    CT3
    CT3 is offline
    Hoodwink
    Reputation: CT3's Avatar
    May 2010
    RS shock pump on FOX suspension
    dont have access to my topeak shock pump. so i tried using the RS pump that came with my recon on my FOX fork and shock. it doesnt seem to make any type of reading of psi. if i just pump it air gets in there and has some spike the pressure on the gauge really fast then just goes down. it puts air in it sort of but there is no way of telling how much. if i push the bleed button instantly goes to 0
    is this normal for RS pumps to only work on RS stuff?
    Nope, my rs pump that i got with my revelation works great with my fox float 36.
    Sent from my GT540 using Tapatalk
    staike
    Reputation: staikeinthahood's Avatar
    That's what happens when you use Rock Shox air in a Fox fork. They've added a special ingredient to the pum that reacts with the seals and oil in your Fox fork... expect your fork to be garbage within in a week.
    But seriously, yes it should work. I've used different brand pumps on different brand forks and shocks many times and it has always worked... maybe the pump is faulty, lacking an o-ring or something?
    CT3
    CT3 is offline
    Hoodwink
    May 2010
    probably bad pump. seems it doesnt depress the valve when screwed on all the way.
  1. Manitou shock/fork pump & SPV pump, what's the difference?
    By snovvman in forum Shocks and Suspension
    Last Post: 02-03-2010, 12:17 PM
  2. Swinger SPV: Reg shock pump or SPV pump?
    By backwoodser in forum Shocks and Suspension
    Last Post: 03-24-2007, 07:58 AM
  3. Tire air pump vs.shock air pump -- difference?
    By Creelove in forum Shocks and Suspension
    Last Post: 09-10-2004, 06:28 AM
  4. New Shock Pump / Fri Nite Pump Porn...
    By Speedub.Nate in forum General Discussion
    Last Post: 02-26-2004, 09:13 AM
