Results 1 to 3 of 3
    Christoph NorCal
    Stuck Chris King bearing cap on fork
    Hello,
    I am trying to remove my 2008 XC 800 TST 2 fork from my 2002 Isis Ellsworth frame. It appears that the chris king bearing cap is frozen on the steering tube. I've tried tapping the steering tube with a metal hammer and also putting liquid wrench on the bearing cap -- no go. I even went to my LBS and they were unable to get the fork off. Any suggestions besides hitting it with a sledge hammer
    I want to salvage the fork because I am sending it to Marzocchi for service. Last time the fork was serviced was Sept 2010 so the fork has been on the frame just under 3 years.
    CC
    Climb, climb, climb, work harder suffer less....
    Quote Originally Posted by ccastro View Post
    Hello,
    The "Gripnut" under the stem? Should just have an o-ring that contacts the steer tube.
    Christoph NorCal
    I finally removed the stuck Chris King bearing cap. I use a Dremel tool with the 195 high speed cutter and 9911 Tungsten carbide cutter. I cut a nice vertical slot into the bearing cap being careful not to hit the bearing or fork tube. Once I had a nice slot open up I use a wide blade screw driver and gave it a few whacks from the side. That broke the bearing cap loose and the fork came out.
    CC
  1. chris king inset 1 (sealed bearing) serviceable?
    By LGavin in forum Bike and Frame discussion
    Last Post: 11-21-2012, 05:52 AM
  2. Replies: 1
    Last Post: 09-15-2012, 05:06 PM
  3. Grease on top of Chris King headset cartridge bearing?
    By Krause in forum General Discussion
    Last Post: 09-08-2012, 10:58 AM
  4. Chris King 20mm Front Hub Bearing Removal
    By Freerider in forum Wheels and Tires
    Last Post: 11-24-2011, 12:24 PM
  5. Chris King hub adjusting collar stuck
    By MRC in forum Wheels and Tires
    Last Post: 02-14-2011, 08:13 PM
