Results 1 to 6 of 6
    What hub fits the Marzocchi 44 micro ti with QR 15?
    I have a 2006 Iron Horse Warrior Expert that I am in the process of upgrading (brakes and fork)
    I would like more travel than the stock 100mm and make the bike slacker ( I am not worried about cracking the frame cause if I do it will give me an excuse for a new bike.
    I found this Marzocchi 44 Micro Ti Fork from Departmentofgoods.com
    Overall it seems like a pretty good deal, however, how expensive are hubs that meet the 15QR standard? I would like to stiffen up the front as it feels pretty noodley right now. Or should I just get the 9QR instead and not worry about it.
    Last edited by cassieno; 09-27-2011 at 06:08 PM. Reason: Title needed to be more descriptive
    Former Bike Wrench
    You of course have to build up a wheel as well...
    You can get Shimano or Dimension 15mm front hubs for about $60
    Thank you
    Thank you for help. Ill search around for a 15QR hub and see what I can find. My quick search last night was only returning $200 results and I didn't want to spend that much.
    Of course Ill have to build up a new wheel. Probably not a bad thing I am sure my current wheel needs some help.
    Right now the front feels very noodle like. I have not ridden a 15QR does it make an actual difference?
    Super confused
    According to department of goods website (Marzocchi 44 Micro Ti Fork from Departmentofgoods.com) this fork uses a 110 mm x 15 mm QR axle. I assume that means it needs a 110 mm hub also.
    I asked the online chat with department of goods, they said that's correct I needed a 110 mm x 15 mm hub.
    I cannot find a hub that meets those requirements. I only see 110 MM X 20 MM.
    Are they wrong is it really a 100 mm hub that's needed?
    Former Bike Wrench
    They are wrong, there is no such thing as a 110mm x 15mm hub. There is 100mm x 15mm or 110mm x 20mm.
    My guess is that they are a completely clueless wholesaler and nothing more...I can assure you the fork is a 100mm x 15mm dropouts.
    Thank you, that's what all my searching led me to believe. I just kept asking are you sure its 110 x 15 and they kept saying yes.
    However, given that no 110 x 15 hubs exist...
    Anyway thank you again
  1. 15qr wheelset and 15qr fork
    By pangster in forum Where are the Best Deals?
    Last Post: 08-27-2011, 01:55 PM
  2. Cheap 29er Options
    By BlueWheels in forum 29er Bikes
    Last Post: 07-15-2010, 11:30 AM
  3. 15QR/ Center lock wheel set options?
    By tailwaters in forum Wheels and Tires
    Last Post: 05-09-2010, 08:37 AM
  4. Cheap hardtail options?
    By Sleepy_Steve in forum Bike and Frame discussion
    Last Post: 08-25-2008, 05:17 AM
  5. Cheap SS Drivetrain Options
    By tibug in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-27-2006, 02:58 PM
