Results 1 to 13 of 13
    Reputation: brankulo's Avatar
    Aug 2005
    x-fusion 2013 stuff, vector air HLR in particular.
    any info?, anyone got their new stuff? still debating vector vs ccdb air. with price hike for vectors ($579+50 dw tune) i am starting to lean towards ccdb which can be had for little under $500. opinions?
    Jan 2011
    I have the vengance DLA air which superb, I don't doubt that the vector will be any different,
    I wasn't sure which one to go for,
    I think there are five factory tunes for the vector, at extra cost like you say
    In the end I opted for the ccdb air, only two rides very happy, the small bump absorbs ion is unbelievable,
    Five is right out
    Vengeance is a step-down fork, Vector is a shock?
    Aug 2005
    vector is shock.
    any idea on how easy is to shim travel on ccdb air?
    Reputation: honns's Avatar
    What exactly do you mean by "shim travel"?
    Aug 2005
    to reduce a travel a bit, 2-3 mm. my bike is 650b convert and needs little less travel so the bigger wheel doesnt rub seat tube at full compression. in my current rp23 i use 3 1mm plastic washers from HD around shaft.
    Huckin' trails
    Reputation: David C's Avatar
    Quote Originally Posted by brankulo View Post
    You could try offset bushings for the mounting hardware if you have enough frame clearance. $20 a pair I think on eBay. Or just shim it the same way you did with your current RP23.
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    Gotcha, makes sense but I hadn't ever heard of those before. You might want to contact Cane Creek, they've been helpful to me when I've had questions.
    I just installed a 2013 Vengeance and 2012 Vector w/ DW Link tune (HLR Air for both) on my HD. I'll try to get a review up by next week in the Ibis forum. My initial impression is very positive.
    Aug 2005
    great, please do. i have HD too. where did yo get 2012 vector? there is opportunity to get ccdb air for $470 right now, so i might end up going this route. with new hi flow inner can and xv outer can it should remedy all the issues people are having with it on HDs.
    Straight from X-Fusion. The CCDBA is a great shock and you will definitely need the new can and outer to make it work right. For me it was a simple decision of getting a factory specific DW tune vs waiting while the bugs between the HD and CCDBA are sorted out.
    Aug 2005
    you got 2012 vector from them? was it for 160? i was told 2 months ago they were out of them and to wait for 2013 model which is over $100 more.
    Reputation: windv's Avatar
    have ridden the vector and the ccdb and i vode 2 hands for the vector air.
    Has been working flawlessly for and year, while i had problems with cane creek all the time. It went ack for service a few times and i just got fed up with it.
    There is not really a noticeable difference in performance, a little difference in tunability and huge difference in reliability. Not too much is spoken of ccdba problems, but when you are faced with it and start digging, you find many people who have problems with it....
  1. X-Fusion Vector Air HLR - First Impressions
    By Warp in forum Shocks and Suspension
    Last Post: 04-13-2015, 08:36 AM
  2. X-Fusion Vector Air?
    By tiSS'er in forum Knolly
    Last Post: 04-16-2013, 05:53 PM
  3. X-Fusion Vector HLR Air
    By dropmachine.com in forum Shocks and Suspension
    Last Post: 02-02-2013, 10:45 AM
  4. 2013 X-Fusion stuff
    By IDysterDimma in forum 27.5
    Last Post: 09-06-2012, 09:13 AM
  5. Anyone run an X-Fusion Vector HLR on their Rune?
    By Haus Boss in forum Banshee Bikes
    Last Post: 06-03-2011, 06:21 PM
