Results 1 to 5 of 5
    Small bump damping strategy-Rockshox
    For forks where it is difficult to find decent small bump compression sensitivity, has anyone considered running the fluid level low, below the damper, so that the damper is not immersed at sag level, and doesn't get any damping until the fork compresses an inch or 2?
    Your thoughts?
    Michael
    old guy
    It will ride like crap. Imagine slapping water with an open hand. Swinging it through the air is fine until you hit the water and then, abrupt stop.
    Reputation: mullen119's Avatar
    This would also cause cavitation which would cause a terrible ride and eventually cause damper failure.
    moaaar shimz
    Reputation: tacubaya's Avatar
    Terrible idea
    Reputation: DethWshBkr's Avatar
    NO!!!
    If anything, try running a thinner fluid. You will not want what you suggest.
  1. Bad small bump sensitivity on my Bronson- ?s
    By jmallory in forum Santa Cruz
    Last Post: 12-15-2013, 04:42 PM
  2. Has RockShox SID small bump compliance?
    By Woodwhistler in forum Shocks and Suspension
    Last Post: 09-26-2013, 06:50 AM
  3. fox van rc2 180mm help with small bump
    By bhigdon101 in forum Shocks and Suspension
    Last Post: 10-23-2012, 07:53 PM
  4. fox van rc2 180mm more small bump compliance
    By bhigdon101 in forum Downhill - Freeride
    Last Post: 10-07-2012, 03:30 PM
  5. New Jekyll small bump performance
    By Morgs010 in forum Cannondale
    Last Post: 03-24-2012, 11:49 AM
