Results 1 to 7 of 7
    Apr 2013
    Why I'm I so far from Rockshox pressure recommendation?
    I have a 2013 Revelation RCT3 fork. It was the standard solo air but I converted it to dual position air with new air spring internals (150/120). It was a very easy conversion.
    I weigh 174 pounds:
    For a 160-180 pound rider, RS recommends 85-115 psi (for the solo air) and 125-140 psi for the dual position air.
    Since I have the dual position spring now, I should be in the 125-140 psi range according to RS. I am now at 90 psi and it feels good. It is smooth through the range of travel and doesn't dive. I have about 25% static sag in the long travel setting. I am still not getting full travel. The o-ring is always 20mm from the crown after a fairly hard ride. This is in the open damper setting and no compression damping at all. I feel like I might even need to drop the pressure down to 85psi. If I let all the air out of the spring, I can get it to fully compress so it isn't a spacer or bump stop issue.
    I can imagine being a bit lower than RS recommends; However, I am at 85 psi and they recommend 125. That's not even in the same ballpark.
    Any thoughts?
    Class Clown
    Reputation: dundundata's Avatar
    I run a fair bit less on my Recon too. It recommends around 100 for my weight and the travel, 180 and 120 respectively, and I have it set at 75. Maybe it's a liability thing. Low pressure with no compression damping or open floodgate setting could potentially send someone OTB when braking. So they recommend a stiffer fork setup. I don't know, just guessing. I just ride with what feels right.
    Curious to see how other setup their air.
    My buddy has a revelation xx wc dual air (2012 I think) that he runs way under recommended pressure. He likes it squishy though so maybe it's just a preference thing.
    Class Clown
    true enough, I like a soft spring with a bit of LSC
    I have a Reba that I ride at 90-100 psi. I weigh over 200 geared up which would put me at over 135 if I followed their guidelines. I do like it soft though.
    Lightly salted
    Reputation: fuenstock's Avatar
    I have a Revelation rlt ti and run lower psi then recommended. Same thing on my Fox 36 160mm fork. Its best to adjust to feel and just use the stated psi as a starting point.
    Dec 2009
    The only fork i've ever got close to running at recommended pressure is my 55CR. From memory my Revelation is way off recommended pressure.
  1. Rockshox Reba 29 air pressure question.
    By Flying Wombat in forum Shocks and Suspension
    Last Post: 03-31-2013, 08:53 PM
  2. seeking recommendation for Monster Cross (Richmond VA) tire pressure
    By Eric Marshall in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 02-13-2013, 10:54 AM
  3. How much pressure to run in a rockshox bar 1.1
    By MTBCanuck in forum Shocks and Suspension
    Last Post: 07-21-2012, 07:30 AM
  4. Replies: 3
    Last Post: 05-26-2012, 10:31 PM
  5. Tire Pressure Recommendation? Help
    By Campagnolo in forum Arizona
    Last Post: 01-08-2012, 05:33 PM
