Page 2 of 2 FirstFirst 12
Results 101 to 139 of 139
  1. #101
    Jan 2005
    Quote Originally Posted by ktm520 View Post
    Update: I recently got a new CTD shock service under warranty (sucked air into damper) and on the packing slip, Fox has the shaft seal listed as "O-ring [8.5mmID X 2.5mm CS]Metric, Polyurethane Parker 4300/92A, or DISOGRIN 9250/90A, dynamic". This must be a recent configuration change, as the 2008 drawings/parts list show the -110 oring. This is just an FYI. I will continue to use the -110 polyurethane 90.
    ok thanks for the info so: dash 110 is .362 ID X .103 thick
    and the new metric one is .335 ID X .098 thick
    i tried a buna 70 dash 110 for the shaft seal once because it was much cheaper, that made noise immediately after rebuild, went back to poly 90 dash 110 and the shock has been perfect ever since...haven't tried a buna 90 dash 110 but the polys are relatively cheap
    "He can make even a global summit meeting seem like a kegger." M. Dowd, NY Times, 19 July 2006
  2. #102
    Mar 2013
    Good ... good
    Hi all,
    Just an addentum to my previous messages about the RP2 i've serviced some months ago.
    The air would not stay inside with a plastic cap on the schrader valve but it will with a metal cap WITH an o-ring inside. My shock is now working perfectly for 4 months, pressure is kept inside with no problems.
    I got 440 psi in it.
    Happy riding to all.
  3. #103
    Oct 2013
    This post has been Very helpful to me. My RP23 has done the deed too. Thank you everyone.
    BTW. If anyone is looking for a valve with the right thread for re-pressuring our shocks. The pressure release valve from a Ford Escort/Mondeo's injector rail is exactly the right thread. Go to your local scrap yard with a long reach 11/32 socket and get yourself a few. Ford have two types of injector rail. One has a moulded in release valve but the other is fully removable. They work brilliantly
  4. #104
    Oct 2013
    please delete this
  5. #105
    Oct 2013
    please delete this
  6. #106
    Mar 2013
    Quote Originally Posted by 412294 View Post
    Thanks a lot for the info, will check in the junkyard to see if i can found an Escort or Mondeo (Diesel or Gas ?).
  7. #107
    Guys, can u help me somehow? I dont wanna pay fox 120 euro + shiping for servicing shock
    Fox RP23 leaking oil behind rebound knob - Pinkbike Forum
  8. #108
    Mar 2013
    Hi mcwelja,
    Are you able to dismount the Shock absorber ?
    Look at post #89 and #87 from this thread, your problem is certainly the A or C ring.
  9. #109
    Reputation: travman's Avatar
    deleted - after more research my answer was received.
    Attached Thumbnails Attached Thumbnails X-Post Fox RP3 - Unserviceable?!?!?!-img_2618.jpg
  10. #110
    damper seal kits -
    i hope you guys won't consider this as spam. i thinck the link can help the diy riders -
    Fox Float R RP2 RP23 RP3 Triad Improved Oil Seal Kit | eBay
  11. #111
    Aug 2013
    Damper o-rings for all these inline Fox float shocks (CTD, RP, RP2, RP3, RP23 etc):
    9x2.5mm (2pcs) - bumper and damper shaft seal
    26,7x1,78 damper cap seal
    17x3,5 IFP
    4x1.2 rebound tube seal
    2.5x1 compression rod seal (ctd or propedal rod)
    7,5x1,5 air seal between damper shaft and shock top cap (if shock leaks air under knobs)
    values are in milimeters
  12. #112
    moaaar shimz
    Reputation: tacubaya's Avatar
    Quote Originally Posted by ncerni View Post
    17x3,5 IFP
    Incorrect.
  13. #113
    Reputation: ktm520's Avatar
    ^^what tacubaya said. All of the correct oring sizes have been posted previously in this thread. CTD and RP do not share the same shaft size.
  14. #114
    Aug 2013
    IDK, these sizes work for me Every inline fox float shock I had in my hands had 9mm damper shaft.
  15. #115
    Aug 2015
    I would be grateful RP3 seal sizes. Also, a table to lookup IFP depths.
    Thanks, great thread!
  16. #116
    Quote Originally Posted by ptd006 View Post
    I'd be grateful of a lottery win but its not going to happen!
  17. #117
    Aug 2015
    No worries, in the end I bought the "improved" seal kit from Sheeep Israel / abagrizzli on eBay ($32 delivered). As with the Fox seals, it seems way overpriced for over the counter seals. Also it remains to be seen exactly what "improved" means!
    For the needle hex adapter/tool I'll drill out a tamperproof 4 mm hex bit. Still not sourced any nitrogen.
  18. #118
    Aug 2015
    I plan to rebuild my RP3 next weekend (to hopefully get ProPedal working and get rid of the squelching noise!).
    I've got
    - the Fox air can seal/oil kit
    - Abagrizzli/Sheeep's seal kit
    - Spare 7mm o-ring to make extra rubber pucks (if necessary)
    - an old 4mm hex/allen bit to drill out
    - an old football needle with a thread that fits my shock pump.
    - syringe for bleeding
    Missing:
    A) hypodermic needle (which I will epoxy into the football needle). What size/gauge to get?
    Edit: I happen to have 21 and 23 gauge needles in my medical bag. So will try one of those!
    I figure a 0.9mm internal diameter needle has about 28.3 square mm surface area per cm, i.e. 0.045 square inches. At 400 lbs / sq. inch that's about 18 lbs or 8.2 kg, which I think is OK but I wouldn't go lower than this (i.e. > gauge 18).
    The motion pro needle is a 22 gauge, going by internet forum posts.
    (I would buy a motion pro needle but they seem outrageously expensive for what they are!)
    B) Oil. Any suggestions? (I do have some old motorbike fork oil but doubt that is appropriate).
    C) IFP depth settings! Any got a link to a table?
    Edit: I am just going for the 48.3mm depth spec'd for the RP23 in same size.
    D) Anything else?!
    Edit: I bought a new Float CTD, "just in case", so I can keep riding
  19. #119
    Jan 2017
    Hello, I am new here but I have some problems servicing my RP23.
    I have a needle and a shock pump so I have no troubles putting more than 300PSI in my IFP chamber.
    Problems comes from the fact that I cant take all the air from the damper when rebuilding it. I have followed all the steps from http://www.dhfr.ru/fox/Content/Servi...23_Rebuild.htm
    But opon putting together the shock I have about 10mm of squishy in the upper travel.
    I have followed the instructions and oil got out of the bleeding port for damper oil, after that I have inserted the steel ball and nut.
    photo hosting sites
    Can you please give me some advices, maybe there some settings like full open and rebound full on, or full of ... i dono
  20. #120
    Feb 2010
    You want to fill the damper body to the top with oil. Have the rebound fully open (fastest setting) and soak the entire piston etc. in another container of damper fluid. Keep the piston under the fluid and agitate it until there are no more air bubbles coming from the piston etc. Quickly transfer it to the damper body and screw it on. Lots of oil will overflow and some should escape out the bleed port as you screw the final few turns on the damper.
  21. #121
    Jan 2017
    Thanks @TigWorkd, what you are saying makes perfect sense. To bad I haven't found an advice like this before servicing it.
    For the moment I have tested the shock by installing it upside-down and the sound is still there so It makes me think that if there would no air it would be sitting on the IFP plate and not at the piston plate.
    So I am thinking there is no air in the damper and the noise is caused by the oil passing through the shimstack and valves? Could it be like this?
  22. #122
    @adyamg,
    If you are getting 10mm of aerated oil, that is a lot of air. Fox's published bleed procedure doesn't get all the air out, but it's good enough. Definitely make sure both the compression and rebound are set to full soft/fast. If not, the ifp will displace and leave a pocket of air above the piston. When you do it right, quite a bit of oil will vent out the bleed port and run down the side of the damper body.
  23. #123
    Jan 2017
    @ktm520 if it would be air in damper oil, when I have turned it upside down, the air should have moved to the ifp plate and should have not been felt at the beginning of the run! It should have been felt at the end of the run/stroke.
    Besides that, I have got the oil out from the bleed port when threading the piston into the damper body!
    The only think I haven't done is to submerge in oil the piston plate before threading it to the damper body.
    Other fact is that I have tried tu purge the air by opening the bleed port on the top of the piston plate(I know that IFP depth got modified in this case). It only got out oil, no air bubbles.
    So my gues is that if it is air it is located somwere in the piston, or maybe it could be normal operation noise of the shock caused by oil passing through shimbstack and rebound and all the valving in there?!
  24. #124
    That sheds a little more light. Ya, sounds like you got a decent bleed. Is the air can installed when you hear noise? When air piston passes transfer port in can, it can make a noise consistent with what you describe.
  25. #125
    Jan 2017
    @ktm520, I have cycled the shock without the air can and I could not feel a swoosh, hiss, nothing, i would say it felt butter smooth.
    After installing the air can when pumping it, at about 50PSI it makes a hissing sound, and that is the sound that I get when compressing the shock.
    Can you please point me to what Fox said about bleeding and not getting all the air out?
    Cane Creek stated something similar here: https://www.canecreek.com/products/suspension/lounge/forum/air-cs-soft-initial-damping
  26. #126
    Jan 2017
    Hmm, you guys got my thinking.
    Could it be me putting a little to much oil in the air can(I have used synt gear oil and I could actually put a little more having the ideea that more is better then less?!)?
    And this oil being cycled between negative and positive?
  27. #127
    Mar 2017
    Fox Service Instructions RP2, ...
    Quote Originally Posted by HomegrownMN View Post
    is unfortunately not available.
    I assume it was a ZIP File with the service instructions for rp3, rp2, rp23 and others.
    Please can someone upload it again?
    www.dhfr.ru/fox , which I assume had the same information is offline, too.
    I would appreciate it very much when I can get the "Bible".
    Thank you
    wildhai
  28. #128
    ggg
    ggg is offline
    Quote Originally Posted by wildhai View Post
    Thank you
    wildhai
    This service procedure from Fox for a CTD Boost Rebuild
    is mostly applicable to the RP line as well.
    Go crazy !
    https://www.ridefox.com/help.php?m=bike&id=143
  29. #129
    Jan 2016
    Hi all, I have a Van RC that bottoms out on my 2012 Trance X2 which I'd like to tune, would increasing the ifp pressure also increase bottom out resistance?
    Could I just unscrew the old 4mm hex screw, screw on that Schrader valve and get pumping; no need to do a full rebuild on my shock?
    I found a link from fox (https://www.ridefox.com/help.php?m=bike&id=63) that shows the ifp depth for the Van RC, it seems that they state the same depth for all the different travel versions of this shock, how could that be? Isn't ifp depth determed by the shock travel?
  30. #130
    Reputation: Dougal's Avatar
    Quote Originally Posted by Razroid View Post
    The Van RC doesn't have anything inside which responds to IFP pressure. But it'll still have an effect by adding shaft force and also adding friction on every seal.
    IFP depth has to be enough to allow full stroke without too much pressure building. That's most of it.
    Owner of www.shockcraft.co.nz and NZ Manitou Agent.
    www.dougal.co.nz Suspension setup & tuning.
    SPV Devolve
  31. #131
    Jan 2016
    Quote Originally Posted by Dougal View Post
    So my understanding is that the suspension fluid is being pushed into the piggyback that has a floating piston in it, one side is aforementioned oil and the other side is the air, this in turns increases out bottom out resistance if I increase the pressure of the air side?
    Or will increasing the IFP pressure do nothing at all?
  32. #132
    Yes. But the bottom-out resistance is only increased by the air-spring effect. It doesn't add any damping to the oil valves.
    The DHX boost-valve shocks looked similar but had a valve in the bottom of the piggy back that would increase damping with more IFP pressure. But the Van RC doesn't.
    SPV Devolve
  33. #133
    Jan 2016
    Ah, I thought it would work similar to the DHXs, would it still be worth a go at it though? what adverse effects would there be if I overinflated the IFP?
  34. #134
    Worst case (provided you don't go super silly) is firmer top-out and more seal friction.
    SPV Devolve
  35. #135
    Jan 2016
    Well I can't go past 400 on my shock pump sooo :P
    Firmer top out meaning the shock will extend harder when I get off the bike?
    and would higher seal friction hurt small bump performance?
    Should I just sell the thing and get a 2016 Float DPS (C2QC)?
  36. #136
    Yes, yes, no.
    Use more compression damping or firmer spring.
    SPV Devolve
  37. #137
    Jan 2016
    Yes, yes, no.
    Well, I'm using a 500lb Ti spring and I weigh 90kg, I'm hardly getting 10% sag and I can bottom out the shock, does that mean that my bike (Trance X2 2012) is not meant for a coil shock?
    Is doing this mod worth the time or do I just leave it be and ride?
  38. #138
    Where is your compression set?
    SPV Devolve
  39. #139
    Jan 2016
    The LSC? Slightly past middle I think, so from 0 - 16 (0 being open, 16 being high damping), somewhere like 10 clicks?
  1. Replies: 7
    Last Post: 11-23-2012, 09:40 PM
  2. Rant - Fox Float RP3 - unserviceable?!?!
    By HomegrownMN in forum Colorado - Front Range
    Last Post: 12-11-2011, 07:18 PM
  3. 2011 Fox 32 Float RL OEM models come w/ unserviceable damper?
    By mehukatti in forum Shocks and Suspension
    Last Post: 11-22-2010, 05:37 PM
  4. Thomson post & KCNC quick release clamp, post keeps slipping
    By ewarnerusa in forum Weight Weenies
    Last Post: 11-13-2009, 10:20 PM
  5. Thomson post & KCNC quick release clamp, post keeps slipping
    By ewarnerusa in forum General Discussion
    Last Post: 11-10-2009, 09:21 AM
Members who have read this thread: 14
