    Apr 2005
    Setting sag on 07 Fox Float R 130 mm fork?
    I have an 07 Fox Float R 130 mm fork on a Gary Fisher Cake 2 DLX. I read on the Fox website that sag should be set to 25% of Fork Travel. The problem is when i set the sag to 25% of fork travel I never use the top 2 inches of fork travel. I have a zip tie on the fork so i can see how much travel im using on a ride. I have to set the fork to about 40% of sag to use all of the travel on the fork. So im either using the bottom 2/3 of fork travel or the top 2/3 depending on the amount of air i put in the shock. How can i use the full amount of travel the fork is supposed to offer? Am i setting it up correctly, is the shock working properly? What's annoying is the geometry of the bike changes as well when i use either the top 2/3 or bottom 2/3 of shock travel.
    Andrew Fox
    Ft. Collins, CO
    Apr 2005
    Shameless bump.
    somebody's got to know something!
    Quote Originally Posted by afox
    Shameless bump.
    try the reviews, I think I've seen people say the Float forks tend to be progressive, as you've found.
    Because it's an R model, you don't have the option of dialing up the compression to firm it up, but you could send it to PUSH and they could work their magic.
    Reputation: JHwick's Avatar
    Read through this thread: Full travel of a FLOAT
    My solution involves cutting the compression rod to enlarge the air chamber and create a more linear spring rate.
