Results 1 to 7 of 7
    Reputation: steve_b77's Avatar
    Sektor RL Solo Air
    On the new Rockshox Sektor RL Solo Air, can the travel be reduced?
    Is it just a case of fitting an internal space like on Dual Air forks or is it something more complicated?
    Yes it comes with spacers to adjust the travel from 130mm, 140mm, and 150mm.
    Nice one, is it as easy to do as normal Dual airs?
    Haven't done it on my Sektor, I personally think it climbs pretty well at full travel, but heres the Service manual from SRAM http://www.sram.com/_media/pdf/rocks...cal-Manual.pdf
    I don't think the spacers lower the fork length, they just limit the travel unlike the U-turn where you can actually shrink the length of the fork.
    thanks for the link, nice info there.
    Surely the length must drop
    Yes the A-C height changes
    Quote Originally Posted by Flboy
    yeah upoun further research it does lower the fork. I was confused about how the inner workings worked and assumed the spacers worked as bushings to limit the travel.
