Results 1 to 8 of 8
    Running Boxxer WC Without Oil Seals?
    Title pretty much says it... Do any of you have any experience running your WC fork without the oil seals and just the dust seals. I've heard it significantly reduces stiction but i'm curious if any one with first hand experience can comment. If so, i'm also curious as to how much the service interval time decreased running the fork this way.
    How would you keep the oil in the fork
    The dust seals get the job done but you need to overhaul the forks more often. So what i'm wondering is how often guys have to rebuild their fork when they ditch the oil seals.
    moaaar shimz
    Reputation: tacubaya's Avatar
    One guy from Ridemonkey did it. Stiction got reduced but he reported plenty of oil weepage and returned to the oil seals.He said you would have to add lubrication oil every couple of rides...
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    You can get foam rings to replace the oil seals. Works very well in getting rid of the stiction. Some people have also had good results by adding fluoro oil to the stanchions.
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    Quote Originally Posted by pipes10 View Post
    I've been hearing that's the best thing to do to minimize stiction and keep the oil from weeping.Any idea where to source 35mm foam rings?
    Calm Like a Bomb
    You can get them from SRAM but you have to ask as there isn't a part number for them yet I don't think. Come spring they should have that sorted.
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    maybe the smart compromise would be to remove the tension spring from the oil seal
    maybe a little judicious sanding of the seal lip itself if you really want that last bit of friction gone.
    Personnally, even brand new, I was saying 'what stiction?' to my WC compared to my U-turn Revelation.
    2011 Canfield ONE 200mm DH 35 pounds
    2010 Specialized Pitch 29 lbs sold
    Wife: 2009 Canfield ONE also 29 lbs
  1. Boxxer RC seals
    By KAZU in forum Downhill - Freeride
    Last Post: 01-18-2012, 12:21 PM
  2. 32 mm boxxer seals deals
    By toothoogre in forum Where are the Best Deals?
    Last Post: 06-30-2011, 11:25 AM
  3. Boxxer Seals Blowing Off
    By Wrench Monkey in forum Shocks and Suspension
    Last Post: 10-05-2010, 02:45 PM
  4. Boxxer seals
    By Iranian-Mechanic in forum Downhill - Freeride
    Last Post: 08-05-2009, 04:46 AM
  5. Marzocchi seals TO Boxxer TO ? Pike?
    By Robot Chicken in forum Downhill - Freeride
    Last Post: 06-13-2005, 10:16 AM
