Results 1 to 5 of 5
    Dec 2009
    Shock upgrade, possible clearance issues?
    I have a 2009 Slayer SXC 50 that is used mostly "all mountain". I had the stock rp23 serviced about 6 months and 40 rides ago and it has a blown damper, again.
    I want to upgrade to something more reliable, or at least something I can service, but I seem to remember that there may be clearance issues with some shocks.
    Can anyone confirm whether a CCDB Air will fit in there? Are there any other options I should be looking at?
    BTW, I am 175lbs and typically have to have my Fox at about 180-200lbs pressure to not bottom it with the way I ride.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    You can service an RP23......most times it is just a bad seal on the air can.....takes about 1/2 hour the first time you do it.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Dec 2009
    Thanks for the quick reply. I would happily service the air sleeve if I thought that was the problem.
    The shock holds pressure just fine right now. It left two 10" puddles in my garage as the bike sat after the last rides. There is nowhere near that quantity of float fluid in this shock when properly lubricated. It now blows through travel and barely has any dampening to speak of.
    I am pretty sure the damper is blown.
    Dec 2009
    Quote Originally Posted by mtnbikej View Post
    Mtnbikej: Do you still think it could be the air sleeve? I appreciate any input you have.
    SS Pusher Man
    Sep 2001
    Personally I run a Monarch, and RS sells a complete service kit.
    Not sure what Fox does beyond air service kit for the consumer without having to send it in.
    Bucky the Cat
  1. Anyone Having Clearance Issues with XX1?
    By Salespunk in forum Ibis
    Last Post: 01-26-2013, 01:51 PM
  2. Et tu, JET 9? Crankset clearance issues....
    By BruceBrown in forum Niner Bikes
    Last Post: 09-11-2012, 01:07 PM
  3. 951 Crank Arm Clearance Issues
    By stunzeed in forum Intense
    Last Post: 05-30-2011, 01:59 AM
  4. e13 cranks on Uzzi Vp. Any clearance issues?
    By Greg An. in forum Intense
    Last Post: 04-28-2011, 07:50 AM
  5. 29-3 TLR 2.25 clearance issues?
    By A1an in forum Gary Fisher
    Last Post: 01-03-2011, 08:24 AM
