Results 1 to 10 of 10
    Short-Change-Hero
    Reputation: gregnash's Avatar
    Upgrade 2011/12 RS Rev RLT internals?
    So just finished putting together my bike and it is going to be a blast to ride. It currently has a 2011/12 RS Revelation RLT Dual Air (not dual position) that is internally adjustable travel.
    However, looking at the MoCo that it has it is basically the RL version of today (no low speed compression adjustment) and I was wondering if upgrading the damper to a newer RCT3 MoCo with the LSC (like this) is worth it? Will I notice a huge difference in being able to tune the MoCo and LSC? Current bike I have other than the Thumper is my Inbred with a 2011 Manitou Tower Pro which has not LSC so I guess I really don't know what I am missing but wondering, again, if upgrading the damper from the current RLT MoCo to the RCT3 MoCo is worth the $120?
    There is also this version that is a 2012 RLT with LSC MoCo for half the price, so wondering what the difference is.
    You'd get better use of your dollars by upgrading the rebound damper to the dual flow or the yet newer model they have. For the money, it would be better to sell your fork and buy a nice condition used rct3 revelation for around $400. Otherwise you'll be dumping money into a fork you'll never get back out of it.
    Also, I'm pretty sure the tower pro has LSC to lockout as an adjustment.
    Short-Change-Hero
    Quote Originally Posted by kan3 View Post
    Thanks for the info. I was wondering if that was the case or not but really wasn't sure if the upgrade was worth it at $120. Really I am somewhat holding out for a 34mm stanchion 29er offering from Manitou (e.g. 29er Mattoc).
    Yeah I did not realize that the ABS+ was considered a LSC, actually just found that out shortly after writing this post while looking on BikeRumor at their article on suspension adjustment.
    Reputation: mullen119's Avatar
    Revelations already come with a dual flow rebound damper.
    Also, the blue lever is a LSC adjustment on the RLT. You get 5 clicks with the last click completely closing the LSC causing lock out.
    Short-Change-Hero
    So what you are saying is that simply turning the blue knob is in essence a LSC adjustment but just does not have the fine tuning of the newer RLT/RCT3 with the blue knob and silver knob/dial on top?
    Quote Originally Posted by mullen119 View Post
    My 2011 revelation rlt did not have the blackbox dual flow rebound or moco cart. As far as I know you need to have a 2013+ to get the dual flow damper on all rev models but could have been 2012 that the rlt got it.
    Quote Originally Posted by gregnash View Post
    Yes, The blue knob controls LSC with the last click being completely closed. There is no difference between the new and old RLT dampers other than the spring tube material(MOCO DNA uses a different plastic). another thing to note is that the Gate knob works even when the LSC is wide open, you just wont feel it in a parking lot test. Its a crude form of HSC. The multiple clicks of LSC will be more noticeable on the trail then in your garage pushing down on the fork as well.
    The RCT3 damper uses a different design that gives a better range of adjustment.
    Thats surprising, but you could be right. My wife has a 2011 RLT and it came with dual flow, but it may have been the exception. I have had 3 and they all had it but I think they are all 2012+. Its easy to find out though, they are all labeled dual flow on the lowers by the rebound adjustment.
    Short-Change-Hero
    Ok well maybe your wife's is a 2011 but a 2012 model. You guys got me curious so I went out and looks and I do not have dual flow sticker anywhere on there, just Dual Air. So maybe mine is an early model 2011 or maybe they changed mid 2012 and it is a late 2011/early 2012.
    Either way I will run it for awhile and if Manitou ever comes out with a 34mm stanchion 29er fork then I will head towards that.
    Thanks for all the information though.
    Short-Change-Hero
    Coming back to this as I am still curious.. The Revvy as been doing great for me in the past year of riding. I really have no complaints other than tuning for the fork and the fact that it is only a 32mm stanchioned fork.
    I did contact SRAM with my S/N and found out that mine is a 46mm offset 2012 RL Dual Air. So wondering still if adding in a newer damper from an RCT3 will add anything more for me. I weigh 190ish (fluctuates from 185-193) outta the shower and about 210 completely kitted up (3L of water in pack with stuff) and as this bike pushes me faster and faster and hard and more aggressive on the downhill I am wondering if it would be worthwhile to upgrade later this year.
    Ultimately, if Manitou comes out with a 29er version of the Mattoc, no not interested in Fat or mid-Fat forks like the Magnum, then I will be selling the Revvy and trading in my old Tower for the Mattoc when it is released. But from talks with Manitou, while the 29er Mattoc is not out of the question it does not seem like a priority.
    Other thing is that I have noticed that I am not utilizing all the travel, I have a good 2" left on bigger hits and have the it set at -135/+125. The fork feels good, not harsh but wondering if I should lower the pressures as I did play with them recently and felt the fork was super harsh to the point of my hands being numb at the end of the ride.
    Short-Change-Hero
    Bueller? Bueller?
  1. What can i upgrade with my GT Avalanche 1.0 2011?
    By DarkFly3r in forum Beginner's Corner
    Last Post: 12-30-2011, 09:59 AM
  2. 2011 Stumpy FSR, what to upgrade
    By htjunkie in forum Specialized
    Last Post: 10-26-2011, 09:49 AM
  3. 2011 Q520 Upgrade
    By jacobhdylan in forum Felt
    Last Post: 08-03-2011, 08:11 PM
  4. Upgrade or 2011 Giant Reign or 2011 Yeti 575?
    By cesalec in forum All Mountain
    Last Post: 04-26-2011, 10:40 AM
  5. What are your upgrade plans for 2011
    By zgjp82 in forum Gary Fisher
    Last Post: 03-11-2011, 12:18 AM
