Results 1 to 6 of 6
    Jan 2013
    Upgrading a Manitou Black Elite - suggestions
    Hey guys, I'm thinking about upgrading my Manitou Black fork. I've been riding it pretty hard for the past 3 years; mainly trails, stairs (lots of stairs), wooded mountains (think lake district England) etc.
    It's been through a lot, I'm running it with transmission fluid right now and I replaced the original o-rings in the lockout with o-rings from a presta valve extender. Lockout cable is actually an old derailleur cable.
    So yeah, upgrade long overdue. So here's what I'm looking for:
    100mm
    Remote lockout (must be good design, I'm sick of this Manitou BS)
    9mm QR
    Around 3.5 lbs
    1 1/8 steerer tube
    Disc Only
    Easy to find parts for and service (I serviced my Manitou myself cause none of the shops I went to wanted to touch it)
    Preferably under $300, I don't mind buying used.
    I eagerly await recommendations. =)
    Manitou Minute Expert... great fork for they money, the damper is second to none. The minute pro is a little lighter if you have to have that, i think the expert is around 4.1 lbs and the pro is 3.6 lbs. the prices on used Rock Shox and Fox forx are crazy high for what you get IMO
    Reputation: Vespasianus's Avatar
    For you, something from SR Suntour should work well. Good luck.
    On MTBR, the reputation is infamous.
    Jan 2013
    Hmmm, the rest of the bike is not as dingy as how the fork sounds.
    It's an older rockhopper alu frame with a mix of XT/Saint parts, fulcrum red metal 3 wheelset. The fork is pretty much the part I've kept the longest without upgrading. So I hardly thinking a Suntour (read: Walmart) fork will cut it.
    I'm gonna scout fleabay for a Manitou Minute Pro I think. I've read some good things about the post 2010 models. I wonder how they compare to Rebas?
    Here's the bike btw, last post in that thread.
    Let's see your raw aluminium!
    Apr 2013
    Quote Originally Posted by Crank Monkey View Post
    I'm be curious as well.
    I'd love to toss this old Manitou Splice Elite.
    2005 FSR XC Comp
    2012 Roubaix SL3 Expert Compact
    Reputation: Aresab's Avatar
    If you look for used, the Minute 08 & 09 (named Elite & Super back then) can also be upgraded to the Absolute + damper, then they are effectively the same fork as the 10 - 12 pro models. I have an 08, a 10 and 11 (or 12) I believe, great forks the Pro line. I'm sure the Drake/Expert are as well. The damper is very tunable and pretty awesome at repeated hits with shims for both compression and rebound.
  1. Replies: 15
    Last Post: 02-12-2014, 10:31 AM
  2. keep upgrading or buy Superfly Al Elite?
    By Frugaltravelguy in forum Trek
    Last Post: 02-08-2013, 01:17 PM
  3. Upgrading 2007 Marzocchi MX Pro TAS/ETA to Manitou Minute Pro ?
    By pirati in forum Shocks and Suspension
    Last Post: 05-25-2012, 10:07 AM
  4. Need Manitou Black Elite spring cross reference.
    By WyldWeazel in forum Shocks and Suspension
    Last Post: 07-13-2011, 12:11 PM
  5. Manitou Black Elite Air increasing travel?
    By denises26 in forum Shocks and Suspension
    Last Post: 02-15-2011, 08:55 AM
