Results 1 to 5 of 5
    is there an 05 AVA RP3??
    Does anyone know if a FLOAT AVA RP3 exist for 05
    Also, what is the diff between a Float R and Float RP3 apart from the P3 (ie propedal)
    tia
    Cheers
    Do It Yourself
    Reputation: Homebrew's Avatar
    They do have a 05 AVA but it's OEM on some FR/DH bikes. It's not needed for the most part because they retuned the Floats for 2005 so they have about the same spring rate as the 2004 AVA at max. volume. There isn't any difference between the Float R and Float RP3 other than the 3 position ProPedal adjustment. Personally, I don't see much use for the RP3 since you can get a Float R with PUSH Industries custom tuning for the same price. Factory set by the experts just for you and your bike largely eliminates the need for adjustment.
    Long Live Long Rides
    Quote Originally Posted by Homebrew
    thanks for the info...
    The only prob with trying to PUSH a float is if you live overseas.. PUSH does not do international orders yet..
    not so super...
    Reputation: SSINGA's Avatar
    Quote Originally Posted by littlejohn
    Push may not directly do international but TF Tuned Shocks does. They are the European arm for PUSH.
    Nothing to see here.
    Quote Originally Posted by SSINGA
    BUGGER!!!!!!!!!!!!!!!!!!!!!!!!!!
    Wish i had of known this before I ordered
  1. 05 Salty + RP3 --travel issues revisited
    By el Turtlehead in forum Ventana
    Last Post: 02-18-2005, 11:03 AM
  2. Fox AVA vs. RP3 shock
    By thegood in forum Ellsworth
    Last Post: 02-10-2005, 12:19 PM
  3. Fox rp3 AVA....
    By scheckler in forum Shocks and Suspension
    Last Post: 01-25-2005, 01:12 PM
  4. Fox RP3 vrs. '05 Float?
    By Jaybo in forum Shocks and Suspension
    Last Post: 01-19-2005, 06:48 PM
  5. 05 5 Spot: Is RP3 only option?
    By TIGMAN in forum Turner
    Last Post: 11-30-2004, 07:33 AM
