I crashed and the handlebars spinned and pulled the hose.
Where did you get your replacement??
Emailed the local distributor. Thought the replacement was a bit overpriced for a tiny piece of plastic ($25 shipped), but if I only break one a season I'm OK with that.
Anyone still in this thread?
Trying to get my sag correctly, I could never get past half of the travel so I figured there is too much air in the fork (mind that I know next to nothing about suspension).
The setup guide (http://www.xfusionshox.com/images/pd...-Guide-V01.pdf) says 30% sag equals about 54mm. I'm 84kg fresh from the shower, so with gear on probably around 90kg, which according to the chart should need 80psi.
Now, to get only 40mm of sag, I already have to lower pressure to 50psi, and I did it twice using a different pump. Is this normal??
The setup guide ( http://www.xfusionshox.com/images/pd...-Guide-V01.pdf) says 30% sag equals about 54mm. I'm 84kg fresh from the shower, so with gear on probably around 90kg, which according to the chart should need 80psi.
Try to change the compression settings.
they are the dials at the bottom.
Screw them out until the top out.
Then try it again
I did that, screwed both of them out (down), before setting the sag.
Yeah their psi settings are way out. Im 100kg and run 45 psi, this is on the 160mm fork settings.
2 clicks of hsc, 4 clicks of lsc from fully open and im pretty much using all travel.
Contemplating replacing my 180mm Dorado with this to drop some weight. How is the fore-aft stiffness compared to a dual crown in rock gardens? I'm assuming there will be a little more flex, but is it enough to actually slow you down? I'm 180lbs fully geared up.
tbh, i don't think the Dorado being a USD fork is noticeably stiffer than the Metric. I'm just stabbing in the dark here and I've ridden 200mm Dorado and they are flexier than Boxxer or 40, still an excellent fork though... and I run my Metric@160 and it is plenty stiff (they do a good job of keeping straight even with the new Magura MT7 ^^). I figure the difference between Metric / Dorado is gonna be less than Dorado / 40...
I looked through this whole thread and I still don't know.... should I buy a metric or not? Is it an awesome fork? What does it do good? What is it not good at? I ride a 26" 160mm bike and I'm looking for a fork to ride at bike parks during the summer. I've been considering a Lyrik 26 RC2 DH, and I know the Metric is another option to consider. I have a fork I ride for trail/am/xc that works great but it doesn't cut it for spending the whole day at the bike park so I'm looking for a fork I can switch out when I go there.
The metric is awesome in 180mm mode. At 160mm the mechanical negative spring can make it top out a little harder than is optimal. I have one on my tr500. 95% of the time I feel no need for more travel. It's only when blasting rocky trails at race speed that I feel the lack of travel come into play
Sent from my SAMSUNG-SM-N910A using Tapatalk
Easy call.... the HLR damper beats the RC2DH hands down.
just bought an used Metric... seller told me it's a 650b, how can I check if it actually is? any clearly discernible difference in the upper? or does serial n. tell something?
and: I can notice some squirting noise from the damper, is it normal or does it need a service? adjusting dials seems to work properly
all metrics have a 650b casting, the designated 650b forks have a different offset than the 26er. A 650b wheel will fit nonetheless... to tell the difference you would have to measure the offset. they used two different CSU to achieve that.
a very little bit of squishing is ok... if it's a lot, like in a greater part of the stroke, it might have too little oil in the damper.
I would first try calling xfusion and see if they can tell you by the serial #. They should be able to and that might be the easiest, surest way.
Once you get it working I would like to know how it performs with what kind of riding you are using it for.
pretty hard job to measure the offset...
there's udible squishing through the whole rebound stroke, may I refer to this guide X-Fusion Vengeance HLR Service Guide to service the damper?
will do. it'll probably take me some weeks though to get some proper ride time, as I'm recovering from a bad injury and can't ride hard already.
fork is going on a Canfield The One, replacing a Marzocchi 350cr (I was having very nice feelings on the Marzo but such a capable frame was calling for more front travel)
Can anyone attest to the durability of the metric, specifically the CSU?
I've had horrible luck with Fox 36 crowns creaking and desperately need a better option.
2 years and no probs, a vengeance I had before got a new csu on warranty after 1,5 years... been thrashing it as hard as I can, been using it more as a mini-dh fork than anything else...
Had mine since the start of 2014, no problems. Use it for bike park and shuttle days.
I just bought a new updated Metric with the rough cut damper and sweet black stanchions. This is my second metric and I love it!
Before that I had the coil vengeance and it was great but the CSU did creak consistently. I sent the vengeance into X-Fusion and they didn't warranty it, said it was only superficial.
I did notice that the metric's coil negative spring does top out pretty hard when you fill the air spring up to 80, but as others have said, you don't need as much air as the guide recommends. I'm 220 lbs with gear and I ran my previous one at about 70 psi, the new one I'm still playing with. Apparently X-Fusion does have a heavier negative spring coil, but I haven't looked into it too much as the top out isn't bad once you back off of the top psi settings.
The X-Fusion stuff has been so good for me that I made a full switch for both of my bikes. My ONE has the vector air HLR and the metric HLR rough cut, and my Jedi has the RV-1, and soon-to-be vector air HLR for the rear.
Highly dependable, super easy to service, great customer service from my experience, and one of the least expensive out there... Can't be beat!
Fyi if you are having topout issues there is a possibility one of the o-rings in the negative spring assembly may be incorrectly installed. I was having problems with my 1st generation metric and after x-fusion wouldn't admit a problem i eventually found out the o-ring hadn't been installed properly.
Sent from my SAMSUNG-SM-N920A using Tapatalk
I must know how! Love my metric and am after the new damper...
Has someone ridden other forks and can tell some pros and cons vs lyrik rct 3 and new float 36?
This!!
Sent from my E6653 using Tapatalk
By TimT in forum Frame Building
Last Post: 01-05-2015, 05:49 AM
By Jaunty_Joe in forum Endurance XC Racing
Last Post: 08-26-2013, 02:19 PM
By Hand/of/Midas in forum Endurance XC Racing
Last Post: 05-26-2012, 02:36 PM
By customfab in forum Frame Building
Last Post: 04-23-2011, 10:49 PM
Last Post: 02-26-2011, 05:47 PM
Members who have read this thread: 13
- mcozzy29,
- neil_240,
- Crooked Cop,
- bicyclemech1,
- hankthespacecowboy,
- SAIG,
- lazarescu,
- Rusettipasta,
- timboland,
- twodownzero,
- gohdl73,
- scoon,
- dawson1450
- You may not post replies
- You may not edit your posts
Forum Rules
