Kick Start My Heart
Setting Sag - Helpful Hint from my kids
So I finally get around to changing the oil in my Tora 318. No biggie really, - follow the directions and everything is good.
I have it back together and mounted, go to set up the sag, and have one of the kids measuring, and they ask, 'why isn't there a ruler on the fork? instead of measuring?' -I don't know - 'just put one on there then'
Smart kid. I drew one on with a Sharpie. I can wipe it of with alcohol, or may just let it wear down.
Good thinking!
I tried really hard to post a pic, but failed. You get the idea though.
Good thinking!
I use a sharpie to mark max travel (stroke) of the rear shock then compare the o-ring to the sharpie mark after a few drops. Next time you have the fork apart install an o-ring on the stanchion - use to set sag & max travel used.
or just snug a zip tie around the stanchion if you don't have the fork apart.
If in doubt, assume sarcasm
Canfield Nimble 9 * WTB Phoenix * Salsa Big Mama
- You may not post replies
- You may not edit your posts
Forum Rules
