Results 1 to 3 of 3
    Vanilla 125RL travel question.
    Can this fork ('03) be made to run at 80mm of travel for a XC hardtail?
    Thanks.
    Reputation: robsetsfire's Avatar
    Quote Originally Posted by allroads
    Thanks.
    I believe so... check you manual. I had an 02 which could be lowered to 80mm, your 03 should.
    otb club member
    Reputation: Chris2fur's Avatar
    Thanks.
    Yes. Remove all the spacers from the top of the damper cartridge and the coil spring. Put a 25mm and a 20mm spacer on the plunger rod below the coil spring (see picture). For complete pictorial instructions, go here: http://www.enduroforkseals.com/id28.html
  1. Vanilla 2005 travel adjustment dilemma
    By goatman in forum Shocks and Suspension
    Last Post: 01-20-2005, 07:07 AM
  2. Fox vanilla not going through the full travel?
    By nathanross@hotmail.com in forum Shocks and Suspension
    Last Post: 10-06-2004, 08:36 AM
  3. psylo travel question
    By coolatt in forum Shocks and Suspension
    Last Post: 06-17-2004, 09:21 PM
  4. Technical question on shock length vs travel...
    By BanzaiRider in forum Shocks and Suspension
    Last Post: 05-14-2004, 01:34 PM
  5. Replies: 4
    Last Post: 01-22-2004, 11:09 AM
