Page 1 of 2 12 LastLast
Results 1 to 100 of 171
    Reputation: Nick_M2R's Avatar
    Tune Your Mission Control High Speed Shim Stack: How To Guide: Pics
    WARNING!
    Im not responsible if you damage your fork through hamfistedness or inexperiance working on suspension
    Hi all
    I have a 08 Lyrik coil u-turn on my Kona Bass, i love the fork, but i have noticed that i can blow through the travel REALLY easily, and the adjustment knobs seem to have no noticeable effect on the forks performance.
    The goal i wanted to acheive in tuning the highspeed shim stack was to try and retain small bump performance, but try and increase the bottom out resistance.
    This mod is really easy, no special tools are required, and accessing the shims can be done in about 5 mins with practice.
    This guide uses a lyrik mission control damper, and i see no reason why it shouldnt work for a totem. If you do not like the outcome, it is easy to return everything to a factory setting.
    Righto, time to show DA SHIMZ !
    Only tools required for this mod are as follows:
    > 24mm Socket
    > 4mm hex wrench
    > 1.5mm hex wrench
    > Shifter
    > Rags
    > Digital Vernier Calipers (for measuring the shims)
    > Frosty Beverage (for afterwards of course!)
    STEP 1:
    First, we gotta remove the Mission Control Damper. Make sure that the HSC knob is set at maximum hardness (turned fully right). You can tell if its in the correct position as the blue knob will be raised off the wrench flats.
    STEP 2:
    Next you'll want to take your wrench and tighten it on the LSC Knob, then using a 4mm hex, loosen the floodgate adjuster, then the LSC knob will just lift off.
    Next using you 1.5mm hex wrench, loosen the 2 grub screws holding the HSC knob on, then lift it off. Make sure you put the adjuster knobs in a safe place and dont loose em.
    STEP 3:
    Using your 24mm socket, loosen the Mission control top cap
    Once the threads are disengaged, lift the Mission Control damper out of the stanchion, dont yank it out, rock it gently from side to side and lift it out, a tip is to press the centre bit (where the LSC konb sits) down while you lift it out, as this will drain any oil in the floodgate assembly.
    Lift it out and use a rag to wipe away the residue oil, be very careful not do damage the grey piston glyde ring, i strongly suggest you CAREFULLY remove it and place it in a safe place to ensure you dont damage it
    STEP 4:
    Now that you have completely removed the Mission Control Damper, place it on a clean workbench.
    The shim stack is sandwiched between the flared end of the black tube (which i have pulled back to reveal a little black plate which sits inside the base of the black tube) and the gold piston. When you you adjust the HSC knob to make it harder, this black plate is screwed onto the shims, basically acting as a preload adjuster on them, increasing the HSC.
    Next you are going to want to grip the threaded part of the top cap and the gold piston at the bottom, then turn the piston to the left (left from looking at the bottom of the Mission Control Damper) which will unscrew it.
    You can now access the shim's (SHIMZ! ). The HSC compression shim stack is 3 same sized shims, i dont have any measurements though as my vernier calipers died, if someone could give the measurements id be very grateful.
    Now time to tune. Seeing as i wanted more progressiveness, i used a pyramid (sort off) stack. The 2 shims below the 3 originals are 2 same sized but larger shims which i had from an old roco, as the ID hole is the same (again, sorry i dont have measurements but will post them as soon as i have them.). My stack consisted of using a stock sized base shim with the two larger ones on top, but you may tune to your liking.
    I decided to stick to 3 shims, im not certain if you can add many more as the black preload plate (HSC adjust) may grind on them if there are to many. I also recommend you keep the stock shims separate in a safe place incase you want to return to factory spec.
    Install your shims back onto the piston, make sure you get the orientation correct.
    Then screw the piston back on. This is why it was important to make sure that you turned the HSC to max before working, as this makes sure the piston is screw onto the right depth on the threads.
    Thats it your done! Only thing left to do is to reinstall the gylde ring is you removed it, screw the damper back in and put the knobs on. Now this mode may take a bit of trial and error to get a perfect setting for you. You may have to take the damper apart a couple of times to find the perfect shim setting, but dissassembly gets easier the more you do it. I was extremely lucky that my first stack was near perfect for me and my weight (65kg (metric FTW )) Also you may have to check you oil volume if a large amount of oil spilled when you pulled the damper back. Measurement is 112mL of 5wt oil.
    Shim Measurements:
    Stock Shims:
    Outer Diameter: 20mm
    Inner Diamter: 8mm
    Thickness: 0.10mm
    Mod Shims:
    Outer Diameter: 21mm
    Inner Diameter: 8mm
    Thickness: 0.15
    Ride report:
    I have a couple days of riding on this moded fork....
    and all i can say is OMFG! It feels freaken awesome, my first shim stack is bloody perfect. The fork has a plushness that rivals that of my 66, meaning small bumps are almost non exsistant. Then about 3/4 of the way down, the larger shims kick in, significantly increasing the bottom out resistance. After a couple days of drops and jumps, i have only bottomed the fork once (and it was on a VERY scrappy landing)
    The Adjustment knobs also have a MUCH more noticeable effect on the damping, even the LSC feels better, which is odd because the LSC is seperate from the High speed shim stack, oh well i anit complaining . I have noticed that the HSC knob may feel as if its stiffer and grinding a little, but its nothing to worry about, ive turned it about a billion times in the last couple of days and nothing has gone wrong.
    So in the end, do i like this mod?
    **** YES!
    This fork now rips alot better on my bass as im nolonger bottoming the fork by riding off a step. Ill be posting up more long term riding reports as well as the measurements of the shims i used as soon as i have a working set of vernier calipers.
    Hope you found this little mod useful
    Enjoy!
    Thanks for posting that. I'll keep it in mind if I end up with a Lyrik and it's not Pushed. While I like the 36, there isn't really this level of adjustability, though there is one shim.
    I hope more manufacturers offer shim tuning options.
    No prob JC, glad to hear you liked it, if you end up getting a Lyrik and tune it, let us know how it goes
    Reputation: darkzeon's Avatar
    Yeah, I noticed this too on my Lyric, I'm 145lbs, using the stock red spring, which is rated for a 160lbs. minimum rider. I can still bottom the fork during jumps, even with 8-10 HSC. With my current spring the fork feels a little harsh on choppy terrain. When trail riding I only use 2 clicks of HSC,LSC. Nonetheless I'm still very happy with the fork, just need a softer spring for trail riding.
    Nick - How much do you weigh, and what spring are you using red, yellow?
    Folangag
    Im 65kg (im in australia, so metric all the way!) and use a stock red spring, gives me perfect sag
    Reputation: romar's Avatar
    Cool write up Nick! This sounds like just the mod I've been looking for. I'm 190Lbs.(or should I say 86.18Kg) and even with the firm spring in my Lyrik I experience a lot of pretty harsh bottom out. So if I'm understanding correctly, we're looking for different, or larger OD sizes on the shims with the same thickness?
    err, 27.5+
    Reputation: AL29er's Avatar
    Seriously, did you need to put a disclaimer on this All internet information is to be taken with a grain of salt. I appreciate the documentation of the suspension you have been putting up But I wouldn't hold it against you if I damaged something following your example. What is the world coming to.
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
    www.derbyrims.com
    Reputation: derby's Avatar
    Excellent documentary and your choice of shims is very educational. Without any experience doing this myself, the "mushroom" stack makes logical sense for better big hit speed sensitivity bringing increased progressive compression, and maintaining milder damping for the more moderate trail riding hits.
    There was a recent post here wondering when there will be PUSH tuning for the Lyrik to gain such a wider range of speed sensitivity for rebound. I wonder if doing a similar "mushroom" stack for the rebound piston would bring similar deep travel rebound increased damping landing jumps, while maintaining faster rebound for more moderate hits when trail riding.
    Replacing a couple shims is a lot less expensive than PUSH tuning for those who are mechanically inclined. Although I know PUSH also sometimes replaces the pistons and seals with better quality and always checks slider bushing and leg alignment and more with their service.
    I dig trails!
    Reputation: Mr.P's Avatar
    Feb 2005
    Nice one!
    Thanks for posting that up!
    This gives us another fork with tuning options.
    Lyric is on the short list now.
    P
    Cheers for all the positive responses guys
    Comments like that make me want to post more things like this up (Coming soon will be a DHX Air rebuild Guide )
    Haha Yea i know, i put that warning there for the little kids who are flat out turning a wrench who try to do some stuff to there forks, then screw it up and come crying to me about how i broke their fork
    Cheers for the comments mate
    The mushroom stack was what i was thinking from the start, when i first seen that the shim stack was 3 same sizied shims, it made perfect sense why the fork felt so linear. Because the shims didnt get larger, oil just sort of blew through them, and i reckon thats why the HSC knob had little effect. I thought that adding to larger shims on top of a stock one would give me the damping i was looking for, plush in the first 3/4 travel, then stiffen up towards the bottom, and as i said my dampening is now bang on plus the HSC Knob now feels as if its doing something. As soon as i track down a pair of calipers ill get measurements of the shims i used
    Yep thats what you want, the shims i used are the same thickness and ID, but larger OD
    Nice one!
    P
    Cheers Mr. P
    Also thank must goto you, as your TST shim mod was what inspired me to do this, as well as provide alot of info
    Feb 2007
    i want to do this mod - where to get these size shims???
    my lyrik (and totem) needs this mod. i'm doing it if i can find the shims. but what size are the shims and where to get them?
    I dont have exact measurements for the shims, i reused some shims from my old ROCO that died because the ID was the same as the stock ones
    Try MXTech.com for shims
    Petty and weak
    Reputation: Gruntled's Avatar
    You''re a champ. I'm gonna take apart my old mission control and see what goes, if I can find a supplier for da shimz of course!
    ~ Downride and Freehill, nothing else ~
    Righto people an update
    So far i have one 25km cross country epic and numerous runs on our new DH trail on the moded fork and all i can say is that i am in love! The dampening in this baby is so much better than before. Also nothing broken to report, its solid as a rock
    Reputation: sanjosedre's Avatar
    This page is definitely getting bookmarked,
    awesome stuff man i appreciate the effort & documentation.
    Reputation: PUSHIND's Avatar
    I'm confused....are the two shims that you changed the same thickness as the originals, but just larger in diameter?
    Darren
    Reputation: flipnidaho's Avatar
    Is the Lyrik MC cart the same as what is used in the Totem?
    Darren: Same thickness, larger OD
    Flip: i dont see why the totem MC would be any different, besides being slightly larger
    huh.....using a larger OD but the same thickness shouldn't produce any change especially to bottoming resistance because the shims are all bending at the same rate when stacked on top of each other. If you used a separating shim to build a two stage stack you might see something but even then it would be difficult because the shims are under preload from the HS spring and the secondary stack may be pushed into the initial stack when static.
    I'm guessing if you noticed a difference in bottoming control it's coming from a slight increase in oil level in the damper leg which would give you an increase in spring rate at the end of the stroke.
    Darren
    Darren:
    There isnt any bottoming increase from the oil level, as i havent increased the oil level at oil, might even be a little low as you loose some oil when you remove the damper
    With regard to the shim thickness, truth be told i dont have exact measurements as my calipers have died and wont be able to buy new ones till i got to the city next weekend. As of now ive only used a REALLY old set of micrometer's, but i wouldnt trust the measurements. The new shims maybe a tad thicker, or even still you maybe correct and the BO increase is all in my head, either way it like how the fork feels now, it does have an increase in bottom out aswell as the adjusters now feel as if they are doing something
    I had considered using a two stage stack, but was worried that the HSC preload bolt would start grinding on the shims, as there where only 3 shims in there to begin with, but i may try a bit of fiddling and see what happens
    Also just to clear up in no way do i mean to sound like a prick, i actually appreciate your comments, helps me understand even more about these things and ways to improve it
    LOL.....Understood, I actually didn't take it that way.
    As for the shims, the thickness increments are 0.1mm, 0.15mm, and 0.2mm so you'd be able to tell the stiffness difference in your fingers without having to measure them. If you can't feel the difference with your fingers, they're probably the same.
    In thinking about this further, another factor maybe the height that you set the jam nut when reassembling the MC unit. Increasing or decreasing the height of the jam nut would change the static height of the HS circuit therefore influencing the damping range that you get as well as the range that the adjusters are effecting. So, if in reassembling your jam nut height was higher than how it came from the factory, you would experience the increased compression force throughout the entire range. As I sit here typing I also just realized that the jam nut height has an effect on the Floodgate range as well.....so many things to consider!
    Darren.
    Quote Originally Posted by PUSHIND
    Darren.
    Haha cheers for that, just didnt want you to think i was being a prick bout it haha
    Yep just check the shims with my fingers in the way you described, the 2 i put in there are definitely stiffer than the stock ones, which feel really flimsy.
    Now that you mentioned it, i agree with you about the jam nut, having it set at a different point would make a difference on when the HSC engages as it changes when the oil hits it right?, i may have set it a wee bit higher
    One bloke on pinkbike said i sould remove the Floodgate base plate from the bottom so i get full use from my mod as MUCH more oil will flow through it, although i dont really want to loose the platform, makes the 25km desert races much more bearable
    Okay, with that being the case then you've effectively shifted the force curve on compression. The positive is that the increase in compression force will be better for single impacts, the negative being that you'll decrease initial bump sensitivity and cause the fork to be less reactive to impacts such as breaking bumps. This is exactly why we often install new pistons into forks and shocks. It allows us to balance the two by using firmer shimming for control, but different port volume and shape to allow the shims to open more rapidly under bump forces.
    Funny thing is, doing what you're doing is what got me my start more than 20 years ago in a garage in Northern Maine. I'm still playing with the same stuff, just now with the advantage of powerful software programs, on-board data logging, and a suspension dynamometer!
    Best of luck!
    Darren
    Hey Darren-Totem Service
    Hey Darren!
    Any word on Totem tuning at Push?
    www.derbyrims.com
    Thanks Darren! Very interesting analysis. Your years of tweaking shocks is worth every dollar of a PUSH tune, and really much more.
    Righto people, an update, i finally have measurements of the shims
    the stock shims measurements are as follows:
    Inner Diameter: 8mm
    Thickness: 0.10mm
    And my replacement shim measurements are as follows:
    Outer DIameter: 21mm
    Inner Diameter: 8mm
    Thickness: 0.15mm
    Reputation: bjj4202000's Avatar
    Darren
    Of note--I have tuned a couple of forks (motor bikes) with greater OD shims of original thickness to achieve greater compression damping (my logic being less flow around the edges of the shim causing greater deflection). This does not affect bottom out resistance but could give a similar effect if there is greater compression. I will digress, however, both instances involved open bath systems so my results may not be relevant here.
    Nick_M2R, congrats on the topic and the mod!!!
    Keep us posted on our feeling on it!
    Cheers Marcolino!
    This mod has really livened up my lyrik, it nolonger bottoms going of steps, the compression dials now have a noticeable effect on the damping, and it has much more bottom out resistance, this thing now rocks on my Bass, a very worthwhile little mod
    So, I'm finally getting to this mod on my Lyrik as it's been feeling kinda dead lately. After I had the MC apart I was inspecting the piston. Looking through the HSC port holes I noticed some gunky looking stuff inside the piston. So I dug a little deeper into the piston by removing the inner c-clip and found this:
    It appears to be some sort of o-ring or seal although it feels a bit to brittle and if it is, what is it supposed to seal? As you can tell it is way distorted and blocking the ports in the piston. Anyone have any clues what this is supposed to look like?
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    It's part of the Floodgate system. The first pic is all four pieces (from a Totem and Lyrik), while the second pic shows the part in question in new condition (again one from a Totem and one from a Lyrik, they are just flipped to show both sides).
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    Reputation: Gman086's Avatar
    What would you accomplish by removing the floodgate? Seems to me there would be no noticable diff between running with the adjuster fully open versus removing it altogether? I think a lot of users just don't get that the adjuster has an affect even with floodgate off. I can't imagine running with no floodgate; would dive like crazy then and you'd bottom out way too easily! Correct me if I'm wrong.
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    Nightmare on Lyrik st. VI
    Reputation: amrgb's Avatar
    That's the whole point of removing the floodgate. You like the additional low speed compression given by the floodgate even when it is set to open. Others don't. Many people who removed the floodgate are using heavier oil to get more compression. The advantage of removing the floodgate seems to be a better sensitivity to small bumps, even with the heavier oil.
    Quote Originally Posted by TNC to whining spammer
    Don't let the nose of your saddle hit you in the @#!#X on the way out.
    Quote Originally Posted by amrgb
    Ah! Heavier weight oil would make sense then! Lot of different ways to skin a cat. I do like how mine (Lyrik Solo Air) feels now tho but do need more bottom out resistance for FR... so what to do? Probably just add a thicker shim like the OP suggested? I can prevent bottom out by cranking the HS comp damping in more than 6 clicks but then it's harsh over square edge hits.
    Thanks,
    G
    If you are willing to try, I think you could put more oil in the air chamber to make it more progressive. I haven't tested this theory yet, because I'm having constant problems with the fork and I can't even ride for long enough trouble free to tune the damn thing (right now I have oil migrating from the lowers to the damper, can you believe that).
    I opened a thread to discuss that, and one concern that was raised, is the extra oil migrating to the negative chamber, negating the benefit of adding oil or even screwing up the spring rate even more.
    Romar, that hard o-ring piece looked the same misshaped way in my lyrik too. I took that as evidence that oil flow was pushing it against the high speed ports and hence misshaped it, and that people on here where right about it limiting oil flow. I took mine out.
    Funny how everyones view on how the damping of the lyrik needs to be changed are different. I thought small bump sensitivity and also low speed damping was to stiff so I run 2.5wt oil in the damper with the low and high speed full fast. Like that alot. But I do have the UT coil with the RS suggested spring for my weight and seems like some run a lighter spring than RS recomendations.
    Thanks all for your comments, and pipes10 thanks for the pic. I'm going to run the fork without the floodgate guts, play around with some different oil weights and see how it is.
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    To add to pipes10's post.
    I just removed my MC this weekend. Haven't had a chance to ride it yet, but I took some pics of the process.
    1. before removal
    2. the 4 pieces you remove, from left to right.
    -retaining ring
    -brass plunger
    -rubber o-ring
    -shim
    3. after it's been removed
    Reputation: Karve's Avatar
    Mar 2006
    Quote Originally Posted by romar
    Here is an explanation of what that does - the weird squashed thing looks like its the blow off valve on the floodgate.
    http://autobus.cyclingnews.com/tech....of_piston_body
    So by removing the floodgate, do we basically turn our damper into a copy of the new mission control DH damper?
    Quote Originally Posted by Nick_M2R
    little more than that. The dh dampener has high/low speed rebound on a larger shaft moving more oil.
    I was looking for more bottom out resistance and ended up putting the floodgate back in to slow things down a bit.
    Feb 2007
    a belated "thanks"....
    Inner Diameter: 8mm
    Thickness: 0.10mm
    Inner Diameter: 8mm
    Thickness: 0.15mm
    nick you're a champ! now, i'm gonna do it to mine. sorry i took so long to get back to this and thank you.
    No prob Mr.Niles, hope it works out well for ya!
    Feb 2007
    nick - one question....
    about the orientation of the shims....
    did you place your largest shim over the piston ports, or are the stock shims over the piston ports with the larger shim stacked on them?
    do this make sense? most shim stacks i've seen are pyramidal with the largest shim covering the ports, then the smaller shims are stacked on top of that in succession large-to-small, thus forming "pyramid" or "cone" shape. are yours stacked like this over the ports?
    Yep the largest shims where placed on the piston port side, while the stock one is ontop (contacting the black jam nut)
    Mar 2006
    So is the shape of the shims actually doing any thing or is it just the fact that you are pr4eloading the HS by 50% more than before
    Yes the shims are actually doing something.
    I wind the knobs all the way off, the fork dives all over the places, wind it on and it feels alot stiffer, the HSC now has a noticeable effect, unlike before.
    I tried fiddling round with different configs, like removing the stock shim and replacing it with a larger and thicker one to completement the others. Fork felt VERY stiff, way to rough over the bumpy stuff and it would lock up on the whoops on our little pump track
    Either way the shim mod does have an effect, the HSC adjuster now actually does something and the fork nolonger bottoms on small drops
    Quote Originally Posted by Ratt
    Ratt, i didnīt understand completly...
    You mean the dh dampener is different, with more adjustments?
    The Mission Control damper dosent have more adjustments. Its basically a regular Mission Control damper minus a few things. There is no floodgate in the MiCo DH, instead it is replaced with a High Flow piston, which great increases oil flow around piston/shim area, meaning a much mroe supple and plush ride for DH riding
    Nick M2R, with your current set up, how many mm of preload if any are you puting on the HS spring when HS is set to full fast or min preload? Has this changed any from stock?
    Quote Originally Posted by Marcolino
    The DH rebound shaft is increased from 12mm to 19mm to force much more oil through the compression circuit.
    On the Boxxer the Beginning stroke and Ending stroke (low/high speed) rebound are externally adjustable. On the single crown forks only the beginning stroke is adjustable and the End stroke is preset from the factory internally. I think the non-dh rebound is low speed only.
    I was looking for more bottom out resistance, so I actually put the floodgate back in and pre-loaded the HS spring by bottoming out the jam nut to the main shaft. Have better bottom out resistance but the fork is a bit harsh on the chatter bumps compared to the fork without the floodgate and no preload. Going play with the shim stack next.
    I got it now! Nice explanation!
    I guess with a bit of shim stack testing you will be on the right track!
    So if I wanted to have less HSC and a more plush fork overall could I just remove one or two of the shims? From reading through the post it seems like the stock shims are as thin as they come (.10), and not sure I want to completely remove the flood gate.
    How much do you weigh?
    Quote Originally Posted by WhistlerMike
    No i would not recommend that, I'd first remove the floodgate (if this is still off the table go to step 2), second make sure with the hsc all the way open that the upper spring is not putting any pre-load on the shim stack, and third try a lighter oil.
    After reading into this further I'm going to try removing the floodgate, don't think I've ever used it anyway. Will do this tomorrow morning and post results.
    I weigh 155 lbs.
    Great write-up by the way!
    This is good advise. Allthought you could try the lighter oil (2.5wt) and HS preload seting 1st if you actually use your lockout any. I've done those 3 to my lyrik and I like it a lot better. And I am heavier than most and running the extra firm spring. I know small bump has to be harsh for small riders running the lighter rate springs.
    Roll on Spring Time!
    Reputation: juan pablo's Avatar
    I found a link to this thread and think its worth reviving for an update.
    Sounds like I was right when I thought my high speed adjustment wasnt really helping on bottom out. With the same 7' drop my 36RC2 seems to handle better than my Totem and I bought my Totem thinking it would help in my progression to more DH riding and bigger freeride hits. I seem to make up the lack of HSC by winding up my LSC when I freeride which doesnt help for DH where I lose small bump sensitivity. I run my HSC 2 full turns with half a turn left and use full travel on said 7' drop.
    DH setting 6 clicks LSC and11/2 turns of HSC
    FR setting 10 clicks of LSC and 2 turns of HSC
    My HSC doesnt click hencs reference to full turns etc.
    I do some milage with the Maelstrom so the floodgate helps on long climbs which means I am not rushing to remove this feature. Any updates on shims etc? I will have to see what I can find in South Korea.
    Quote Originally Posted by juan pablo
    hi jaun
    unfortunatly the only place I've found that sells shims internationally is mxtech.com
    Just in case anyone wants to order custom shims for cheap:
    http://www.misumi-ec.com/usa/eusaen/...300237240.html
    I just looked at this site and the problem that I see is that they don't show an applicable material for shock absorber shims. The materials that they have listed won't work. Just FYI before you spend the money.
    Darren
    Darren
    I am curious as to what material is required. I never really realized there were choices in the matter. The site has low carbon steel, brass (C2801P), and 304 stainless steel. Can you school us on what the number designators mean also? I know low carbon steel makes it less flexible, more tightly packed molecules so I can see that being an issue where they may be more brittle but that is just theoretical deduction on my part.
    Darren
    Well that sucks, since I just ordered some low carbon steel ones!
    The problem is, in my application they're for an old Fox Alps shock, and I haven't found the size I need anywhere else.
    Stray Bullet
    Reputation: Nagaredama's Avatar
    You want shims from these guys.
    http://www.mx-tech.com/?cat=12&id=products
    Those steel shims wouldn't bend at all. They're designed for something completely different.
    Quote Originally Posted by Nagaredama
    I tried MX Tech and it's a no go. I need two shims with ID of 10mm and an OD of 18mm and 28mm.
    Will they not flex even though they're only 0.1mm thick?
    Just wanted to post my results after removing the floodgate. It feels like it breaks away a bit faster on high speed compression hits, which is exactly what I was looking for, and no downsides at all. Functions the same as before while pedaling, don't notice any excessive dive while cornering, and I never used the floodgate anyway, so great mod. Livens up the fork a lot. and really good instructions
    I be damned if I can unscrew the compression piston. I got a 2010 mission control damper and I was curious to take it apart. But it doesn't budge and my hands are already screwed up.
    Nick, how hard was it to unscrew yours? Maybe a little oil will help.
    But I can see that the new damper has 3 shims but all of different diameter.
  67. #67
    [QUOTE=amrgb]I be damned if I can unscrew the compression piston. I got a 2010 mission control damper and I was curious to take it apart. But it doesn't budge and my hands are already screwed up.
    QUOTE]
    Hi mate
    Mine was actually pretty easy to undo. It was by pure chance that i undone it anyway. I was holding the base (piston) while i was turning the HSC knob back and then noticed that i had undone the piston at the same time. Try giving it a shot of oil, hopefully that should loosen things up abit
  68. #68
    Jan 2009
    I did mine acouple of months ago 'solo air' with the same results. It was a awsome fork before and now its even better.
  69. #69
    HI,
    I have a 2010 Totem Coil with Mission Control DH and the fork doesn`t work well on small bumps! I will change the shims now - my question to get a smooth fork on small pumps: should be the outer Diameter of the shims bigger or smaller than the standard shims??
  70. #70
    So, I took everything apart..thank you for this thread. So far I have removed the floodgate and dialed in the HS compression shim stack. I did this because removing the floodgata on the SA made the fork blow through it's travel. I was hoping to compensate with heavier oils an attempt to get the HS stack to engage a little earlier in the travel. Funny thing, at least on the SA. All of this has really affected the rebound top out. It has absolutely no damping near the top end of the rebound. It appears that fiddling with the HS compression eases this a little, but still much too harsh. I have to add a bit more air as well which makes things rough on the small stuff
    We did the same service on (minus the HS shim mod) on my buddy's Totem Coil and it does seem to be an improvement. I guess the coil provides quite a bit more mid-stroke and is already quite progressive by design.
    My initial feelings are that this is not necessarily for the SA. I would be interested in the shim mod, but not sure where to get my hands on some shims. It's not like I got spare shocks just hangin' around that I can pillage.
  71. #71
    FYI...The upgraded Mission Control has a "mushroom stack" and the sleeve has been modified.,,,
    I went ahead and ordered the DH version as well for comparison along with the coil assembly. Should be good times
    It consists of about 5 shims going from widest to shortest from bottom to top.
  72. #72
    Boyeeee
    Reputation: BCBlur's Avatar
    Quote Originally Posted by Mtn. Biker123
    I did the mod last night and got out for a quick ride thismorning. I noticed the rebound was off, but didn't have enough time to put my finger on it.
    The problem is that the small plastic piece (round on one end, hexagonal on the other) was deformed and I'd rather not put it back in like that. How much did that DH damper run?
  73. #73
    Quote Originally Posted by BCBlur
    You should call SRAM and tell them about it. the deformed piece should have had a silver shim behind it? That's the way mine was, anyhow. That ring should keep the plastic from leeching into the ports. I think that would be a factory defect and that's why no oil is moving through those ports. This mod does not due justice to this particular fork, probably makes it worse in a lot of ways. Works better on the coil IMO. However, the new damper is friggin' sweet. You should get this one if SRAM decides to warranty the part.
  74. #74
    Boyeeee
    Yeah, it had a shim behind it. When I pulled the "button" out, I saw that it was a bit deformed. I'll give them a call next week.
    Did you get the damper direct from SRAM?
  75. #75
    No. All warranties must be done through a shop. If you are on good account with a local shop they should be able to handle it for you. Mine was not deformed in the least, but I have only been on the fork for a few weeks. I wasn't sure if that was indeed a shim or by the looks of the yours and the others just a buffer between blow off and the port. SRAM will not send you the new blow off, they don't even have a schematic for the tear down of the MC . No one there knew anything about the individual parts of the MC damper. They will likely just send you the new and improved damper. Well worth the wait if that is the fact.
  76. #76
    Boyeeee
    Mine has only been on the bike since early September and I haven't had a lot of time for riding lately...
    I'll hit up my local shop when I can, but it seems odd to replace the whole damper when a 5 cent piece is the trouble.
  77. #77
    You should have no problems. I asked and the do not even sell the individual parts nor to they even service the MC. They just send out the updated assembly
  78. #78
    Feb 2007
    anyone taken apart one of the new 2010 mc dampers and measured the new shims yet? i am curious what sizes are being used for the new damper.
    i've decided to re-shim my lyriks on my freeride bike and am bike. i ordered shims from avalanche (although they can be ordered from racetech and mx-tech). i may do a three shim stack for the freeride bike of 19mm x 0.20 / 20mm x 0.15 / 21mm x 0.10 with atf for oil. this should also add some spring preload, too. for the am bike i may try a 19mm x 0.15 / 20mm x 0.15 with atf for oil.
    we'll see.......
  79. #79
    Jan 2009
    Does anybody know where i can get an exploded diagramm of the mc-unit
  80. #80
    Evlkneevljr
    Reputation: daverach2478's Avatar
    This is about the closest I found: http://www.cyclingnews.com/features/...control-damper
    It has a couple pics on there and highlights the circuits used during a certain activity (HSC, LSC, etc.).
    Does anyone have a new DH MiCo damper for a Totem? I'm wondering what the size/thickness of all the shims are on those? I hear they are like a pyramid stack unlike the standard/old MiCo.
    I like bacon.
  81. #81
    Hey, I came across this tutorial, but i cant get the gold piston to unscrew. Theres no special tools required are there?
  82. #82
    Quote Originally Posted by kingloryrider
    Just pull it out, it does not unscrew.
  83. #83
    Sorry a clear up, 5 post above, the circle gold peice of metal with oil ports on it. Doesn't it unscrew from the mission control assembly so I can get to the shims?
  84. #84
    Reputation: Hiramson's Avatar
    Great!
  85. #85
    kingloryrider, join the club.
    I held the bottom of the MiCO, the golden piece with orifices, with a rag, and I went to the point of removing the gold (from slipping in the rag) out of that piece before quitting. Mine has to be glued or something. Good luck with yours. If you manage to unscrew it, let me know. I might give it another try.
  86. #86
    i just rebuilt them,with lighteroil.amixof 2.5 and 15, mainly 2.5.
    My enital problems wheres stiction, and snail slow rebound. now the forks obvisouly a bit more lively. I will just have to bring the pump with me everywhere to adjust the air pressure accordingly.
    I heard this somewhere, but i imagine the seals blowing, can you put say 30ml in speed lube to make it more progressive? or like 35ml?
    unscrewing the mission is hopeless for me.
  87. #87
    Not in the lowers (bath oil). It will just hydrolock without a noticeable change in progressiveness. But you can increase the volume of oil in the damper to achieve more progressiveness without hydrolocking, since that is more or less air tight, unlike the lower. But be prepared for blown seals. I've blown 3 sets of seals in the MiCo without running extra oil. Imagine with excess oil creating pressure.
  88. #88
    Hi guys!
    I own a Lyrik 2008 2 Step. It's the IS-Version with Motion control.
    Works good so far, but I would be happy about a bit more HS-compression.
    Anyone any idea?
    Othe thing is, that the fork lost travel, typical problem. When the bike stands on the floor, travel is down at about 150mm.
    I thinking that the 2Step side has no damping in it. What about using 0W40 engine oil? Has much better lubricating.
    Any solutions?
    Thank you
    Reno
  89. #89
    ive got a '10 totem solo air and i was wondering if i can mod the shim stack. my problem isnt bottoming out, its hardly ever using the full travel, barely ever using the last inch. its not im not riding difficult enough trails. im not using very much air pressure in it either so itd be nice if i could fix it by changing shims.
    thanks
    I hope your car has a big trunk because I am going to put my bike in it.
  90. #90
    Quote Originally Posted by mtnbikinggolfer
    thanks
    Yes you can mod the shim stack to give a softer compression range, but before you do this, make sure that the reason you not getting full travel is because oil is leaking from the Mission Control chamber into the bottom of the fork leg causing hydrolock
  91. #91
    Calm Like a Bomb
    You can also try decreasing the oil volume in the air spring upper tube by a few ccs.
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
  92. #92
    I dig trails!
    Feb 2005
    pinkbike has a great video of removing the floodgate:
    http://www.pinkbike.com/news/technic...-mod-2010.html
    happy modding!
    P
  93. #93
    EDIT so to check if oils leaking all i have to do is check to make sure oil is in the mission control chamber, right? if it were the case that oil was leaking i wouldnt notice by the lack of oil in the mission control chamber, right? also the mission control adjustments dont seem to do much to the fork so is that also a sign of hydrolock? EDIT
  94. #94
    Oct 2010
    For all of you having problems unscrewing the golden piston from the damper and still reading:
    Take a 14mm wrench and screw the black jam nut a bit further onto the silver shaft (just a 1/4 turn cw). That will reduce the pressure onto the shims/piston and it should be unscrewed easily. Worked for me on both, MC and MCDH.
    By the way to keep measurements updated:
    the 2010 MC damper has 6 shims in a two stage stack (all 0.1mm, ID 8mm). ODīs from bottom/piston to top: 20 - 20 - 13 - 20 - 17 - 13 mm
    2010 MCDH is the same but has 7 shims: 20 - 20 - 13 - 20 - 20 - 17 - 13 mm
  95. #95
    Quote Originally Posted by Sceh
    ...the 2010 MC damper has 6 shims in a two stage stack (all 0.1mm, ID 8mm). ODīs from bottom/piston to top: 20 - 20 - 13 - 20 - 17 - 13 mm
    Thanks, was going to re-shim my 3 shim '08 totem but didn't know where to start, this looks good.
  96. #96
    Dec 2009
    How do you fix this? I've thought that this has been the problem with mine for a while, but thought it was just excess fluid hanging about.
    Cheers,
  97. #97
    Dec 2009
    Bump
    So, did a service on my forks about 30mins ago, oil measurements/oil weight all correct. But, still feel like crap.
    However, you would expect quite a bit of fluid to come out of the damper side lower section if oil had been leaking from the damper housing into the lower section, but there seemed to be nothing, except from a little bit, which is probably just some 15wt which should be there anyway.
    Has anyone got any ideas what might be going wrong?
    Cheers, Ryan.
  98. #98
    Reputation: d.n.s's Avatar
    any ideas on upgrading motion control damper? have bottom out problems too.
    I'm from Ukraine, Kiev
    I'm graphics and web designer
    Follow me on Behance
  99. #99
    Quote Originally Posted by d.n.s
    There are 4 ways you can go; air/spring, oil, shim, or have a pro mod your fork.
    You can increase the air pressure or spring rate. If solo air, switch to spring or reduce the air volume in the chamber to cause more progression at the end of stroke.
    Check your oil levels, you maybe low. If spot on maybe go Zokie style and add more oil to your fork to increase progression at the end of stroke.
    What year is your fork? Pre '10 only have 3 shims, newer forks have 6-7. You could try re-shimming your fork.
  100. #100
    i have 2007 pike 426 coil u-turn. i've already ordered custom progressive spring, but really don't know about re-shimming. Don't want to reassemble damper for now, will see what new spring will do.
