Results 1 to 2 of 2
    servicing a Fox Float 2011 fork
    My Fox Float fork is getting very stiff. Dunno what's going on, but certainly something is wrong. Do I really need to send it in, or is the Float serviceable (to some extent) by a user with medium skills and a reasonable collection of mechanical tools? If positive, can somebody direct me to appropriate technical documents? Many thanks in advance!
    Quote Originally Posted by adriano View Post
    Fox forks are fine to service yourself. Check here for technical - WebHelp
    Go to "service" for oil volumes and further details required in order to perform the service.
    I ground down a socket to use on the top caps but not far enough. Managed to chip the hex shape so i just bought a fox socket for next time i serviced.
    From memory you will only need seals, foam rings, float fluid and green fluid for your service but double check on the link i've posted.
    All the best.
  1. 2011 Fox 32 Float 29 RLC FIT Fork sanction play
    By bassn in forum Shocks and Suspension
    Last Post: 10-12-2012, 12:34 PM
  2. Servicing Fox F100RLT & Float RP3
    By Tso in forum General Discussion
    Last Post: 06-27-2012, 09:39 AM
  3. Servicing a FutureShock fork
    By ErikGBL in forum Specialized
    Last Post: 02-15-2012, 03:01 PM
  4. 2011 Talas Servicing
    By Spokerider in forum Shocks and Suspension
    Last Post: 08-11-2011, 10:42 AM
  5. Revelation 2011 servicing
    By mark_o in forum Shocks and Suspension
    Last Post: 07-20-2011, 12:05 PM
