I have an old 1999 Psycle Werks WildHare with an old Startos Helix coil shock. Well it finally took a dump. The little internal bottom out spring broke and was rubbing and causing a ton of noise.
I dont want to spend a ton of money but I want to keep the bike in working order. The shock is a 6.5 X 1.5 which I know is not common by todays standards. Any suggestions on what the best option would be to replace it? I have an old 1999 Fox Float R but it totally sucks. No matter how much air I put in it I always get 50% sag. Im 210 lbs and I have over 250 lbs of pressure in the shock and still get 50% sag which is why I went with the coil.
