• 01-12-2013
    Muffinhead
    Small amount of play in Manitou Tower Pro
    Today I got the fork installed on the bike, and everything seems good so far except that there is a little bit of play in the first few mm of travel, as if there isn't any resistance at all. For example, if I pick up the bike by the handlebars and jolt the front wheel back and forth, the lowers on the fork seem to "move" up and down a little. Is this normal, and if not, how can the problem be alleviated?
  • 01-12-2013
    keen
    Here is a pictiure of the inner workings of the Mar's air spring - should have zero "play". Air sping piston preloads spring rod then coil spring then spring shaft rod.
    http://www.jonesparkchronicles.com/M...d_Increase.jpg
    Has the fork been apart ?
  • 01-12-2013
    1niceride
    Do you mean as in a loose damper or spring rod? If its a new issue check it out. Probably needs a service anyway?
  • 01-12-2013
    Muffinhead
    I mean when you compress the fork, the first few millimeters of travel feel like they don't have any sort of resistance.
  • 01-12-2013
    beanbag
    My minute pro is like that too. The spring is not quite long enough to push the compression pushrod out all the way. It is about 1/8" worth. If you increase the air pressure, it helps recover a little bit.
  • 01-12-2013
    Muffinhead
    Ok, I'll try that tip out.
  • 01-12-2013
    keen
    Play or looseness is usually felt if you hold the front wheel down and compress / extend the fork. You could invert the bike and remove the front wheel then lightly compress / extend the lowers - should be no looseness.
  • 04-21-2013
    kylemcnulty23
    Sorry to resurrect this thread by a few months guys but I have the exact same problem. Muffinhead did you ever figure out a fix for it? Because of the minimal resistance when I"m riding over some rocky areas sometimes I feel like the fork is chattering a little bit because there isn't much resistance.
  • 04-21-2013
    Aresab
    I have a few Minute Pro and Nixon Super models, they all have a smidge of travel upfront, even with the X-Firm spring. It should be just a bit of sag, it's a good thing as it helps the wheel follow ruts smoothing out the ride. I'm a fan of the MARS system, I also have a Coil RS Sektor and SoloAir Recon 20mm, but in my opinion, the MARS based pro blows them away in feel (and my Recon has been upgraded to dual-flow rebound like Manitou already has).
  • 04-21-2013
    kylemcnulty23
    Ah that's great to hear, really helps relieve some anxiety from a new fork haha. Initially there seemed to be some sort of top out clunk from the small amount of play. If I would slightly weight, then unweight the fork to activate the small amount of travel with low resistance there would be a low sounding clunk, but I've been riding the fork nonstop and it seems to have fixed itself so I'm attributing it to the break in period
  • 04-22-2013
    mattsavage
    Yeah, that's normal... My Minute and Nixon MRD's all do it. the top out clunk is annoying.
