Results 1 to 13 of 13
    X Fusion Vengeance knocking/clicking?
    My 2012 ven hlr air has recently started knocking/clicking on compression in the first 20-25% of the stroke. It doesn't knock or click when I cycle the suspension slowly, but quick hits is where it makes the sound. It's definitely coming from the air spring side and it kind of sounds like coil bind. I'm wondering if anyone else has had this issue and if they were able to locate the problem and fix it. I had the air spring apart last night and I couldn't find anything wrong other than the rubber bumper at the bottom of the negative spring was not quite seated in the billet end cap and the heat shrink at the top of the negative coil is a little loose. The bushings feel tight and upon inspection showed no signs of wear. The stanchions are smooth inside and out. When I reassembled the air spring I covered the assembly in Slick Honey and the sound was gone for a few minutes of cycling the fork and then came back. I am really at a loss and I would much rather fix it myself than send it out. If this is something that is inherent in the fork's design then I can deal with it, but it just doesn't seem right. Thanks!
    moaaar shimz
    Reputation: tacubaya's Avatar
    The ITA spring can sometimes click (as well as Fox Float springs) because the negative spring rubs the top out spring during initial compression. Greasing this area helps (and it is a step in X-Fusion service guides).
    so pack grease in between the 2 springs? like i said, i packed the whole spring assembly pretty good with slick honey and the noise went away for about 2 minutes of me cycling the suspension. after that it came right back. maybe i need to use some heavier, thicker grease?
    moaaar shimz
    I wouldn't worry much about it really
    Reputation: honns's Avatar
    Would putting some shrink wrap on the spring quiet it? I don't know if that would interfere with its function though, its a small spring after all...
    on my 3rd wind...
    Reputation: SingleTrackHound's Avatar
    Jul 2003
    My brand new 2012 Vengeance made same exact sound right out of the box. Sent the fork back to X-fusion twice but they weren't able to fix it. They said it is coming from negative coil spring mechanism in the fork. They tried everything but no avail...they even tried shrink wrap. Sounds drove me nutz so I never even took it out on the trail. I just returned it to shop for full refund and bought Zoke 55 RC3 Ti instead.
    I have two different Fox Float forks and they dont make that same noise.
    sth
    Awesome. Good to know x fusion can't even fix their own product.
    Maybe I can send it to Fox and they can fix it
    I had a Vengeance HLR DLA and the CSU was clicking as well. They said it was expected on long travel single crown... Since I also had lots of problem with the DLA cartridge, the fork went back and I got a refund. I bought a zoke 55 too.
    Apr 2016
    X-Fusion Vengeance, coil spring i have these forks on my big hit and when i ride over small bumps the forks are making a loud knocking sound anyone have a idea what it could be cheers
    Sent my 2011 Ven HLR back to X-Fusion for a CSU creak. They were able to fix it. Never made a noise after that.
    Apr 2016
    do i have to send them to them or would i be able to take them to a bike shop
    Quote Originally Posted by dombradleeds View Post
    I called them direct and sent them in myself. If you have a good bike shop that deals with them, they can do it too. I would call first tell them your issue and ask some questions, then decide which way to go.
    May 2010
    Vengeance CSU creaking is an easy fix with a couple of drops of loctite 309.
    (green penetrating loctite)
    Leave upside down with a couple of drips on the CSU\station interface for a couple of days, and wipe off the excess.
    Just due to slightly poor surface finished on the CSU and Station interface, so the bonding can creak.
    309 wicks into the micro-gaps and hey presto you have a silent fork that is perfectly safe.
    The only other thing I could suggest for the clicking, would be due to the negative spring warping when being compressed. You could look at putting a teflon washer above it, so it has less binding force and can rotate to keep straight (rather than bend and catch the topout spring inside it).
    Scar
  1. X-Fusion Vengeance
    By gunt pimp in forum Shocks and Suspension
    Last Post: 10-16-2016, 05:44 PM
  2. x fusion 2013-vengeance-hlr????
    By loolilon in forum Shocks and Suspension
    Last Post: 01-04-2013, 02:12 PM
  3. X-Fusion Vengeance HLR- Who has one n how u like it??
    By yellowpasta2000 in forum All Mountain
    Last Post: 10-03-2012, 08:55 AM
  4. X-Fusion Vengeance HLR - Check it out!!!
    By Gaprider4Life in forum Shocks and Suspension
    Last Post: 04-14-2011, 06:52 PM
  5. x-fusion vengeance
    By bailout in forum Banshee Bikes
    Last Post: 02-17-2011, 07:09 PM
Members who have read this thread: 4
