• 11-26-2012
    ride the biscuit
    Why did Rock Shox discontinue U-Turn Air forks?
    I am considering buying a used u-turn air fork, like a pike 454. It just makes me wonder why they dont make them still (please correct me if I'm wrong about that).
    Seems like u-turn external adjustments on a sturdy air fork would be pretty nice
    also, i would be interested in other model suggestions than the pike 454
  • 11-26-2012
    keen
    Don't know if they were more costly to produce or suffered more reliability issues (they did have a top out clunk problem reported) but in my experience I just left mine @ one travel setting. Initially I thought it would be great to run different travel settings but after 1 one ride I was satisfied w/ full travel. Also, running the fork lowered for climbing wasn't an "on the fly" adjustment.
  • 11-26-2012
    Joules
    I think it's that the dual position air they have now is more of an 'on the fly' type thing, where the u-turn required you to dial down through small steps. I guess they found, or believe, that most riders want a high and low travel setting without much in between.
  • 11-26-2012
    ride the biscuit
    OK that makes a lot of sense. I am planning on putting it on a hard tail that is supposed to ride well for both street/DJ and single track so the adjustability is key esp since I don't know exactly what I'll like best yet.
    But yeah, it seems that if I knew what I wanted 2 settings would be enough
  • 11-27-2012
    Renegade
    Spam; I have a pike dual air, u-turn Push industries Factory tune fork sitting in my garage, waiting for a purpose. PM me if this is of interest to you.
  • 11-27-2012
    Mountain Cycle Shawn
    Reliability, weight and the fact that they found out that people really don't use it. I mean really, who wants to stop right before that climb, lose your momentum and crank your fork down. Then you have to stop and crank it up before going back down. Where I ride, I'd spend half the time cranking my fork up and down.
  • 11-28-2012
    alexzhu1
    I think this is why, changing my Tora 289 U-Turn from minimum 85mm to maximum 130mm takes a ton of turns and probably over a minute of time, so I just leave it at full travel.
    The new Dual Position mechanism apparently only takes 1/4 turn to go from minimum to maximum so I imagine it would be much more useful.
