Results 1 to 7 of 7
    Reputation: dirtrider76's Avatar
    Sep 2012
    Shock bushing stuck
    I have a Fox DHX5.0 and the aluminum adapters on the air chamber end are stuck in the bushings. I haven't been able to move them at all, the bushings on the other end come right out. I don't care about the adapters and just want them out. I'm at the point now I'm ready to drill it out till one side comes off so I can push the bushing out! I've tried putting a screw extractor in them to spin them out, clamped the bushing in my vise and tried to spin it nothing. It wont spin, work outward nothing.
    Anyone got any advise on how to get them out?
    I like to fart when I'm in front of you on a climb
    Braaap
    Reputation: DirtMerchantBicycles's Avatar
    May 2014
    Press it out with a vise and sockets.
    Dirt Merchant Bicycles
    Providing unrivaled support and unbeatable pricing on all cycling goods to riders near and far.
    Sep 2012
    You can't press the bushing out till the aluminum frame adapters are out. That's what is stuck and won't come out.
    Outcast
    Reputation: Renegade's Avatar
    Drill them out. Don't use a drill bit larger than 31/32 (.468 inches) or 12 millimeters.
    Braaap
    May 2014
    If its "pin and sleeve" reducer hardware you can press everything out.
    If its "two piece" hardware then a bolt extractor should be able to bite in and allow you to grab and pull. Not talking about using an easyout to "spin" it off.
    Try a few drops of PB Blaster. Drilling it out seems excessive.
    Sep 2012
    Yeah its been soaked a few times in Pb blaster over the last couple week's.
    Tree Crasher
    Reputation: rockhop's Avatar
    Mar 2006
    Screw extractor won't loosen it? Never heard of such a thing. If it's that seized then I would recommend drilling out the reducers, working up to the largest bit your drill can handle. Then with a hammer and chisel gently from the side see if you can get it to collapse on itself. Repeat with the other side. Aluminum is soft, shouldn't be too big a deal.
    I suppose you're replacing with the urethane ones.
    CRAP... I'm in the wrong gear
  1. Jet 9 RDO offset shock bushing
    By 06HokieMTB in forum Niner Bikes
    Last Post: 09-03-2014, 04:44 PM
  2. Eccentric Shock Bushing
    By fuentes_88 in forum Ibis
    Last Post: 07-13-2013, 08:13 AM
  3. ESTX Shock Bushing
    By Jlar in forum Rocky Mountain
    Last Post: 04-06-2012, 06:41 AM
  4. Replies: 7
    Last Post: 06-25-2011, 06:57 PM
  5. Helius FR Shock bushing
    By Karve in forum Nicolai
    Last Post: 03-29-2011, 11:03 AM
