Results 1 to 2 of 2
    Upgrade 2002 Duke Damper - Possible?
    Is it possible to fit SID internals in a Duke? The damping on my fork hasn't worked for a long time and was hoping to resurrect this V-brake, uncut steerer to use again.
    I had it fully serviced with new Enduro seals and the mechanic said the problem is with a valve that is inconsistent in function...
    BikePedia, Suspension fork damper cartridge, RockShox 114311393000 "Dampers" - Full Item Description
    Former Bike Wrench
    Duke uses 30mm stanchions, SID currently uses 32mm and formerly used 28mm so the internals would either be too large or too small.
