Results 1 to 11 of 11
    Freelance Whatever
    Reputation: chowdownca's Avatar
    V-Brake 26" Forks
    I have a Rock Lobster frame that I'm looking to re-build with some changes from it's previous life. I wanted to know if there are any companies that are still making "nicer" (i.e. no Dart whatever) forks that have V-Brake posts. Would like to keep it about 100mm. Or would it be more beneficial to get say a used Fox and have it rebuilt?
    What I do for a living doesn't define me....
    I don't think RS or Fox still make a high end v-brake fork, but believe the Manitou R7 is still available. I've personally bought 3 Fox forks with v-brake bosses, and they're quite easy to rehab, and fairly cheap.
    ups and downs
    You can still find some V-brake SID Teams around at a decent price. The 80mm travel can be changed to 100mm by removing the spacer.
    Quote Originally Posted by rockyuphill
    Shiny. What's particularly nice about that fork is for $70 you can upgrade the rebound damper to the shimmed BB rebound damper. It makes a noticeable improvement in suspension performance, is cheap, and, in my opinion, works better than the full BB damper.
    http://www.universalcycles.com/shopp...5&category=705
    bikexor
    Reputation: derockus's Avatar
    White Brothers Forks have V-Brake options in 80mm and 100mm
    Little Shred Riding Hood
    Pedal Power
    Reputation: MalcolmTi's Avatar
    May 2010
    i recently picked up a rock shox tora sl (air) fork with both v mount and disk. right now i have my v brakes on but am going to switch to a disc soon. its nice because it offers both options. loving the fork for the price too.
    Why Ti?
    2009 and 2010 Rockshox SID Race or Team models were made with V brake bosses.
    Pricepoint has the 2009 Team on sale, I just picked up the 80mm for an older bike rebuild.
    Its very light and light years better than compared the Rockshox Jett it replaced.
    For 2011 the SID is no longer being made with V brake bosses. On the higher end forks, its getting harder to find ones for V brakes. If you see a nice fork, get it while you can.
    Blue Sky Cycling also recently had some 2009 Tora SLs on sale with V brake bosses, right around $199 or so which is a pretty good price. They were 120 mm travel but can be changed to 100 or 80mm.
    Hi.
    Reputation: jtmartino's Avatar
    I recently purchased a Magura Durin MD80 SL with v-brake bosses. I love the fork, it's ultralight and performs well for me (200 lbs XC rider.)
    I AM I AM
    Reputation: ducktape's Avatar
    I came across these when I was looking to buy an Identiti Rebate. Not sure if they would fit on the fatter legs of a supsension fork though, would be the best solution if they could!
    http://www.chainreactioncycles.com/M...?ModelID=20153
    Hi.
    Quote Originally Posted by ducktape
    I know it wouldn't look cool, but isn't there bolt on kind of v brake mounts that you can buy to put on any fork? I'm sure I've seen them somewhere, maybe mainly meant for rigid jumping forks though.
    Pretty sure I came across such a thing when looking to buy my Identiti Rebate.
    Big Cheese linear brake adapter through QBP.
    Former Bike Wrench
    Plenty of options or there is always the "Mullet" option with a Avid BB7 on the front.
