Results 1 to 27 of 27
    Reputation: 2 Slow's Avatar
    What are you using to pump your air shock?
    I recently installed a RockShox solo air fork which has a shrader valve for air inlet/outlet and was wondering if it is necessary to buy a shock-specific air pump with built-in dial gauge.
    Could I just use a small air compressor or are these shocks that finicky that a bike-specific pump is necessary? I haven't even attempted to use the air compressor but also wouldn't mind saving $40 if I can.
    Thanks.
    Enthusiast
    Reputation: JonathanGennick's Avatar
    I'd buy a shock pump. The volumes of air are small, and would you be able to get the precise pressure you wanted using a compressor?
    Here's one on eBay now for only $24:
    Rock Shox HP Shock Pump 300psi | eBay
    Yeah that's the advice people seem to be giving outside of this forum after a google search -- buy a shock pump.
    Went to a LBS today and other than charging $6 for a star nut he wanted over $50 for the shock pump (Cannondale brand) which is where I came up with the idea to use my air compressor.
    Did you buy the fork NIB? When I bought my RS Reba it came with a pump. Yes, I recommend a shock/fork pump.
    Quote Originally Posted by Call_me_Tom View Post
    Yes, I bought the fork NIB. It is a RockShox Recon Gold and did not come with a pump.
    I'm digging the the pumps with an attached hose. Probably make it easier to maneuver the pump and for better positioning when in place.
    Chamois Dropper
    Reputation: natzx7's Avatar
    I have a RavX and a marzocchi . I like the RavX because it has a little release on the shraeder fitting so you don't lose as much air when you unscrew it. I think it was about 30 bucks. The marzocchi works better for low pressure forks, IMO.
    2008 GT Force
    Go Veg
    Reputation: ColinL's Avatar
    Feb 2012
    I have a topeak dxg shock pump. It's small and convenient to put in my camelbak in case I need to tune mid-ride, which is pretty rare unless I'm on a new trail.
    FWIW, my new Fox fork didn't come with a shock pump.
    Feb 2012
    Sette Air 2 ST-35 Universal Shock Pump at Price Point
    This is what I use. Not bad for a $25 pump.
    Quote Originally Posted by SteezusChrist View Post
    +1
    I had two shock pumps because they came with my bikes. Sold one for cheap to a friend.
    An air compressor will blow your fork/shock up. Even if you could use an air compressor, you would lose all the air when you check the pressure with a gauge. You have to use shock/fork pump. You never lose air from the fork/shock when you unscrew the pump. The air you hear is the air coming out of the hose of the pump. Don't tighten the pump on to hard.
    Quote Originally Posted by ColinL View Post
    +1 on what he said. I just got the X-Fusion Slide 29er and needed a pump. Got mine off Amazon for under $30. Easy to use and quick inflation plus has a built-in valve in the connector so you don't lose air pressure when you unscrew it.
    2011 Sirrus Sport
    2012 Hardrock Sport Disc 29er
    I don't know everything but I can always find someone that does.
    Thanks for the help everyone!
    I ended up buying a new RockShox pump for $25 shipped off ebay.
    Quote Originally Posted by robit View Post
    You don't lose air with any pump when you unscrew it.
    Gonna have to disagree with you there Shawn...I had a pump that would definitely bleed off as it was unscrewed. It was a real PITA and was resolved by getting a Topeak pump with the double thread (one to engage the schrader and one to open the valve).
    whatever...
    Quote Originally Posted by steadite View Post
    Then there is something wrong with your valve on your fork/shock. The valve closes from the higher pressure in the fork/shock as soon as you unscrew the pump. The air you hear coming out is from the air in the hose of the pump. You get a lower pressure reading when you screw the pump back on because that same hose fills with air.
    Yup, the bleed is from the air in the hose and not the shock.
    I got a schwinn pump that my LBS sold me for 30$ used because they didn't have any shock pumps in stock. Its a very nice pump, everything is solid metal and I would feel comfortable dropping it off the top of a building!
    Sep 2012
    Blackburn has one of their toolminators with a shock pump it's small but cool if you need to pump on the road or trail
    Quote Originally Posted by Mountain Cycle Shawn View Post
    Why would an air ompressor blow up your fork/shock? The issuse I have with the air compressor is that mine only goes up to 100 psi. And I don't have any accurate way to change the PSI with such a small volume. If I just wanted 100 PSI everytime then the air compressor would work fine.
    I use a Sette shock pump. works great
    Reputation: rjg5's Avatar
    Aug 2010
    I've got 3 shock pumps. PM me if you might want to buy one cheap
    Reputation: MXRider72's Avatar
    Aug 2010
    I got one of the house brand pumps at performance bicycle on sale for $25, think its called hurricane. Works great and it goes up to 300 psi.
    Sent from my PC36100 using Tapatalk 2
    Bicyclochondriac.
    Whatever the pressure in the tank is (or the setting of the pressure regulator on the hose) that is the max pressure you are going to put in the shock. As long as that is not too much pressure, you will not damage the shock.
    This is correct^^^^
    Quote Originally Posted by kapusta View Post
    This is correct^^^^
    It's the quick shot of high pressure from a large tank into a small shock air chamber that blows the shock or fork. And, if the compressor is on, that makes it worse.
    Bicyclochondriac.
    Only if the tank is set a high pressure to start with. Size of the tank is irrelevant. If it is set at 150 psi and the shock can take 250psi, it is not going to blow the shock because it cannot deliver more than 150 psi.
    Realistically, few tanks can hold enough pressure to blow shocks, which can easily take 250 psi.
    bontrager pump... no issues
