Results 1 to 2 of 2
    sid vs sid B damper
    I was wondering if anyone could please explain the difference in parts between the sid and sid b. I'm looking to replace the damper and there are two options and I am not quite sure what the difference is
    Feb 2010
    Comp damper or rebound damper? SID B comp damper has slightly smaller sealing diameter at the bottom of the damper because SID B stanchions are thicker, so smaller on the inside. SID B comp damper can be used in SID fork with a slightly larger o-ring but not recommended. SID B rebound damper has a longer shaft to accomodate 120mm travel.
  1. A little help on a RLT damper....
    By Miker J in forum Shocks and Suspension
    Last Post: 06-16-2013, 11:53 AM
  2. TK damper to MC damper- is it possible?
    By arevuar in forum Shocks and Suspension
    Last Post: 01-27-2013, 01:16 PM
  3. Fox F29 Damper vs. Damper oil bath?
    By Tcov in forum Shocks and Suspension
    Last Post: 05-19-2012, 07:03 AM
  4. DUC 32 damper knob/damper rod bolt turning
    By voob in forum Maverick
    Last Post: 01-09-2012, 08:35 PM
  5. RL Damper to replace my R damper on Float R 130MM
    By 434Mtbiker in forum Shocks and Suspension
    Last Post: 02-03-2011, 07:27 PM
