Results 1 to 2 of 2
    Reputation: PhaseSpace168's Avatar
    Sep 2012
    Vivid R2C Coil weights?
    I'm thinking of changing my old roco R to an RS vivid R2C 7.875x2.25, and was wondering what spring weight would be best for me? I weigh about 200lbs with gear, bike weighs 38lbs.
    Thanks in advance.
    Reputation: tune's Avatar
    There is not enough information to suggest any spring rate as the frame you are mounting the shock is very important (linkage curve/rate is very important). There are calculators to estimate what spring might be the best. For example: TF Tuned Shox - Spring Calculator
    But these calculators are only an estimation (as there are a number of other factors to consider that many calculators don't take into account) and not precise. So you might have to buy a couple of springs to find the right one for you.
  1. What is the psi for the IFP of a 2011 Vivid R2C coil?
    By bing! in forum Shocks and Suspension
    Last Post: 04-07-2013, 07:38 PM
  2. Replies: 30
    Last Post: 12-30-2011, 08:14 PM
  3. RS Vivid air, coil or Monarch+?
    By Danish Dynamite in forum Shocks and Suspension
    Last Post: 11-13-2011, 01:32 PM
  4. Replies: 29
    Last Post: 07-31-2011, 06:32 PM
