    What lube for sticking PopLoc? (Reba SL Dual Air 29er)
    My PopLoc has started sticking the past few rides. I have narrowed it down to be the blue external dial that is sticking. What should I lube this with to fix my problem?
    Fixin' shocks Day & Night
    Reputation: two6labs's Avatar
    Nov 2008
    Quote Originally Posted by cinaibur
    Check to make sure the white Teflon washer is in place under the dial. It may need to be cleaned. Get some snap ring pliers and remove the knob assembly and wipe it all down with WD-40 or something similar. Then with everything removed try to turn the black hex cap that the blue knob sits around. You may need to use a wrench to do it the spring should be tight. If you turn it and it snaps back then the problem lies in the cable from the remote to the knob. I hope this helps.
    Tim
    Thanks. I will try that when I get home from work.
    The problem ended up being with the cable shroud. All is well now. Thanks for the advice!
