Does the Specialized/FOX Triad II with autosag (stock on the 2012 Stumpy FSR Comp) use the same air sleeve seal kit as the Float shocks...?
Yes. There is only one Fox Float air sleeve kit. I even used that kit to rebuild a 2004 Fox rear shock this past Monday. You may have an extra o-ring after the rebuild... mk
TrailWerks Cyclery TrailWerks Suspension Service trailwerkssuspension.com trailwerkscyclery.com
Forum Rules
