality.
    Service was top notch too. I'll get in the bushing tool and a few other tools down the line.
    Keep up the good work!!
    Check my Site
    Natural body armor
    Reputation: Zen_Turtle's Avatar
    So now I know about the tools, where do I buy reducers and bushings?
    Thx
    ZT
    "There is no A-line"
    Savvy Bike
    today i change the front and rear eyelet on my elka with this tool and the silver eyelet's. that is so easy!! best gadget!
    ride.
    moaaar shimz
    Quote Originally Posted by Warp
    Dude a I machined my own headset press at school, it will install 1 inch, 1.125 and 1.5 inch cups!!! You need access to a lathe dude!!!!
    Quote Originally Posted by tacubaya
    Good for you, but not everyone has access to a lathe.
    "El Whatever"
    Ah... yeah. I used to do so when I was working at a shop... but not anymore.
    If you've got a lathe around, that's the way to go.
    I'm happy with my mtnbiker4life cups, in the meantime. And they look pretty too!
    Check my Site
    moaaar shimz
    I was talking to Warp, not bashing your product. Warp and I know each other (he is a M.E. and I am a M.E. student).
    Btw Warp, I am going to start working on a very interesting project... I'll tell you about it via FB.
    I didn't take it as a bash of my product but more of a snidely type attitude which happens a lot of mtbr which is why I responded the way I did. I had no idea you know each other.....which explains everything.
    "El Whatever"
    Well... spill the beans...
    mtnbiker4life... sorry for the thread highjack. We indeed have ridden quite some together.
    Check my Site
    mtb4life, check your email.
    Thanks.
    got mine, great little tool for a great price.
    1 installation question though, I have an anthemX that mounts the shock vertical
    should the slit go straight up away from the shock, or straight towards the back of the bike?
    The mountains are calling and I must go
    Quote Originally Posted by Evan55
    The split in the bushing should be placed in position that is out of the path of shock. Here is a snap shot from the mfg installation manual.
    Laker and a Trail Blazer
    Reputation: Broncstad's Avatar
    Perfect in every way...
    Beacuse of this perfect tool and the dude who designed it, I was able to get this killer ride, epic climb in today...
    X-Post: Review of mtnbiker4life's shock bushing tool-bushing-ride.jpg
    X-Post: Review of mtnbiker4life's shock bushing tool-photo.jpg
    Super easy to use even for a new guy. This has encouraged me to start doing more of my own work on my bike. Instead of LBS(Lagging bike shop). Mtnbike4life is truely a pleasure to deal with.
    I had trouble getting those aluminum spacers out because of first time. I would like to replace those too. Where do I get them? Also I was wondering why the bushing wears out before those aluminum spacers do? Is seems the aluminum is a lot softer and would wear faster.
    Quote Originally Posted by Broncstad
    I'm glad you like the Bushing Tool The DU Bushing is the wear item in the system but the reducers do wear out expecially the Fox 2-piece type. The Fox reducers are not anodized so they wear faster then the Rock Shox 3-piece reducers which are hard anodized. From what I have experienced is I tend to go thru 2 DU Bushings then the Fox reducers are shot. If you need new reducers contact me.
    moaaar shimz
    Bought a bunch of DUs from mtnbiker4life at a great price. The shipping was FAST. Thanks again bro.
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    Just used my recent purchase to swap out the upper bushing on my RP23, simple, even using a c-clamp.
    Rolling on 29", 650b, 8.3" and 23mm
  67. #67
    Can you use the tool to install the RWC needle bearing conversion?
  68. #68
    Just received mine, and it worked great. I had my bushings changed and the shock back in the bike in about 5 minutes.
  69. #69
    Quote Originally Posted by Ray Pinpillage View Post
    Check my ads. I sell a drift that works with the Tool to remove and replace the RWC Needle Bearing.
  70. #70
    I just wanna chime in and praise this tool, it is so simple and elegant and the crafting is pure quality!
  71. #71
    Reputation: flyxaos's Avatar
    Old thread I know, but...
    I have MTBRforlifes tool for DU and RWC. I just used it to put the RWC needle bearings on the back eyelet. Worked great, of course.
    But, on the front. I am using the fox heavy duty hardware, a through steel pin, with a DUl. Problem is, the pin is too tight in the DU bushing. I think it should be snug, but allow rotation. I saw in another post MTBRfor life said he "burnished" his DU.
    Can I remove some material from the outside of the DU before I install it? Or is there some other way to gain a little bit of room to allow the pin to rotate?
    thx.
  72. #72
    today i change the front and rear eyelet on my Dobermann Stella elka shock with this tool and the silver eyelet's. that is so easy!! best gadget!
    ride.
  73. #73
    Quote Originally Posted by flyxaos View Post
    thx.
    Burnishing DU Bushings requires the correct tools and know how. I know upon installation that steel pin feels too tight but that bearing material will flow after it's put into service. I thought about selling some burnishing tools but the process requires more then general knowledge.
  74. #74
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    mtnbiker, I installed new bushings using your tool 1 week ago. Afterwards there was a slight clunk when compressing the shock quickly. It felt a lot like a platform opening. Anyways after 3-4 rides during which I lived with the "problem" it slowly but surely went away.
    Is this to be expected??? Any clue what went on?
    Check out my SportTracks plugins for some training aid software.
  75. #75
    Reputation: bob29r's Avatar
    Dec 2004
    ... and if we just ...
    I ordered this tool on a Sunday and received it on Wednesday, CA to GA via USPS. Great service from "mtnbiker4life" !!
    I couldn't see possibly messing up my shock post with the socket "ghetto" process or getting all the other DIY parts to make it happen. This tool is machined perfect for the job!
    Highly recommended!
  76. #76
    Dec 2005
    I would agree. Have had the bushing tool for a while. Haven't used it in quite some time. After cleaning my bike last time I noticed quite a bit of play on rear suspension. Didn't think it had been that long; After pressing out the old DU and installing a new one, all was back as it should be.
    So nice and easy to replace a DU bushing when you have the correct tool.
    to the mtnbiker4life's shock bushing tool
  77. #77
    Very nice tool. So much easier than trying to use sockets. Fast response and shipping from seller.
    Mark
  78. #78
    Just Ride!!!!!
    Reputation: mecam's Avatar
    Cool tool. I ordered one even though I don't need it yet. Used sockets in the past but so time consuming trying line things up.
  79. #79
    Dec 2004
    Anywhere I can find a write up of the install of Enduro Needle bearing kit with you tool? Mine should be here today. Thanks!
  80. #80
    Dec 2005
    Quote Originally Posted by mgsuarez View Post
    Should be instructions within the kit. Mine had some brief instructions. Pretty easy to do. I already had the 1/2" standard DU tool from mtnbiker4life so DU bushing removal was easy. I picked up the needle bearing installer from either RWC or mtnbiker4life (can't recall which).
    That said the needle bearing kit is installed (top only as it is on a Giant Reign that does not utilize a DU on the bottom), and has been problem free all along and seems to offer up a less restricted movement as compared to a DU.
    Have fun
  81. #81
    Dec 2004
    Just received mine from the mail. Nope no instructions. I was hoping to have some. Maybe ill email the sellar. Thanks!
  82. #82
    Are the bushings for Fox (2013 RP23) and RochShox Monarch XX (2013) the same and are they and the reducers interchangeable?
  83. #83
    Dec 2009
    Yet another happy customer here.
    I ordered and quickly received this tool and some bushings from mtnbiker4life. Just brought my RP23 over to the local bike co-op to use their bench vise and was out of there with a new bushing in about 5 minutes. Totally awesome tool, great price, beautifully machined, and easy to use. Old reducers fit snugly in the new bushing. Thanks mtnbiker4life!!!
  84. #84
    Oct 2013
    I got my tool today at it was really good. Excellt stuff, Im very impressed!
  85. #85
    I use his tools in my shop for like 4 years. They all worked as they should.
  86. #86
    Reputation: jgusta's Avatar
    Another happy customer here. High quality, easy to use tool. Thanks Vince!
    Ride On!
Members who have read this thread: 12
