Talas to Float conversion
I have a 2012 talas 150 that im thinking about getting converted to a float 150.
I never use the adjustment on the talas and have heard that the float is a smoother fork.
Has anyone done a conversion and how does the fork perform afterward? Is it worth the 250ish to have it done or would I be better off buying a Float 150?
The float system is generally plusher and overall gives a better ride. With that said, it should not cost $250 to go to the Float. Closer to $100. It is a very easy mod that you can do at home. Fox will also sell you the parts directly.
I just double checked and its actually 225, and includes a complete rebuild.
Why wait?
You'll have a real Float after Fox does the swap and service for you.
When it is done, you'll have a fork that feels smoother throughout the entire stroke with better small bump compliance.
If you do the swap yourself you can do it for $100+. You can do a basic service of the fork yourself for about $40. The damper service is where things get tricky if you haven't done it before and don't have proper tools.
The full rebuild from Fox can be a good deal since it includes damper service along with full seal service and fluid change.
$225 is a very fair deal for the conversion, seal, fluid, and damper service if you aren't going to do the work yourself.
Oh. For a complete rebuild, that seems about right.
Why not just do the work yourself? It's easy.
After converting from talas to float will you save weight also? If so how much? Thx
Is the weight saving the same as the two different models?
Yes, converting from a Talas to a Float will save you weight.
just had it done on my talas 120/160, the front end feels more nimble (something like a 0.2lb weight difference), and the fork is way more active, pretty sweet upgrade
Hey Darnelli, how much did the conversion cost ya. I'm considering swapping mine over also.
around 80-90 bucks parts (another 30+ for new skf seals)
Thanks apparently I can get it done here for $200 aud so fully serviced and lowered to 150mm
- You may not post replies
- You may not edit your posts
Forum Rules
