Results 1 to 3 of 3
    Reputation: VT Mike's Avatar
    slick honey instead of judy butter?
    I'm servicing an 04 Duke SL U-turn. The instructions say to coat the spring with Judy Butter. Is it okay to use Slick Honey instead?
    www.derbyrims.com
    Reputation: derby's Avatar
    No problem
    Quote Originally Posted by VT Mike
    Judy Butter is like Slick Honey with higher viscosity (stickier). Slick Honey tends to thin out faster in heat and may not quiet spring rub inside the stansions as long and might need more frequent maintenance to keep the fork quiet. But no problem using it where Judy Butter is speced, except more frequent maintenance. And Slick honey is a lube with faster, or less damping effect.
    - ray
    ... and if we just ...
    Have been using slick honey instead of judy butter for years and have found that it works better in all conditions.
  1. Swapping Mag 21 and Judy crowns
    By Rumpfy in forum Vintage, Retro, Classic
    Last Post: 05-09-2007, 11:39 AM
  2. judy springs - color coded?
    By slim in forum Shocks and Suspension
    Last Post: 03-08-2004, 07:27 AM
  3. what do you lube your stanchions with?
    By switch in forum Shocks and Suspension
    Last Post: 03-03-2004, 12:22 PM
  4. rs judy lubrication
    By orestis-xc in forum General Discussion
    Last Post: 02-15-2004, 10:52 AM
