    Jan 2013
    TK damper to MC damper- is it possible?
    I have RS Recon Silver TK (2011) fork with steel legs. Can I upgrade turnkey damper to Motion control damper from Reba?
    Reputation: mullen119's Avatar
    No, but you can use a MoCo damper from the Argyle
    Jan 2013
    Quote Originally Posted by mullen119 View Post
    Why no?
    The internal diameter(ID) of the aluminum stanchions from a Reba is different then the ID of the steel stanchions of you Recon. You can switch dampers, but you have to use a damper from a different steel stanchioned, 32mm Rock Shox fork. In your case, the only option is the Argyle.
